Old 27th May 2019, 13:05   #56361  |  Link
clsid
Use the debug version. Then you can see what madVR does right before the hang occurs.
Scan your harddrive for bad sectors.
Scan for damaged Windows files.
Old 27th May 2019, 14:18   #56362  |  Link
mclingo
Originally Posted by ttnuagmada View Post
Anyone have any ideas on this? I still cannot figure it out, and this is the only situation that anything like this happens. My computer is otherwise perfectly stable.
I've tried everything I can think of short of re-installing windows.
i had a similar issue a couple of times before, maybe not exactly the same though.
before resorting to a full windows rebuild, have you chucked the full monty at it in one go, rather than doing everything bit by bit?, before you do a full rebuild try this all in one go.
  • Remove NVIDIA driver using DDU and reboot.
  • Remove MADVR completely
  • Remove Lav completely.
  • Reboot again
  • reinstall Nvidia driver.
  • Install MPC-BE and run up a movie just to check all is working ok at this point.
  • install LAV
  • Install MADVR in a !!NEW!! location
  • Switch MPC-BE render to MADVR and try it, leave MADVR at stock settings for now.
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 19.9.2
KODI DS - MAD/LAV 92.14/0.74.1 - 3D / DIRECT3D11 / MADVR 10bit
Old 27th May 2019, 14:38   #56363  |  Link
el Filou
el Filou's Avatar
@ttnuagmada have you tried disabling fullscreen exclusive mode? (I think it's enabled in the default madVR settings)
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 27th May 2019, 14:50   #56364  |  Link
Siso
Siso's Avatar
Since a few releases, it is disabled by default.
Old 28th May 2019, 02:57   #56365  |  Link
ttnuagmada
I have not, but the lockups dont occur at full screen. It happens the second the video is opened in a window. I don't have it set to go fullscreen automatically.
ttnuagmada is offline   Reply With Quote
Old 28th May 2019, 03:01   #56366  |  Link
ttnuagmada
i'll try this when i get home.
Old 28th May 2019, 12:03   #56367  |  Link
njfoses
Nvidia driver 430.86 released.
njfoses is offline   Reply With Quote
Old 28th May 2019, 12:57   #56368  |  Link
veggav
Madvr uses the private nvidia api to enable hdr.
Can someone or madshi show the api?
I want to make a script for other things to enable hdr by command line interface.
@Madshi can you post the API, please?
veggav is offline   Reply With Quote
Old 28th May 2019, 14:26   #56369  |  Link
Alexkral
https://developer.nvidia.com/nvapi
https://developer.nvidia.com/high-dy...ay-development
Alexkral is offline   Reply With Quote
Old 28th May 2019, 15:58   #56370  |  Link
veggav
Thanks, that's what I'm looking for.
The white papers even bring the code ready.
I'm just wondering, the APIs are part of nvidia drivers now? Or those need to be installed?
If I'm getting this right, all I need to do is copy and paste the code to the player and it will trigger HDR.
Also again, much appreciate the help.
Old 28th May 2019, 16:32   #56371  |  Link
Alexkral
No, you don't need to install anything else.
Old 28th May 2019, 17:55   #56372  |  Link
veggav
Great thank you.
Old 29th May 2019, 12:46   #56373  |  Link
chrisssj2
So today I checked. Playing video on my kodi box vs playing with kodi using madvr/dsplayer.
And it seems Kodi on pc is indeed experiencing mini stutters, while my kodi on my media box is 100% fluid.
It's frequent but with spaces of it being fluid aswell. So I was doubting my own eyes.
But it just barely annoyed me, sometimes more then others.
Thus I had to be sure and checked.
I check madvr OSD and there don't seem to be dropped/ repeated frames or presentation glitches.
Yet mini sutter is still present.
Im on 430.39
I had heard this was a thing that happend often to RTX 2080?
Can any RTX user tell me how they eliminated this problem?
For now I am just playing the same movie both on my pc and kodi box at the same time.
Trying to play them back at the exact same time for my ambilight to be correctly timed with the video source coming from android kodi box. to still have 4k HDR Ambilight with the video.(which is impossible for the android box alone I have, which is why I would prefer PC now, but mini stutters..)
chrisssj2 is offline   Reply With Quote
Old 29th May 2019, 13:02   #56374  |  Link
clsid
These settings solve it for most people:
https://forum.doom9.org/showthread.p...70#post1871970
Old 29th May 2019, 19:17   #56375  |  Link
chrisssj2
You mean this?
This is NVIDIA Profle Inspector tool with an optimized profile for MPC-HC/BE.
Download
Most important settings it uses:
Power management mode = Adaptive
VSync = on
GSync = off
SLI = off
Prefer NVIDIA on Optimus systems
Already using those ssettings.
Though I dont see a prefer nvidia on optimus setting.
Anyway these settings make 0 difference appearently.
Old 29th May 2019, 19:36   #56376  |  Link
Daicon
The only option in Kodi to use MADVR with HDR goes through Kodi DSPlayer ???
There is no other?
Daicon is offline   Reply With Quote
Old 29th May 2019, 19:46   #56377  |  Link
Asmodian
Originally Posted by chrisssj2 View Post
Im on 430.39
Isn't this the version with the CPU usage bug? Update.
madVR options explained
Old 29th May 2019, 19:48   #56378  |  Link
this is the version where telemetry can create a huge load on the CPU.
Old 29th May 2019, 19:49   #56379  |  Link
chrisssj2
So which version should I be using?
Old 29th May 2019, 20:01   #56380  |  Link
garson
Hello everyone.
Occasionally I am experiencing stuttering in moving scenes, but no dropped frames or presentation glitches.
How can I track what is causing this?
I enabled full screen exclusive mode, looks like it is helping a bit but still I see it.
Does FSE still makes sense?
I am using madVR v0.92.17 with latest MPC-HC on Windows 10 64 bit.
garson is offline   Reply With Quote
