Old 16th April 2011, 20:28   #1  |  Link
Jader Dias
How to render/generate video files?
I created a AVS video but I can't upload it to youtube.
I would have to generate a video file from that script.
How to do that?
Jader Dias is offline   Reply With Quote
Old 16th April 2011, 22:05   #2  |  Link
Mounir
Best way is to use Mediacoder which accept avs scripts you can encode in x264 with it with your cpu or graphic card (cuda) which i advise.
Mounir is offline   Reply With Quote
Old 17th April 2011, 17:15   #3  |  Link
Jader Dias
It worked! Thanks!
Old 19th April 2011, 11:53   #4  |  Link
kypec
User of free A/V tools
kypec's Avatar
Thanks to your post I understand at last why majority of Youtube videos look like crap but please refrain from recommending such awful tools next time, thanks.
kypec is offline   Reply With Quote
Old 20th April 2011, 02:26   #5  |  Link
RedDwarf1
RedDwarf Fan
Mediacoder has some nasty adware stuff in it, I would not want to install it.
RedDwarf1 is offline   Reply With Quote
Old 20th April 2011, 18:14   #6  |  Link
Mounir
mediacoder has the best x264 implementation as far as i know, not sure why you are so angry.I have never spotted an adware with this software, really plus that tool can do everything.
In the same vein there is avidemux.
Old 21st April 2011, 09:36   #7  |  Link
kypec
kypec's Avatar
mediacoder has the best x264 implementation as far as i know,...
Yet you advised to use CUDA encoding in Mediacoder?
I'm curious as to how those two things come together in your mind because they basically contradict each other:
x264 stands for HIGHEST POSSIBLE QUALITY encode there is
CUDA stands for SPEED (though it can be beaten by x264 on most modern multicore CPUs easily as well) but certainly not QUALITY encode
renderer
