Old 4th May 2015, 02:16   #41  |  Link
real.finder
new version in 2nd post, probability it will be the last (at least for this period)
in the last ver. many changes done
precision=4 is recommended instead of 3 in most cases, in old noisy telecined source (like VHS) you can use something like this if there combed frames especially in the still frames like where the only mouth is move
TComb(othreshL=4) #Dot Crawl and Rainbow remove will help a lot here (even if you did not notes Dot Crawl and Rainbow in the source)
AnimeIVTC(1,0,4,mi=50,blockx=8,blocky=8,tfmm=0,autoAssuf=true,o3025cfr=true).TDecimate(1,chroma=false) #o3025cfr here to not Decimate because we have to do it externally
and this ver. http://forum.doom9.org/showpost.php?...9&postcount=48 may help too
and you may convert scan order to make IVTC filters work correctly
sourcford = getparity() ? 1 : 0
originField = SeparateFields()
newoFields = originField.Trim(1,0)+blankclip(originField,length=1)
sourcford == 1 ? newoFields.Weave().AssumeBFF : newoFields.Weave().AssumeTFF
AnimeIVTC(1,0,4,mi=50,blockx=8,blocky=8)
this will add audio delay (-16) in NTSC source and -20 in PAL source
try this method first and then try autoAssuf=true above if it not succeed
edit: I note that mchroma bool in tfm didn't affect on fields matching, Confirmed that through source that has noise in the chroma by converttoy8 and then converttoyuy2 and the tfm work correctly in that scene
and I made this for easy use of the notes above https://pastebin.com/h4ZPnM3Z
My Avisynth Stuff
Old 8th May 2015, 06:28   #42  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Thanks, I gave it a shot on some old Kimagure Orange Road footage and it seems to work quite well. Thanks! Might be worth making that a "noisy=true" preset if that's generally recommended.
Old 9th May 2015, 23:49   #43  |  Link
real.finder
My policy is keep the default settings of the original script
And also there may be a side effects
Anyway, happy that it work for you
My Avisynth Stuff
Old 12th May 2015, 00:37   #44  |  Link
Elegant
I'm trying to provide an extbob (doing my own QTGMC) when using precision=6 but it's demanding that the extbob be YUY2. If I convert it to YUY2 it then complains that the source is not YUY2, is this normal?
Elegant is offline   Reply With Quote
Old 12th May 2015, 13:54   #45  |  Link
real.finder
My Avisynth Stuff
Old 16th May 2015, 00:44   #46  |  Link
sPaCeMoNk3y
Dependencies
I'm sorry to ask, but I'm quite new to user scripts. Are there any dependencies to run the script, because I get an error. If so, where can I find those and is there a decent manual?
sPaCeMoNk3y is offline   Reply With Quote
Old 16th May 2015, 06:02   #47  |  Link
creaothceann
Always post error messages.
creaothceann is offline   Reply With Quote
Old 10th June 2015, 00:14   #48  |  Link
real.finder
upcoming version (for test)
non atm
sample in vertical global motion (Pan) with tfm default settings "AnimeIVTC(1)" http://i.imgur.com/nTiifDn.png
use it like this should be ok AnimeIVTC(1, 0, 4, tfmm=0, micmatching=0, o3025cfr=true).TDecimate(1)
Result http://i.imgur.com/L0Y8kwm.png
Originally Posted by sPaCeMoNk3y View Post
it almost same as original one http://forum.doom9.org/showthread.php?t=138305
and the most change in this mod mentioned in 1st and 2nd posts, and most of them didn't effect plugins Requirements
My Avisynth Stuff
Old 14th June 2015, 04:10   #49  |  Link
real.finder
I do a quick test to avoid bob in Field blended sample
orig = last
nnedi3(-2).srestore(omode=2)
getparity(orig) ? interlaced60or50 : interlaced60or50(bff=true)
ivtc here
and seems that the experiment is successful
since that nnedi3 preserves the original fields, so the srestore will replace blended one with new one that originally made by nnedi3 to complete the frame
My Avisynth Stuff
Old 24th June 2015, 22:08   #50  |  Link
chagomx
Hi, hope somebody can help me.
I have a DVD R2J but I can't get IVTC'it, is a hybrid.
I've used mode=4, omode=2 but as you can know the 4th frame of 24fps segments are duplicated, if I use omode=1 decimates and display the 24fps segments as it should be but the 30fps segments are blended.
I've tried using credconv="mocomp" but it still dispaly blended.
For the opening I've used p1/p2/e1/e2 at omode=2 and everything is fine, but at the episode I can't use the same technique since p1/p2/e1/e2 are limited and I wouldn't set p1...pn/e1...en.
chagomx is offline   Reply With Quote
Old 25th June 2015, 01:19   #51  |  Link
real.finder
if your setting is IVTC only make sure to set precision to 0 or 1 or 4 or 5 and real30p=true
and if you use setting that need bob then don't set cbob to 3 without yadifrepwithtdeint=true or 4
to help you better, post a sample
My Avisynth Stuff
Old 25th June 2015, 16:09   #52  |  Link
chagomx
Hi again, first of all, thank you for the reply. I've tried your suggestion but it didn't work. This is the line i'm using:
AnimeIVTC(mode=1, precision=5, aa=4, dark=0.6, killcomb=1, real30p=true, cbob=3, yadifrepwithtdeint=true)
or
AnimeIVTC(mode=4, omode=1, aa=4, dark=0.6, killcomb=1, real30p=true, cbob=3, yadifrepwithtdeint=true)
Here es the untouched sample (only encoded to x264 for compression):
Sample
Thanks again.
Old 25th June 2015, 18:39   #53  |  Link
real.finder
or
Sample
Thanks again.
I did a quick test in random frames and didn't see what you talk about in AnimeIVTC(mode=1, precision=5, aa=4, dark=0.6, killcomb=1, real30p=true, cbob=3, yadifrepwithtdeint=true)
and the correct way to encode Interlaced in x264 is SeparateFields() in the last of avs script and --interlaced in x264
and I don't recommend killcomb and aa in animeivtc, better use daa3 or daa3mod or even better mcdaa3
and about omode=1, I edit animeivtc http://forum.doom9.org/showpost.php?...9&postcount=48 and add o3025cfr bool
so the output in your case will be 30 (29.970), if you want it in 24 (23.976) use fps converter like http://forum.doom9.org/showthread.php?t=160226 or simply changefps() but will lead to stutter motion
My Avisynth Stuff
Old 27th June 2015, 14:14   #54  |  Link
ChiDragon
ChiDragon's Avatar
Wait, what?
ChiDragon is offline   Reply With Quote
Old 27th June 2015, 20:57   #55  |  Link
real.finder
Originally Posted by ChiDragon View Post
Wait, what?
that how it work for me
edit: look like --interlaced in x264 will be enough
My Avisynth Stuff
Old 30th June 2015, 01:01   #56  |  Link
chagomx
Hi again, sorry for the hyper-delayed reply but I can't deal with this.
You're right, real.finder. I meant that when I output to 24fps, the 30p segments displays jumpy.
Here I uploaded another sample, this time RAW (m2v). I'm using DGIndexNV frameserver:
Sample 2
What I want is to recover progressive frames but with smooth playback, I don't want to set --interlaced at x264.
If there's a good solution (without trim 24/30 segments), any suggestion is welcome
Thank you.
Old 30th June 2015, 04:50   #57  |  Link
real.finder
Sample 2
Thank you.
--interlaced at x264 for encoding sample, Because the previous sample you post it was Progressive but the Content was interlaced
the best solution for your case is vfr (omode=2) 2pass and if you had a problem with it in smooth then use nvfr=true in animeivtc may help
My Avisynth Stuff
Old 6th July 2015, 15:20   #58  |  Link
chagomx
I had to handle it with VFR. If only there was a way to do it with CFR would be great. Thank you.
Old 6th July 2015, 19:04   #59  |  Link
creaothceann
You could use 120000/1001 fps if you have a monitor that can be set to that frequency (or use exactly 120 fps and use ReClock to speed up the video slightly).
Old 7th July 2015, 09:25   #60  |  Link
real.finder
there are vfr to cfr
http://tasvideos.org/forum/viewtopic.php?t=12763
http://forum.doom9.org/showthread.php?t=165045
https://griffeltavla.wordpress.com/2...sing-avisynth/
but you need to do 2 pass before you can use it
My Avisynth Stuff
anime aa, animeivtc, chroma fix, deinterlace, mod
