Old 8th November 2004, 18:12   #41  |  Link
karl_lillevold
karl_lillevold's Avatar
Shinobu: thanks for explaining ehq levels so well!
gabo: please do use search, and read the stickies. Next time you ask before you search, you will be given a strike.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 8th November 2004, 23:57   #42  |  Link
karl_lillevold
** 2004-11-08: Fix for Medium EHQ complexity, which
almost no one is using. No need to update if you are not.
Old 18th November 2004, 00:14   #43  |  Link
hubereevez
Star member
hubereevez's Avatar
hi : high memory usage ?
hi,
I did search the rv section, but didn't see anything related to my question/problem....
I do have 1 Go DDR, but producer uses quite a lot : 430 Mo.... lol
I didn't check if this is normal or not (due to the 10.1.0.390 ?)
With Process explorer from sysinternals, I can check wich handle is open from producer. This not telling me smthg, cose I'm a big noob.....
Voilą ! should I format ?
Thanks
hubert
hubereevez is offline   Reply With Quote
Old 18th November 2004, 00:19   #44  |  Link
karl_lillevold
hubereevez: with Avisynth as the input to Producer, the memory usage will be very large. Most of it is in Avisynth. Compare with encoding a short uncompressed AVI file
And especially during the 2nd pass, because due to a bug in Avisynth/DirectShow, memory from the 1st pass is never freed, and memory usage pretty much doubles
Old 18th November 2004, 00:23   #45  |  Link
hubereevez
Star member
hubereevez's Avatar
erf
oki
Actually I did red somthg like that in a post from satsuki.... but I had missundertand it perhaps, I believed that the cause may be dll encoding and not through producer cmd...
i will check without avisynth
thanks karl (who said you're not fast lol)
Old 18th November 2004, 00:31   #46  |  Link
karl_lillevold
It's even worse when using the SDK for batch encoding, since then memory will not be freed in between each encoding. This results in memory usage becoming quite impossible to deal with, for more than a couple of sequences.
Old 18th November 2004, 00:41   #47  |  Link
Sirber
retired developer
Sirber's Avatar
I wonder why this bug don't get corrected... it's been known for years
Detritus Software
Sirber is offline   Reply With Quote
Old 18th November 2004, 23:10   #48  |  Link
damrod
damrod's Avatar
realbatch 1.5b in vb6 with sdk => around 80Mo for each pass (no avs)
realbatch 2.1 in delphi7 with sdk => around 25Mo for each pass (no avs)
but it's true sdk don't free memory : when i encode lot of files, usually after 10 files sdk use 100-130Mo and it remains like with for the rest of the list....never more (with rb in vb6)
does the sdk proc 'release ressources' can release memory?
Projects :
(dev stopped) DamBatch, MBatch
(generate mkv/mp4 files with aac(+)/vorbis/mp3 and x264/xvid/real or simple avi with h264/mp3 for fast reencoding using mencoder)
Website : Damrod.com
damrod is offline   Reply With Quote
Old 24th November 2004, 20:48   #49  |  Link
karl_lillevold
** 2004-11-24: Fix for parameter firstPassComplexity. This
was in most cases ignored, and always set to 50 for the
new R/C and 65 otherwise.
Thanks to D-C for discovering this bug. There is no need to update unless you specifically need to increase firstPassComplexity, which very very rarely has any effect on the accuracy of the rate control.
Old 24th November 2004, 20:56   #50  |  Link
Sirber
retired developer
Sirber's Avatar
ok
I'm using it for "Extreme" at 65, otherwise I'm at 50. Gonna upadte for RealAnime 2.30. Thanks D-C and Karl!
Detritus Software
Old 10th December 2004, 18:55   #51  |  Link
karl_lillevold
** 2004-12-06: Fix for rcBestPSNRMode introduced 11-24.
rezard found a problem in which I accidentally always enabled a feature that was supposed to only be used with rcBestPSNRMode, so please update when you have a chance.
Old 10th December 2004, 19:13   #52  |  Link
Sirber
retired developer
Sirber's Avatar
RealAnime 2.30 will be ready with it.
Detritus Software
Old 11th March 2005, 07:56   #53  |  Link
rezard
the Rate Control stretch tiny frames.
RealVideo Rate Control 2nd pass log:
Framerate: 23976/1000 = 23.976000 fps
Total number of frames: 30518
Target filesize: 123833344 bytes
Keyframe boost adj: 1.00   Nonlinear adj: 1.00
CtrlStrngth: 5  MaxOFlowImpr: 1  MaxOFlowDegr: 1
Num	Type	Quant	Size	Scaled	AdvSc	Target	Actual	Error	OFlow
0	i	14	19333	7627	7627	7627	9216	1589	-1589.00
1	p	13	5836	2581	2581	2555	2313	-242	-1387.74
2	p	13	8262	3746	3746	3708	2812	-896	-532.49
3	p	13	7850	3611	3611	3585	2645	-940	366.77
4	p	14	11903	4978	4978	4995	4364	-631	957.03
5	p	14	10873	4460	4460	4504	4059	-445	1361.28
6	p	13	8414	3821	3821	3859	3600	-259	1579.54
7	p	13	8376	3788	3788	3825	3127	-698	2236.79
8	p	13	11388	4773	4773	4820	4767	-53	2249.05
9	p	13	10531	4315	4315	4358	4449	91	2117.31
3297	p	5	892	459	459	1018	3002	1984	1152267.81
3298	p	3	453	240	240	798	3267	2469	1149796.56
3299	p	5	1083	563	563	1120	2639	1519	1148275.31
3300	p	7	1789	907	907	1463	2487	1024	1147249.06
3301	p	7	1517	808	808	1363	2211	848	1146398.80
3302	p	6	1367	714	714	1269	2526	1257	1145139.55
3303	p	7	1430	749	749	1303	2153	850	1144287.30
3304	p	5	960	499	499	1053	2948	1895	1142390.05
3305	p	5	918	468	468	1021	2614	1593	1140794.79
3306	p	4	725	378	378	930	2834	1904	1138888.54
3307	p	6	1101	576	576	1127	2180	1053	1137833.29
3308	p	5	1066	571	571	1122	2744	1622	1136209.04
3309	p	7	1622	819	819	1369	2389	1020	1135186.79
3310	p	5	806	425	425	975	2854	1879	1133305.53
3311	p	7	1559	817	817	1366	2250	884	1132419.28
3312	p	8	2105	1010	1010	1558	2397	839	1131578.03
3313	p	8	1886	900	900	1448	2222	774	1130801.78
3314	p	7	1337	677	677	1224	2241	1017	1129782.52
3315	p	8	1967	950	950	1497	2247	750	1129030.27
3316	p	8	1776	906	906	1453	2041	588	1128440.02
3317	p	9	2051	959	959	1505	2151	646	1127791.77
3318	p	9	2912	1415	1415	1961	2343	382	1127407.51
3319	p	8	2062	1011	1011	1557	2255	698	1126707.26
3320	p	9	2232	1117	1117	1663	2034	371	1126334.01
3321	p	8	1915	964	964	1509	2080	571	1125760.76
3322	p	9	2094	1041	1041	1586	1967	381	1125377.50
3323	p	8	1501	710	710	1255	2132	877	1124498.25
3324	p	8	1561	718	718	1262	2057	795	1123701.00
3325	i	15	29926	11020	11020	11130	13880	2750	1120951.00
3326	p	10	24994	9416	9416	9959	16862	6903	1113993.00
3327	p	12	11881	4740	4740	5279	4956	-323	1114261.00
3328	p	13	15048	6191	6191	6730	4956	-1774	1115980.00
3329	p	13	20556	8106	8106	8646	9054	408	1115517.00
3330	p	13	11945	4955	4955	5495	4445	-1050	1116512.00
3331	p	13	10167	4170	4170	4711	4034	-677	1117134.00
3332	p	14	23325	8987	8987	9528	9160	-368	1117447.00
3333	p	13	12313	4882	4882	5423	5275	-148	1117540.00
3334	p	13	11753	4891	4891	5432	4348	-1084	1118569.00
rezard is offline   Reply With Quote
Old 12th March 2005, 17:52   #54  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
you must use higher Oflow because quant prediction isn't very good
CtrlStrngth: 5 MaxOFlowImpr: 50 MaxOFlowDegr: 50
But for me the RV10 RC isn't good: for me a good RC could make second pass with constant quantizer (for I,P,B with possible ratio/offset for I quant boost and B quant reduction) with RC variability setting ...
XviD or RV10 use rcLowBitrateBoost and rcHighBitrateReduce for variability setting but I don't understand the difference between these setting: if you reduce bitrate for "high motion" (high bitrate part) you boost automaticaly bitrate for "low motion" (low bitrate part). Only one setting is necessary: varaibility like for x264 or Bitrate Modulation for DivX ...
For me the best example is x264 RC ...
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 15th March 2005, 02:27   #55  |  Link
rezard
I tried 5/50/50.
indeed, the number of extreme low quants were much less. but not perfect.
1	p	13	5836	2581	2581	2503	2261	-242	-1387.74
2	p	13	8262	3746	3746	3678	2782	-896	-532.49
5	p	14	10873	4460	4460	4506	4061	-445	1361.28
6	p	13	8414	3821	3821	3886	3627	-259	1579.54
7	p	13	8376	3788	3788	3864	3166	-698	2236.79
8	p	13	11388	4773	4773	4881	4828	-53	2249.05
9	p	13	10531	4315	4315	4423	4514	91	2117.31
6285	p	10	8181	3728	3728	4921	4944	23	24583.59
6286	p	11	7971	3517	3517	4708	4351	-357	24910.06
6287	p	11	10966	4918	4918	6125	5655	-470	25349.53
6288	p	11	7709	3521	3521	4749	4005	-744	26063.00
6289	i	7	2656	2425	2425	2465	2389	-76	26139.00
6290	p	9	2086	1168	1168	1801	1640	-161	26300.54
6291	p	7	954	565	565	1202	1831	629	25672.07
6292	p	5	467	268	268	890	2326	1436	24236.61
6293	p	3	184	161	161	748	2302	1554	22683.14
6294	p	1	465	256	256	805	2411	1606	21077.68
6295	p	2	482	247	247	757	2351	1594	19484.21
6296	p	4	862	436	436	908	2433	1525	17959.75
6297	p	6	747	356	356	791	1804	1013	16947.28
6298	p	7	931	427	427	837	1859	1022	15925.82
6299	p	9	1657	775	775	1162	1906	744	15182.35
6300	p	9	1650	735	735	1102	1939	837	14345.89
6301	p	10	1719	768	768	1152	1776	624	13722.42
6302	p	10	1635	724	724	1086	1769	683	13039.96
can I request you to explain about the MaxOFlowImpr/MaxOFlowDegr?
I'm eager to have a quant-limit option in the RC.
Old 15th March 2005, 07:46   #56  |  Link
Dark-Cracker
Dark-Cracker's Avatar
@rezard
do u think u can try the RC AltCC who is in autorv10 to see which result it give u ?
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec.
AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles.
Dark-Cracker is offline   Reply With Quote
Old 15th March 2005, 10:58   #57  |  Link
rezard
sorry, I love manual encoding.
what should I do with .pass(analysis) file produced by ScaleCurve.exe?
Old 15th March 2005, 19:05   #58  |  Link
karl_lillevold
I have on my list of things to do, to do another pass at the rate control. These are good suggestions for areas to look into:
1) QP limits.
2) improve prediction of QP for small frames.
3) perhaps combine rcLowBitrateBoost and rcHighBitrateReduce
Old 28th March 2005, 18:41   #59  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
@ karl_lillevold
I test seriously the RV10 Rate Control ... and I humbly make some suggestion to improve it.
1) Don't use Average PSNR for RC optimization. Overall PSNR is very better for visual optimisation tweak. Use Overall PSNR in rv9log.txt.
2) Overall PSNR is better with quality mode (vbrQuality + scalingFactor). The quant prediction for New RC is not good for me. If second pass average quant is very higher than the first pass rcPFrameRefQuant then variability quant in 2 pass could be very high. That observation is confirmed by the high default overflow setting. Perhabs multipass rate control could be very better. First pass for first evaluation, second pass with first pass average quant prediction and final pass with better quant prediction. Perhabs bframe sensivity/treshold setting could be good too for test ...
3) bframe decision seem strange: 1 or 3 bframe but not 2. Bframe decision in P(n-2) B (n-1) I(n) with Iframe scene change frame is strange too:
23160	17	1752	40.08	23280	34.11	41.26	12943		100
23200	17	1508	39.96	21640	34.11	41.26	12958		100
23240	17	1180	40.35	19096	34.11	41.26	12969		100
23280	23	2120	35.15	17800	34.11	41.24	13150	d	100  ????
23320	17	13696	37.50	113648	34.11	41.25	13142	Key	100
23360	23	1304	35.37	13128	34.11	41.23	13230	d	100
23400	17	4920	36.91	60272	34.11	41.24	13230		100
IMO if you change bframe for Pframe the quality for Pframe is very higher (Pframe use previous frame, bframe use previous frame and Iframe scene change for reference ... ). Min frame PSNR is praticaly always for bframe in these particular sequences. IMO with Iframe scene change you must close GOP ...
Old 29th March 2005, 23:50   #60  |  Link
karl_lillevold
Sagittaire: these are good suggestions. Thanks!
