7th June 2009, 11:41 | #63 | Link | |||||
Perhaps it is an issue with UAC. Completely disabling UAC can cause problems for applications (like this tool) that need to run with Administrator privileges. Quote:
MPC-HC 2.2.1 |
7th June 2009, 12:54 | #64 | Link | |
regarding the owner of the key: it was trustedinstaller. i have already changed it to administrators and have given the administrator an the users full rights. unfortunately it didn't work. |
7th June 2009, 12:59 | #65 | Link | ||
7th June 2009, 14:36 | #67 | Link |
Perhaps you have some kind of security application (firewall, virusscanner) installed that is blocking the tool.
MPC-HC 2.2.1 |
8th June 2009, 14:08 | #68 | Link |
MPC Video Decoder
CLSID,
I know that you've been barraged with requests for adding more decoder options to your very helpful bit of software; here's another. Would you mind adding MPCVidDec.ax to your list of decoder options? Because it enables hardware acceleration, it has been my experience that it is a very good video decoder. Many thanks on behalf of the HTPC enthusiast community, Battles |
8th June 2009, 15:44 | #69 | Link |
I'll put it on the todo list for next version.
The Microsoft decoder also has hardware acceleration and is probably has better compatibility than MPC's decoder (which is still buggy).
MPC-HC 2.2.1 |
8th June 2009, 18:37 | #70 | Link |
Thanks CSLID,
This may not be the appropriate thread for this, but I'd appreciate your view on the best video decoders (by file type encoding...VC-1, .264, mpeg, etc.) that employ hardware acceleration. One problem I was having, in particular, when using the media foundation decoders in Win7, was with regard to the playback of .m2ts files encoded in VC-1 (got audio but no video when playing back through MCE/WMP12). I have since solved the problem by disabling the Media Foundation wrapper (msds.dll) and the WMV decoder (wmvdecod.dll). Now WMP/MCE plays back all of my video files; however, in the process, I feel as though I have lost some of the hardware acceleration for .m2ts AVC/.264 encoded files I was experiencing before disabling the aforementioned files (CPU load used to by 10% now around 60%) when using Microsoft's DTV/DVD Video decoder. Your recommendations would be very helpful. Best, Battles |
8th June 2009, 19:50 | #71 | Link |
Report your problems at the Microsoft Technet forums, preferably with a sample file. Then they might be able to solve those problems before Windows 7 goes RTM.
I don't play any VC1 content, so I can't make any recommendations for it.
MPC-HC 2.2.1 |
8th June 2009, 22:26 | #72 | Link |
VC1 in M2TS won't be supported for RTM. It's a feature request that'll be looked at for the future. =\
battles: yeah, disabling aspects of playback would result in different and potentially bad results. That seems like it would be expected... ?
speaking for myself only |
8th June 2009, 23:02 | #73 | Link |
Thanks. But, I'd rather have MCE playback .m2ts VC-1 than not, even with some slight degradation to CPU efficiency. Considering MS developed VC-1, I'm surprised that MS' support of VC-1 .m2ts will not be in the RTM. I'm sure there is a reason, but if you look at the number of blu-ray titles being released which were encoded in VC-1, it sure would be nice if MS supported this natively. Please feel free to enlighten me on this.
9th June 2009, 01:29 | #74 | Link |
Priorities. You have N people capable of doing X work at Y quality level.
You're making a Feature Request. The right people are aware of it, but it is not going to make the cut for this release, sorry. If they did go off and do that non-trivial work, it's a trade-off with 'other feature' that was deemed of more general value. Trying to be everything to everyone at once doesn't work well in practice.
9th June 2009, 02:25 | #75 | Link |
Thanks. I'm glad to hear that this is on the MCE project team's radar screen -- as it seems support for VC-1 playback is no less important than .264. Hopefully it will be addressed in a service pack or update post release. As you know, there's a community of enthusiasts who spend countless hours poring over chat rooms, forums etc, trying to get their MCE completely dialed in. I'm hopeful that those heading up the MCE project team for win7 fit this profile. A lot of us don't necessarily love the MCE product out of the box, but love its potential, and certainly appreciate what the MCE community on the web has done to optimize the MCE experience.
Thanks for sharing an insider's perspective. |
10th June 2009, 01:29 | #76 | Link |
I also had problems with a french release of 7 RC.
I had to set permissions on the Prefered regkey manually with SetACL Command line to use CLSID's tool. How to do this : Download and unzip this file : permissions.zip Edit permissions.cmd file Change for every line this string : "Administrateurs" by the "Administators word" in german/french/spanish... Save the file and run it with command line (see attached image file) After that you sould be able to change decoders with CLSID's tool. CLSID, do you think you could update your tool to support non english Windows 7 versions. I think you just have to change the "Administrator" or "Administrators" strings for SetACL command lines (I think your tool use this). French translation : Administrator=Administrateur Administrators=Administrateurs Last edited by MysTinuX; 10th June 2009 at 01:34. |
10th June 2009, 09:34 | #77 | Link | ||
For instance this pasted to a cmd or bat should work: Code:
@echo off Reg Query "HKLM\SOFTWARE\Wow6432Node" >nul if errorlevel 1 goto 32BIT echo \Registry\Machine\Software\Wow6432Node\Microsoft\DirectShow\Preferred [1 5 8] >> x64.txt regini x64.txt >nul del x64.txt >nul :32BIT echo \Registry\Machine\Software\Microsoft\DirectShow\Preferred [1 5 8] >> x86.txt regini x86.txt >nul del x86.txt >nul Last edited by turbojet; 10th June 2009 at 12:27. |
10th June 2009, 12:56 | #78 | Link |
Changing the ownership of the key is the problem. But I have found the solution for it. By using the SID instead of the localized name.
MPC-HC 2.2.1 |
10th June 2009, 19:09 | #79 | Link |
HD addict
Thank a lot for adding support for the MPC DXVA decoder! Now I've got the same performance -CPU wise- with Media Center on x64 as I have with MPC-HC.
MPC-HC is my default player and a great one, but Windows Media Center with the Mediabrowser plug-in is just a lot slicker and awesomer for browsing through your video collection.
Windows 7 RTM, x64, AMD X2 7750, Amd 780G (IGP ATI 3200), Ati Catalyst 9.6. |
