Old 26th September 2015, 09:42   #21  |  Link
Sharc
@hydra3333
Out of curiosity, may I ask you whether you have been successful with the interpolation of your clip. If so, which method/tool did you choose?
Old 26th September 2015, 15:45   #22  |  Link
hydra3333
Hello and not successful, no. It was too far gone for anything I could throw at it to make it better. I lived with this (it may be wrong, but it did something).
SeparateFields()
Deblock().deblock().deblock().deblock()
Deblock_QED() #default quant1=24
#SmoothD2(quant=4, qtype=4, num_shift=3, ncpu=4)
#SmoothD2c(quant=4, qtype=4, num_shift=3, ncpu=4)
Weave()
AssumeTFF()
# For RE-INTERLACING http://forum.doom9.org/showthread.ph...41#post1110741
#    AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave() -> TFF
#  AssumeBFF().SeparateFields().SelectEvery(4, 0, 3).Weave() -> BFF
#    AssumeTFF().SeparateFields().SelectEvery(4, 1, 2).Weave() -> BFF
#    AssumeBFF().SeparateFields().SelectEvery(4, 1, 2).Weave() -> TFF
QTGMC(Preset="Slow",EdiThreads=8,Sharpness=1.2,SLMode=1) # result is double framerate progressive, so re-interlate it later
AddGrainC(var=2.0, uvar=0.5, hcorr=0.0, vcorr=0.0, seed=-1, constant=false, sse2=true)
Spline36resize(720,576)
LimitedSharpenFaster(smode=4,strength=100)
AssumeTFF()
Blur(0,0.25).SeparateFields().SelectEvery(4,0,3).Weave() #reinterlace - ASSUMED TFF HERE # BLUR(0,1) per http://forum.doom9.org/showthread.ph...08#post1488308
edit: oh, did you mean Interframe ? Yes, that worked.
Old 26th September 2015, 17:59   #23  |  Link
Music Fan
This script contains resize but no crop while you wanted to crop, are you sure you didn't forget it ?
Music Fan is offline   Reply With Quote
Old 27th September 2015, 10:32   #24  |  Link
hydra3333
Thank you. It's a snippet of the script.
Old 27th September 2015, 20:29   #25  |  Link
Sharc
@hydra
I found it better to resize before adding the grain.
Old 28th September 2015, 01:08   #26  |  Link
hydra3333
@hydra
Ah. I should have thought of that. Thanks.
