28th February 2010, 21:37 | #7002 | Link |
@Lighto
probably you don't have test.idx file in the same folder
1st March 2010, 01:38 | #7003 | Link | |
Nice thing about ripbot.. (Now that I have figured it out better with a little help) you can adjust the quality settings, which also will have a direct effect on the file size too. TGC/WTC |
1st March 2010, 01:50 | #7004 | Link |
I have done a search. But either I am not searching on the right "keyword" or something because I haven't found much. Now I am just more confused than ever.
So if someone can either help me understand this, or provide a link that will explain it better I would be appreciative. In the Profile "settings" box that pulls up when you click on the "..." box next to profile You get a box with all sorts of settings to adjust. So what is: What does it mean? Deblocking Strength Deblocking Sensitivity M.E. Algorithm Subpixel Refinement Macroblock Options of PSXS, SSXS, I4X4 P4X4 and 8X8DCT The rest of it I know i need to leave alone except for what is: Weighten B prediction Weighten P prediction AVCHD compatibility Dadptive Quant. Thanks TGC/WTC |
1st March 2010, 18:04 | #7005 | Link | |
http://mewiki.project357.com/wiki/X264_Settings |
2nd March 2010, 11:38 | #7009 | Link | |
Silent Reader
Komisar builds work if you change profiles. Haven't tested JEEB's, but should work too. Last edited by Wishbringer; 2nd March 2010 at 11:43. |
2nd March 2010, 23:10 | #7010 | Link |
Is there anyway to get around the program check? I want to try ffdshow x64 but it won't allow me. I read that it could be edited in the inf but that has since been removed.
Edit: Or should I just stick with all x86 apps (ffdshow, avisynth, haali media splitter) even though I am on Windows 7 x64? Thanks Last edited by Macota; 2nd March 2010 at 23:16. |
3rd March 2010, 08:18 | #7012 | Link | |
Silent Reader
formerly "--nal-hrd" was only a switch, when not added, no infos were written into stream. now "--nal-hrd" has two options: "vbr" or "cbr". so you have to correct old settings of "--nal-hrd" to "--nal-hrd vbr" in profile text file in the profiles folder. |
3rd March 2010, 10:29 | #7013 | Link |
audio sync problems w/content from NGC HD channel from TiVo HD
From my earlier post at http://forum.doom9.org/showthread.ph...26#post1374626, thanks to Atak for solving my judder problems on one show. There are still unsolved judder problems w/the White House Revealed ep but I'll tackle that later. (I'm on Ripbot264 v1.15.0.)
I'm still using the same workflow (kmttg to transfer shows from Tivo HD to my PC, resulting in decrypted .mpg files) and I'm now trying to archive some 720p content recorded from NGC HD channel, specifically http://channel.nationalgeographic.co.../4541/Overview and http://channel.nationalgeographic.co.../4904/Overview. I'm again using [HIGH 4.0] profile, 2-pass encoding and locking size to 2230 MB, and selected X.X COPY stream and creating AVCHDs that I burn w/ImgBurn to play on my PS3. The video looks fine and there's no judder and audio sync seems fine at the beginning. However, if I skip say 20 minutes into the show, there are SERIOUS audio sync problems. It's off by at least 10 seconds at that point and it happens w/both shows. Now what? The (1080i) content where Atak solved my problem with was a Star Trek: Enterprise ep recorded from HDNet. It has no commercials and the resulting AVCHD has perfect audio sync, even at the end. They fade out to what would be a break (when it airs elsewhere) and fade in again w/the next act. The NGC content DOES have commercials. Could there be audio glitches/changeovers during the commercials causing probs? Does RipBot264 only use the tools that are in its Tools directory or could I be running into DLL hell? The only significant things that I've installed on this machine (running Vista Home Premium) after "installing" Ripbot264 are T2Sami and multiAVCHD. (I did also add subtitles via .srt files from t2sami and doubt they're causing problems but haven't re-transcoded w/o them yet, as a test.) Last edited by cwerdna; 3rd March 2010 at 11:08. |
3rd March 2010, 11:21 | #7014 | Link |
x264 codec update in RipBot264 !
I use RipBot264 for the conversion of my DVD in mkv and I am completely satisfied by the features of this software. However, I would like to have some precision on the version or the revision of the codec x264 used in the version 1.15.0. The reason is the following one: I downloaded the revision 1471 on the site x264.nl then registered the file by reappointing it correctly in the directory, RipBot264/Tools/x264/ then x264_x86.exe. That does not work! When I launch an encoding, I have all jobs finished, after few seconds... Is there a particular procedure to change or update the version of the codec x264 ? Sorry for my bad English... and thanks for your answers. Regards, |
3rd March 2010, 11:40 | #7015 | Link | |
Silent Reader
x264.nl files don't have nal-hrd patch, they are plain, so if you want to use that revision, you have to remove "--nal-hrd" entry in profiles text files in profiles folder. But then you can't create AVCHD or Blu-Ray compilant files. Second: Download a nal-hrd patched version of x264, see thread here: http://forum.doom9.org/showthread.php?t=130364 Komisar builds are good, others too. Then read my post two entries before! You have to change profiles txt files in profiles folder manually. --nal-hrd switch has changed. Overall: Reading the log would point that error out too. |
3rd March 2010, 15:01 | #7016 | Link |
@cwerdna
If your footage contains commercials then you should remove them using Transport Stream Packet Editor. Make sure you cut at KEY FRAMES!
3rd March 2010, 17:51 | #7018 | Link |
Hello there... first and mostly this prog. is superior! I have a quick ?. I have a i7 water cooled rig thats running at 4.2 ghz flawlessly on windows 7 64 bit. with a ati 4890 as well. My ? is that back 3 months ago my rig was flying through making my back ups.... now it doesnt seem to fly as it use to... im making CQ 18/1080 .mp4 with the base profile of 4.1 and having trellis set to enhanced to stream with my bd 3600 sammy. i was just reading through 2 pages ago. and notice someone saying something about rip bot not using the x264 64 bit? i was understood from my reading that this is a default, or am i wrong? i also may have not used the 4.1 profile nor the enhanced trellis back then... do these two factors really make that much of a differnce? my rips now take 4 1/2 hours when i remember doing them in under 2... or am i just being greedy? I guess basically back then i remember my fps were in the mid to high 20's now there always in 10 or below :-( thanks from Detroit!
3rd March 2010, 19:53 | #7019 | Link |
Oh no! Are commercials known to cause problems for x264? I don't personally care that commercials are included in my recordings and am trying to minimize the amount of work needed to archive TV shows I want to keep.
3rd March 2010, 19:58 | #7020 | Link | |
