Old 31st October 2009, 14:20   #181  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Blame ImagesHack. Will re-upload if it remains broken...
Old 31st October 2009, 19:57   #182  |  Link
turbojet
Originally Posted by LoRd_MuldeR View Post
Nope
Bummer, just a usual routine for me.
Runtime x86 -vs- x64 is already implemented
Ah wasn't aware of that never tried on an x86 OS. How an option in x64 mode an option to use x86 x264 for first pass and an option to use x86 for all encodes?
Also any chance of a process priority option and/or a pause/resume option through something like PsSuspend?
Old 1st November 2009, 12:13   #183  |  Link
Buggle
Posts: n/a
Mulder, I'm having some issues here. First, launcher reports me it is using MMX and SSE2slow. As I'm on a X2 Brisbane 5000+, that doesn't make sense (it supports MMX, Extended 3DNow!, SSE, SSE2, SSE3).
Then, I was wondering if there is an option to select/set the buffer size to use for the encode, since there's no one-size-fits all. I've scrolled through this threat and looked for an ini/inf file in the package, but can't find one. Maybe I'm just blind, that could be the case.
Old 1st November 2009, 12:27   #184  |  Link
Buggle
Posts: n/a
Some benchmarks from me. The clip is a trim() of Lord of War, with double DeGrainMedian, Spline36 resize (hardly, but it's in the filterlist) and some Undots. The x264 used is release 1318 from x264.nl
Source: D:\LORD_OF_WAR\VTS_01_1.avs
Preset: Slower
Tuning: Film
Profile: High
Params:
[Type: 32-Bit, Pipe Buffer Size: 0 MByte]
encoded 5001 frames, 5.50 fps, 1106.06 kb/s
encoded 5001 frames, 5.39 fps, 1106.06 kb/s
[Type: 64-Bit, Pipe Buffer Size: 0 MByte]
encoded 5001 frames, 5.91 fps, 1106.06 kb/s
encoded 5001 frames, 5.38 fps, 1106.06 kb/s
[Type: 64-Bit, Pipe Buffer Size: 1 MByte]
encoded 5001 frames, 4.98 fps, 1106.06 kb/s
encoded 5001 frames, 6.01 fps, 1106.06 kb/s
encoded 5001 frames, 5.96 fps, 1106.06 kb/s
[Type: 64-Bit, Pipe Buffer Size: 2 MByte]
encoded 5001 frames, 5.97 fps, 1106.06 kb/s
encoded 5001 frames, 6.18 fps, 1106.06 kb/s
[Type: 64-Bit, Pipe Buffer Size: 4 MByte]
encoded 5001 frames, 6.03 fps, 1106.06 kb/s
encoded 5001 frames, 6.06 fps, 1106.06 kb/s
[Type: 64-Bit, Pipe Buffer Size: 8 MByte]
encoded 5001 frames, 6.15 fps, 1106.06 kb/s
encoded 5001 frames, 6.11 fps, 1106.06 kb/s
encoded 5001 frames, 6.08 fps, 1106.06 kb/s
Old 1st November 2009, 12:51   #185  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
No, that's perfectly normal for an Athlon 64.
Old 1st November 2009, 12:52   #186  |  Link
Buggle
Posts: n/a
How come? I thought x264 is using/can use SSE3 as well.
Old 1st November 2009, 12:54   #187  |  Link
Dark Shikari
x264 developer
Only as a workaround for a weakness of the Pentium 4E.
Old 1st November 2009, 14:43   #188  |  Link
LoRd_MuldeR
Software Developer
I don't see how this would be useful...
No need to use an external tool. As I have created the process(es), I already have the handles to suspend/resume them directly.
And if you click the "X" button, the encoding will be paused. Click "No" to resume...
Old 1st November 2009, 16:21   #189  |  Link
Fr4nz
Hi Lord, it seems that no one asked you this question in this thread: is it possible to implement a "shutdown" function (like the one present in MeGUI) in your launcher?
Fr4nz is offline   Reply With Quote
Old 1st November 2009, 16:45   #190  |  Link
LoRd_MuldeR
Software Developer
Possible indeed. But not currently planned...
Old 1st November 2009, 17:52   #191  |  Link
turbojet
Fast x264 settings run faster with x86 x264. Including fast first passes which I see are ~5-10% faster. For example:
1280x720, preset medium, 2000 kbps, windows 7 x64, athlon ii 620
x86 from command line
pass 1: encoded 1277 frames, 48.40 fps, 1970.02 kb/s
pass 2: encoded 1277 frames, 28.44 fps, 2000.92 kb/s
x64 launcher
[First Pass]
encoded 1277 frames, 45.61 fps, 1969.83 kb/s
[Second Pass]
encoded 1277 frames, 29.02 fps, 2000.89 kb/s
Also I did a benchmark with the same CPU/source.
Preset: Ultrafast
Tuning: None
Profile: High
Params:
encoded 1277 frames, 51.93 fps, 1083.92 kb/s
encoded 1277 frames, 52.19 fps, 1083.92 kb/s
encoded 1277 frames, 51.82 fps, 1083.92 kb/s
encoded 1277 frames, 47.30 fps, 1083.92 kb/s
encoded 1277 frames, 45.61 fps, 1083.92 kb/s
Thanks that works.
Old 1st November 2009, 21:46   #192  |  Link
McArty
That is good to know, i thought wasn't implemented. Very useful for my slow cpu ;.)
p.d. Only that doing so is impossible minimize...
McArty is offline   Reply With Quote
Old 2nd November 2009, 00:22   #193  |  Link
psycoxl
MeGUI does show you the complete commandline for each profile. So you can simply copy&paste
Anyway, if you want to use MeGUI profiles, why not simply use MeGUI?
Not planned. But I have included the sources, so feel free to hack that in
you can't use it with the x264 x64 (or am i wrong)
psycoxl is offline   Reply With Quote
Old 2nd November 2009, 16:05   #194  |  Link
ACrowley
mhh doesnt work here in 2nd Pass.
It was working before but only after 10-10sec until it suspends and cpu load goes down.
But in this Moment it doesnt work anymore in 2nd Pass here ?
ACrowley is offline   Reply With Quote
Old 2nd November 2009, 23:31   #195  |  Link
Buggle
Posts: n/a
Seeing the attention went to the second part of my question about the SSIMs, I would like to ask the first part again to LordMulder: is it, or will it be, possible to select a custom buffer size? I've searched, but didn't find information about this.
Old 2nd November 2009, 23:39   #196  |  Link
Darth Viorel
I really like this small GUI but sometimes it crashes right after it finishes encoding. I can see the log in the background but I get a windows error message saying that the launcher.exe stopped working. It happens randomly and I can't figure out why. What I can exclude is my hardware, it is stable and not the issue.
Darth Viorel is offline   Reply With Quote
Old 2nd November 2009, 23:40   #197  |  Link
LoRd_MuldeR
Software Developer
You mean VBV Buffer or Pipe Buffer? The former can be adjusted with "--vbv-bufsize". The latter is hardcoded to 4 MB in "encode" (non-benchmark) mode.
Old 2nd November 2009, 23:40   #198  |  Link
LoRd_MuldeR
Software Developer
Never seen anything like that
Old 3rd November 2009, 19:09   #199  |  Link
Buggle
Posts: n/a
I meant the pipe buffer. Would it be possible to implement a custom (drop down or so) option to select your own? Depending on the different uses (fast/slow settings and low/heavy filtering for instance) this could provide for some extra benefit speedwise.
Old 3rd November 2009, 19:12   #200  |  Link
Buggle
Posts: n/a
I've experienced this as well, one time.
