Old 9th December 2016, 10:03   #1001  |  Link
ShogoXT
Trying to use 1.0.0b1 in regular use in staxrip to see if it can help with some rainbow and dot crawl issues.
How do you use the new channels setting? Wiki only mentions cmode.
ShogoXT is offline   Reply With Quote
Old 9th December 2016, 16:56   #1002  |  Link
Khanattila
Khanattila's Avatar
channels = {"YUV", "Y", "UV", "RGB", "auto"}.
"auto" is "Y" for YUV colour space and "RGB" for RGB color space.
github.com
Khanattila is offline   Reply With Quote
Old 10th December 2016, 07:29   #1003  |  Link
ShogoXT
Fiddling around with it in Staxrip I found a few things.
With default settings and with d=0 (Temp on or off made no difference), there was significant blurring compared to the older 7.7 version.
See here:
http://screenshotcomparison.com/comp...3278/picture:0
Its two sets, first is with 1.0b1 vs 7.7, and second with 1.0b1 vs OFF.
Keep in mind this is after it was upsampled and sharpened (awarpsharp2 and LSFMod) a good bit, so the blurring is actually a bit worse before probably (I cant take a pic without LSFMod because id have to redo how havfunc is loaded to make NNedi3 work)
Also with channels = "YUV", although Staxrip doesnt complain, it makes the preview window only show this:
http://imgur.com/mmjCT8e
EDIT: Tried setting all the basic values to 1, but no effect on reducing blur (a,s, and h. Did d as well to play with it)
Old 12th December 2016, 11:34   #1004  |  Link
tormento
Acid fr0g
tormento's Avatar
I have tested SMDegrain with newer KNLMeansCL on lot of movies during these days.
The final result is an average 3-7% less noise reduction, measured very roughly on bitrate output and visual comparison frame by frame.
Any idea of why? What has changed in newer version that could have so much impact?
Plus: with stable version I can use 8 threads, with beta only 7.
@turment on Telegram
Old 12th December 2016, 15:42   #1005  |  Link
WolframRhodium
Maybe because "wmode" has changed? For v1.0.0-beta.1, you should set it to 0 (Welsch weighting function), which is used in v0.7.7 by default.
WolframRhodium is offline   Reply With Quote
Old 12th December 2016, 16:20   #1006  |  Link
tormento
Acid fr0g
tormento's Avatar
Uh... is there any doc for newer version? I found nothing in the release zip file, only a changelog on github.
Old 12th December 2016, 17:37   #1007  |  Link
Khanattila
Khanattila's Avatar
v1.0.0-beta.2 will be well documented.
github.com
Old 12th December 2016, 17:39   #1008  |  Link
WolframRhodium
I'm also looking for official document for new version...
Update: oh the next version will be documented, that's great!
Old 12th December 2016, 23:07   #1009  |  Link
Khanattila
Khanattila's Avatar
I have to finish to update the wiki
github.com
Old 13th December 2016, 01:16   #1010  |  Link
WolframRhodium
That wiki helps me a lot, thank you.
Anyway, isn't the default value of "wmode" is 1(DFT_WMODE)? The wiki says by default the value is 0. And there are 3 kind of Bisquare weighting function but the wiki just mention 2.
Old 13th December 2016, 09:24   #1011  |  Link
dipje
Easiest is to say, that while the 1.0 branch is in 'beta' the doc and wiki will be outdated or have a chance to be incorrect. It's a beta for a reason, a quick release to find problems, not to have a complete finished and documented release :P.
Then again, there are a lot of plugins and products around here that never leave the beta phase so. mweh .
dipje is offline   Reply With Quote
Old 13th December 2016, 13:33   #1012  |  Link
tormento
Acid fr0g
tormento's Avatar
A beta can't be really tested until parameters are known
Old 13th December 2016, 16:27   #1013  |  Link
Khanattila
Khanattila's Avatar
Done.
github.com
Old 13th December 2016, 17:40   #1014  |  Link
tormento
Acid fr0g
tormento's Avatar
Great. Thanks.
Old 14th December 2016, 10:36   #1015  |  Link
tormento
Acid fr0g
tormento's Avatar
It seems it is the default value for both releases.
So, I dunno why output bitrate changed.
Old 14th December 2016, 10:44   #1016  |  Link
WolframRhodium
I just read the source code and perhaps I made a mistake.
The update log mentions "Improved de-noising quality around image edge." Maybe that's the reason?
Update:
I have made another test of v1.0.0-beta.1 on vapoursynth just now.
Yes, the default value of "wmode" is 1 for both version, but in v0.7.7, it indicates "Welsch weighting function", while in v1.0.0-beta.1, it indicates "Modified Bisquare weighting function", so what I have suggested you before to set it to 0 for v1.0.0-beta.1 is to return to use "Welsch weighting function".
I'm sorry for my poor English expression. I'm not a native English speaker.
Old 14th December 2016, 11:58   #1017  |  Link
Khanattila
Khanattila's Avatar
Update:
There were several problems in the release of v1.0.0-beta1, so before I make other changes I release beta2.
https://github.com/Khanattila/KNLMea.../v1.0.0-beta.2
github.com
Old 14th December 2016, 12:33   #1018  |  Link
tormento
Acid fr0g
tormento's Avatar
Nope. Welsch is the default wmode with both even with different wmode numbers, i.e. 1 for 0.7.7 and 0 for 1.0.
Different noise treatment should be somewhere else. Khanattila, can you please tell us what is under the hood?
Old 14th December 2016, 12:40   #1019  |  Link
WolframRhodium
khanattila just pushed the last commit of v1.0.0-beta.2, which is "Change default value of wmode" (https://github.com/Khanattila/KNLMea...573bd0e5ccedf1)
Old 14th December 2016, 13:08   #1020  |  Link
Khanattila
Khanattila's Avatar
v0.7.7 wmode=1 -> Welsch
v1.0.0 beta1 wmode=1 (my fault) -> Bisquare
v1.0.0 beta2 wmode=0 -> Welsch
github.com
