Old 22nd January 2023, 23:13   #1  |  Link
Terka
fresh computer reinstall
please which codecs and movie player should i use these days.
Im used to bsplayer. And have ryzen 9 but no 3d card.
Terka is offline   Reply With Quote
Old 23rd January 2023, 01:38   #2  |  Link
LAV filters.
MPC-HC, PotPlayer, VLC, would be my choice [I install x64 & x86 for 1st 2, but that would not be everybodies pick]
(For Avisynth/VDUB2, UT_Video, MagicYUV)
EDIT:
I use x64 and x86 for testing Avisynth scripts [as well as VDub2 x86 and x64],
but also,
I use x64 for regular default player, but use same x86 player to continue watching some movie from last played position (when player set to do that).
Old 28th May 2023, 09:26   #3  |  Link
butterw2
+mpc-be and mpv, mpv.net.
https://www.videohelp.com/software/s...orderby=Rating
butterw2 is offline   Reply With Quote
Old 2nd June 2023, 17:05   #4  |  Link
butterw2
I just realised VLC default install included 40MB of locale that I didn't want or need. Did anyone say bloated ?
Old 9th June 2023, 18:48   #5  |  Link
Asmodian
Locale is very useful if you do need it and 40MB is pretty small today. Don't look a gift horse in the mouth.
madVR options explained
Old 26th June 2023, 10:40   #6  |  Link
butterw2
Once you've deleted mpciconlib.dll and the Lang folder, the full mpc-be installed size is less than 35MB.
