Old 5th June 2016, 14:07   #1  |  Link
Livesms
Livesms's Avatar
25i vs 50p (QTGMC) with x264 at the same bitrate
Got 25fps interlaced source (DVB, TV show).
What is better way to encode it with x264 at the same bitrate
- leave interlaced and encode with --tff option
- deinterlace with QTGMC with double frame rate (50fps progressive) and encode as progressive at the same bitrate as planned for 25i source ?
Did some short test. Took a part (6000 frames, 720*576, DAR 16:9, 25 fps), encoded with x264 as interlaced (--tff) at 1150 kbps. Did the same encode at 1150 kbps but after deinterlacing (QTGMC - Slower).
Put both output files through Avisynth Compare (PSNR)
Compare( orig_video.QTGMC(), video25i.QTGMC(), "", "25i")
Compare( orig_video.QTGMC(), video50p, "", "50p")
and got
Overall PSNR: 40.9617 for 25i (then deintelaced and compared to deinterlaced original) and
Overall PSNR: 41.0287 for 25p (compared to deinterlaced original)...
Doubling framerate do not lead to quality loss at the same bitrate ?
Livesms is offline   Reply With Quote
Old 5th June 2016, 16:14   #2  |  Link
Motenai Yoda
Motenai Yoda's Avatar
1- interlaced encoding usually is more efficient than encoding interlaced content as progressive, but it's still less efficient than encoding progressive content as progressive;
2- qtgmc include a denoiser, you can try with its losselss mode;
3- doubling framerate usually give almost identical couples of frames so don't take so much bitrate.
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 5th June 2016, 16:18   #3  |  Link
Livesms
Livesms's Avatar
1. I'm talking about encoding progressive as progressive (50p) and interlaced video as interlaced (--tff option for x264).
2. denoiser included with QTGMC enabled by default ?
3. Yes, deinterlacing with doubling framerate produce 2 almost indetial frames (with minimum difference) instead of 1 frame (interlaced with 2 fields).
Old 5th June 2016, 18:06   #4  |  Link
Motenai Yoda
qtgmc has a lot of stuff in it, you can find all about in the docs under Source Match / Lossless and Noise Bypass / Denoising
http://avisynth.nl/index.php/QTGMC
Old 6th June 2016, 10:59   #5  |  Link
Livesms
Livesms's Avatar
Thanks. Tried to use denoise with QTGMC and got an error with dfttest.dll (will ask in QTGMC thread)
One more question - is there any avisynth plugin to provide comparing of two video as from visual quality (how similiar it looks to original in fact, not in ephemeral PSNR) ?
Old 8th June 2016, 23:06   #6  |  Link
benwaggoner
In general, with a similarly good deinterlacer, native 25i encoding will provide better quality at a given bitrate than native 50p encode. The main advantage of encoding as deinterlaced is so that a particularly good offline deinterlacer can be used, and there is no dependence on the playback hardware having a good deinterlacer.
Still, there will certainly be content/bitrate combinations where 25i with a bad post-decoder deinterlacer will outperform 50p with a good pre-encode deinterlacer.
IIRC, in VC-1 we found a 20% advantage for 25i v. 50p in this case. It likely would be somewhat more for H.264 due to the availability of MBAFF.
Ben Waggoner
My Compression Book
Old 9th June 2016, 18:35   #7  |  Link
Motenai Yoda
sure I can't get access to the high pro test clip and encoders of yours but, I made a quick test with parkrun_ter, with
assumetff()
qtgmc(SourceMatch=3, Lossless=2,NoiseProcess=1, NoiseRestore=1.0, Sigma=2.0 )
and only assumetff()
codec settings
"%~dp0avs4x26x.exe" -L "%~dp0x264.exe" --pass 1 -B 6000 --preset slow -o NUL %1
"%~dp0avs4x26x.exe" -L "%~dp0x264.exe" --pass 2 -B 6000 --preset slow --ssim --psnr -o %1_qtgmc.mp4 %1
"%~dp0avs4x26x.exe" -L "%~dp0x264.exe" --pass 1 -B 6000 --tff --preset slow -o NUL %1
"%~dp0avs4x26x.exe" -L "%~dp0x264.exe" --pass 2 -B 6000 --tff --preset slow --ssim --psnr -o %1_interlaced.mp4 %1
ssim is calculated with ssim() for both, psnr is the one x264 calculated
results are
interlaced ssim 77.32887 psnr 36.083
qtgmc ssim 81.72833 psnr 37.444
Old 13th June 2016, 20:45   #8  |  Link
Livesms
Livesms's Avatar
All in all... got tons of DVB video - MPEG-2 (PAL), 720*576 (16:9), 25 FPS, Interlaced (TFF), ~3100 kbps
Need to reencode all video to free some space. Decided to reencode with x264 for 0.10 bit per pixel (~ 1100 kbps).
What way is better - reencode with x264 as interlaced or deinterlace it to progressive (50 fps) and reencode as progressive (50 fps) as the same 1100 kbps...
Old 14th June 2016, 06:36   #9  |  Link
benwaggoner
results are
I would expect that as fps goes up, SSIM and PSNR values that correlate with a given perceptual quality would go down.
There's probably no short cut to doing a visual comparison for this.
Ben Waggoner
My Compression Book
Old 15th June 2016, 12:24   #10  |  Link
Motenai Yoda
I've done another comparison with all four ldv's 576i25 sequencies
while x264 preserve deinterlaced one's "structure" better, combed parts seems to force it to mantain fine details/high frequencies (or generate some sort of grain).
https://www.sendspace.com/file/616xsx
likely with further high bitrate 25i will outcome 50p even on the structure
25i, 50p, interlaced, x264
