13th November 2007, 02:05 | #21 | Link |
Hi, This is my first post - hope I'm in the right place.
I want to use MCBob, but I can't figure out how to apply it to a given clip. Could somebody gently take me through the steps? I work daily with simple AVISynth scripts, but nothing as complex as MCBob. Thanks! |
13th November 2007, 19:33 | #27 | Link |
I'm running mcbob on a quad core 6600 overclocked to 3.2ghz.
Unfortunately, only one core gets utilized. I'm using avisynth 2.5.7.0 and mvtools 1.8.4.2. Deinterlacing a 60i HDV picture @ 1440 x 1080 takes 2 seconds per frame. And looks great, btw. Sure would like to use all four cores. If anybody has any ideas, please speak up! Last edited by rec; 13th November 2007 at 19:36. |
13th November 2007, 19:54 | #28 | Link | |
SetMT(mode=2, threads=4) Avisource("Mydrive:\Myfolder\mysourcevideo.avi") If that doesn't work, then you'll just have to use trim() and process 4 separate segments of the video and assign each segment to one core via taskmanager. Make sure all 4 segments are encoded losslessly so you can encode them to xvid, H.264 or another codec later.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
29th December 2007, 09:37 | #30 | Link |
mcbob is amazing but I have some issues on horizontal lines: they shutter
If I put selecteven it is fine but I would like to keep all the 50 fps. I am using mcbob() without further configuration is there an option that could work for me? |
2nd January 2008, 09:03 | #32 | Link |
it's a little difficult for me to post a part of the file. Anyway the problem is mainly the watermark of the channel and the graphic of the show.
I solved (almost) using tdeint and mcbobbed stream as clip2, it doesn't like flash but it is not so ugly. |
9th January 2008, 03:41 | #33 | Link |
I don't know about getting rid of the watermark, but to keep your 50 fps without using selecteven you could try
complementparity MCBob() |
12th March 2008, 20:05 | #37 | Link |
i'm trying to deinterlace an old anime ntsc r1 (usa) dvd.dgindex reports it as interlaced.here is a sample:
http://rapidshare.com/files/97003811...muxed.m2v.html i'm trying different deinterlacer,am i right using mcbob like that Code:
DGDecode_Mpeg2Source("H:\Kimagure Orange Road Movie 1\VTS_01_1.d2v",info=3) colormatrix(hints=true,interlaced=true) mcbob().selecteven.tdecimate(mode=1,hybrid=1) should i use a different deinterlacer? |
13th March 2008, 00:09 | #38 | Link |
If you're interested in trying something other than mcbob you could look at this thread: http://forum.doom9.org/showthread.php?t=135688
15th May 2008, 22:03 | #39 | Link |
Is there a way to use mcbob just in a section of the encode? Because I'm getting "Framerate doesn't match" error when using trim...
And another question... I know that mcbob doubles the framerate, but how can I get original framerate (29.97fps) back? |
15th May 2008, 22:30 | #40 | Link | |
*Space Reserved*
To get the original rate, use either selecteven() or selectevery(2,0) after mcbob. |
