Old 4th July 2004, 10:26   #621  |  Link
Single
Hi!
I am trying to post e-mail to ogo but reply was "maildir delivery failed: Sorry, the user's maildir has overdrawn his diskspace quota, please try again later."
I am just downloaded reclock v1.4 and found that it has one big disadvantage. There is no more "videocard to use" dialogue. I read "change.log" and read the explanation "why". But you forgot about video mirror mode. I can't no more use reclock with video mirror mode. When i starting video player (light alloy or zoom player) reclock fetches vertical frequency from monitor where overlay is, but I am watching in another monitor (TV) and in this case reclock must sync to monitor where video mirror is and not where video overlay. In other case reclock 1.3 has another side of this issue. If i select secondary video card and than switch secondary display off at "display properties" and will try to whatch movie than reclock will not load or player gives an error. I think there will be great to have to choose certain video card and auto mode. The choise must will be!
Thank you.
Single is offline   Reply With Quote
Old 13th July 2004, 09:30   #622  |  Link
jfma
ReClock and AX10Ai (or 59TXi)
I've got a Pioneer VSA-AX10Ai (which is the European equivalent to the 59TXi in the States). It has a USB interface that works perfectly with my PC. But when I use ReClock there is no sound at all !!
I'm not quite sure why this happens. If I have understood correctly, what ReClock does is slightly modify the sound sampling frequency, so the problem might be that my Pioneer only synchs when sampling freq is exactly 44.1 or 48KHz. Am I right? Does this happen with other USB soundcards?
Please, help!! I posted this question at avsforum but nobody answered.
jfma is offline   Reply With Quote
Old 18th July 2004, 20:26   #623  |  Link
QQ
Hey,
Sorry if I missed something, but I have a problem.. My LCD is running at 60hz (or so it says), and I can't change it. And most of my movies are running at 25/23.9xx/24 FPS, so ReClock says it can't sync them.. Is there anything I could do?
QQ is offline   Reply With Quote
Old 20th July 2004, 10:58   #624  |  Link
QQ
Hmm, any ideas? :?
Old 20th July 2004, 13:10   #625  |  Link
jfma
There's nothing that ReClock can do unless you can change the LCD's refresh rate to a multiple of the movies frame rate.
If you check "enable guessing a better media speed when hardware refresh rate do not match" (that's on the Video Settings section of ReClock Configuration) ReClock will play at 24fps on a 60Hz display (see the Read me First document). But you won't have the best results unless you change your LCD's refresh rate.
Old 13th September 2004, 12:59   #626  |  Link
Cyberace
Originally posted by ogo @Cyberace:
i'm not against giving you the source code of reclock to understand how it works, provided you don't give away the source code.[/B]
Originally posted by Cyberace @ogo:
Hi Ogo, that would be great as it's more than worth a good look I promise I will only share it internaly to the the Teams developers working on the issue and only for guideline/idea use, please e-mail it to me (link) or upload it here (link)
PS! a few team devs have mentioned ideas about a implementing DirectShow framework for XBMC
Hi Ogo, we're still waiting patiently for the source code (still haven't received them, maybe you forgot? )
Hi Ogo, are you still alive?, we're still waiting for that source code you promised
...FYI, we have already started working from scratch on a brand new player-core and would like really like to have a look at your code, now more than ever
Cyberace is offline   Reply With Quote
Old 25th September 2004, 00:16   #627  |  Link
Trucci
Uninstall problems
Ogo, when I uninstall Reclock, Windows Media Player has an error everytime I start it up. Then there is this blue box thingie that appears in the tray. When I reinstall Reclock, everything works again. I am using Windows Media Player 10.
Trucci is offline   Reply With Quote
Old 25th September 2004, 00:42   #628  |  Link
Trucci
No wait, I just uninstalled the Nimo codec pack and all is well.
Old 4th August 2005, 15:31   #629  |  Link
oddball
ReClock crashes playback on MKV. What gives? I tried 1.4 and 1.5 beta 8
oddball is offline   Reply With Quote
Old 4th August 2005, 15:34   #630  |  Link
oddball
Has anyone got a contact for Ogo? His website is not responding.
Old 5th August 2005, 07:36   #631  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Well, his website moved to http://reclock.free.fr/ , but it's not been updated in ages, and his last post in his support forum is from the end of march...
Leak is offline   Reply With Quote
Old 5th August 2005, 09:30   #632  |  Link
Cyberace
Ogo seems to be active in the avsforum.com forums, though I didn't get a reply
Old 5th August 2005, 17:15   #633  |  Link
Leak
Leak's Avatar
Well, his last post there is from November 2004 - that really doesn't look active to me; more like he dropped off the face of the planet...
np: DJ Shadow - Best Foot Forward (Endtroducing Deluxe Edition (Disc 1))
Old 12th September 2005, 11:15   #634  |  Link
Cyberace
@Ogo, are you still alive?!!
Old 23rd December 2005, 05:59   #635  |  Link
GrofLuigi
Member of a Library
Apparently, he is.
There is a new version on his ReClock DirectShow Filter page.
GL
GrofLuigi is offline   Reply With Quote
Old 23rd December 2005, 12:01   #636  |  Link
kallekill
Anyone knows if the timestretching option still degrades sound quality if you choose do resampling with hardware?
kallekill is offline   Reply With Quote
Old 23rd December 2005, 12:38   #637  |  Link
Cyberace
Apparently, he is.
still no source code in sight though ..seams he gone out of his way now to remove (or rather 'work around') the GPL licensed code he is using in ReClock ...however technically as his on binaries/releases still contain (and allways will contain) he is required to release the full source code of those binaries/releases as per the GPL
Old 31st January 2006, 10:41   #638  |  Link
clehner
What do you mean? The quality depends on the resampling quality of your sound card.
http://www.kino-pc.de
clehner is offline   Reply With Quote
Old 31st January 2006, 12:40   #639  |  Link
videomixer9
ffdshow fan
besides some other things reclock doesn't really do anything for me, if something starts choking on things the video gets even more fucked up instead of being unharmed. Very mysterious the effect that marking a dozen media files in explorer makes it hang the video completly.
videomixer9 is offline   Reply With Quote
Old 31st January 2006, 14:11   #640  |  Link
Lil' Jer
What are you talking about? The GPL code is included in the binaries...
Lil' Jer is offline   Reply With Quote
