Old 27th May 2007, 02:41   #321  |  Link
Ok, thank you kweek. I've duplicated it and will fix it for the next alpha release.
EDIT: The JM reference software has some paths limited to 100 characters!
Guest is offline
Old 27th May 2007, 11:48   #322  |  Link
G_M_C
Looked back at the test i did, i saw a (cosmetic ?) slight error.
The test-file is in 23.976 fps, but the programm-bar of DGAVCIndex reports 23.98 fps. The .dga opens as 23.976 though, so it is probably just cosmetic.
G_M_C is offline
Old 27th May 2007, 12:28   #323  |  Link
hajj_3
Does the latest alpha support dvb-s2 h264 .ts files?? if not please can you add it.
here is a clip for you to test with to get it working, its a dvb-s2 h264 .ts file recorded from discovery channel in sweden:
http://www.sendspace.com/file/hwr40h (58mb)
hajj_3 is offline
Old 27th May 2007, 12:33   #324  |  Link
G_M_C
Please read the earlier posts. It isnt supported yet, it only works with RAW H264 files.
You'll have to demux it, and hope it isnt encoded in PAFF, because that's not yet supported either.
G_M_C is offline
Old 27th May 2007, 13:20   #325  |  Link
hajj_3
i see. hope its supported soon, europe has had dvb-s2 .ts for quite a while now, dgavc and videoredo dont support it yet, its a real shame as the quality it fantastic!
keep up the great work neuron!
hajj_3 is offline
Old 30th May 2007, 18:56   #326  |  Link
lucassp
does DGAVCIndex work with AVISynth 2.5.7 MT 0.7?
lucassp is offline
Old 1st June 2007, 14:33   #327  |  Link
Raere
I just wanted to thank you neuron2 for this awesome plug-in, it's just what I needed for my latest projects. Keep up the good work!
Raere is offline
Old 2nd June 2007, 12:43   #328  |  Link
I don't know. Please report your results.
Guest is offline
Old 2nd June 2007, 12:50   #329  |  Link
Version 1.0.0 alpha 6
* Fixed broken GOP stepping after play/preview.
* Title bar FPS indication now has three places after the decimal point.
* A "Finished!" popup now appears at the end of the Save Project operation.
* Fixed an uninitialized variable in DGAVCDecode that could cause crashes in some circumstances.
* Redesigned the whole decoder DLL situation (read the help text carefully before using alpha 6):
- Now only one decoder DLL is required (libavcodec.dll).
- The decoder DLL is stripped down to include just AVC decoding.
- The decoder DLL must be placed in the same directory as DGAVCIndex.exe. The path is automatically passed to DGAVCDecode.dll in the DGA file.
- The decoder DLL project is buildable in Visual Studio 2005, allowing for direct tracing/debugging.
- The decoder DLL is derived from the ffdshow_tryouts project.
http://neuron2.net/dgavcdec/dgavcdec100a6.zip
I think I'll add transport stream support next, and then tackle PAFF.
Guest is offline
Old 2nd June 2007, 22:55   #330  |  Link
lucassp
using Alpha 5: the first pass works fine but the second pass hangs after the first few frames, the timer goes on and the fps drops to zero.
using Alpha 6: it crashes right after I hit the start button.
lucassp is offline
Old 3rd June 2007, 02:44   #331  |  Link
Since I have never heard of this, you should find out who made it and talk to them about it.
And I have no idea what you are talking about with first pass and second pass.
Guest is offline
Old 3rd June 2007, 08:57   #332  |  Link
lucassp
AVISynth 2.5.7 MT 0.7 is the multithreaded version of AVISynth 2.5.7 made by tsp (http://forum.doom9.org/showthread.php?t=94996). The "first pass" and "second pass" are the x264 encoding passes of this AVS file:
SetMTMode(2,0)
DGAVCDecode_AVCSource("D:\Codecs\test.dga",deblock=false)
LanczosResize(960,544)
lucassp is offline
Old 6th June 2007, 09:00   #333  |  Link
hajj_3
yay, finally dvb-s2 .TS support coming:PPPPPPPP
thankyou!!!!!!!
hajj_3 is offline
Old 7th June 2007, 13:52   #334  |  Link
klinika
Darn it, alpha 6 crashes on everything I try to open with it, and the error popup points out libavcodec in futile effort to shift the blame. But happily, alpha 5 works like a charm. Running regular xp32.
klinika is offline
Old 7th June 2007, 14:24   #335  |  Link
What does the popup say exactly? Did you follow the instructions for installation?
Guest is offline
Old 7th June 2007, 15:46   #336  |  Link
klinika
Well, the whole alpha 6 archive is on its own in one dir, libavcodec and all. I mean, is there something more, have I overlooked something?
The popup says nothing useful:
AppName: dgavcindex.exe AppVer: 0.0.0.0 ModName: libavcodec.dll
ModVer: 0.0.0.0 Offset: 00028bb2
Can't seem to select or copy any of the detailed information, but it's available, just need to know which parts of it would be needed. I wouldn't rule out reformatitis just yet though. There's nothing seemingly wrong with the files I tried, they're encoded with recent version of x264 using basic options and play just fine.
klinika is offline
Old 7th June 2007, 15:56   #337  |  Link
Make a screenshot of the popup and post that.
Also, search your entire system for libavcodec.dll and let me know if there is another one than the one that sits with DGAVCIndex.exe.
Also, post a link to a fragment of a stream that causes this problem. Does it happen with the file test.264 that is included in:
http://neuron2.net/dgavcdec/dgavcdec100a2.zip
Guest is offline
Old 7th June 2007, 16:08   #338  |  Link
Oh, and install this:
http://www.microsoft.com/downloads/d...displaylang=en
Let me know the result.
Guest is offline
Old 7th June 2007, 16:56   #339  |  Link
klinika
Installed the vcredist, nada, didn't do anything. No duplicate libavcodecs except the one in ffdshow dir, and that's nowhere near any PATH variables. And test.264 crashes dgavcindex on open too.
Here's a link to a 5s clip I encoded just for this, which I'm sure you'll find working perfectly on your end, but crashes on mine.
Here's a pertinent screenshot, along with the Amazing Error Popup That Refuses To Be Copied, which I meant before (there's info about every dll loaded in memory there if one scrolls down, and down, and down):
The offset, address, and code stays the same whatever clip I try to open. If that means anything.
I'm acutely aware that no one else has reported similar problems, and I'm not sure if it's worth the effort to investigate as it most probably is an isolated case of conflict somewhere in the bowels of my pc. At least such it would seem to be. Still, alpha 5 works, and with a bit of luck, the next alpha works too But it sure is a perplexing problem
klinika is offline
Old 7th June 2007, 17:44   #340  |  Link
xc3ll
Hi neuron2, I tried your program, but get an this error:
[h264 @ 0100700C]Internal error, IDCT permutation not set
when I try encoding w/meGUI, source is a bd disc.
xc3ll is offline
