Old 16th March 2019, 14:30   #55361  |  Link
Tobiwan
Tobiwan's Avatar
I have a question about BT.2020, how did I know that I can use it? Does the monitor need to support BT.2020 or the GPU? Or can everyone use the new BT.2020 and it works?
LG 27MU67-B, i7-7700K, MSI GTX 1080Ti Gaming X, MPC-HC / MPV
Tobiwan is offline   Reply With Quote
Old 16th March 2019, 15:10   #55362  |  Link
tp4tissue
tp4tissue's Avatar
Consumer bt2020 displays do not exist.
What we have now at the highest are dci-p3 displays. If you make 3dluts, make a p3 lut if the gamut of your device is larger than Rec709 (which is more/less the same as SRGB).
Ghetto | 2500k 5Ghz
Old 16th March 2019, 15:26   #55363  |  Link
tp4tissue
tp4tissue's Avatar
@fourbigkids
Pixel shift is usually able to sharpen edges, but may blur certain types of textures, because the shift is an overlap of half a pixel
You'll have to test it to find out if you like what it does.
If you output 4K to 4K that's one step with chroma upscaling
If you output 4K to 1080p, that adds a downscaling step, which may require you to lower the chroma upscaling setting.
Either one may be sharper depending on content and viewing distance.
Upscaling anything lower than 1080p to 1080p is a non-issue.
Ghetto | 2500k 5Ghz
Old 16th March 2019, 15:33   #55364  |  Link
Tobiwan
Tobiwan's Avatar
So if I understand it right it doesn't give me any benefit to set BT.2020 instead of BT.709 for my monitor? I never use 3DLUT or yCMS to calibrate, I always use "already calibrated" with BT.709, PPC and 2.40 gamma.
Old 16th March 2019, 16:51   #55365  |  Link
tp4tissue
tp4tissue's Avatar
In order to set bt2020, the monitor has to have a bt2020 mode, and be operating In that mode.
There are no BT2020 consumer monitors, so that is not an option.
If you do not have a calibrated monitor, pick disable calibration
Ghetto | 2500k 5Ghz
Old 16th March 2019, 17:20   #55366  |  Link
Tobiwan
Tobiwan's Avatar
Thanks tp4tissue!
Old 16th March 2019, 18:16   #55367  |  Link
Manni
This isn't correct.
There are no consumer monitor covering 100% of BT2020, but there are many consumer and monitors and projectors offering a BT2020 mode that covers above rec-709, often up to P3 and for some projectors like the RS4500/Z1 beyond P3.
So there is an advantage to selecting a BT2020 mode in the display/projector, even if the projector is unable to cover BT2020 fully. For example, with my rs2000 that covers close to 100% of P3 with its P3 filter, I benefit a lot from selecting the BT2020 calibration (around 100% of P3 with a P3 filter) or the HDR calibration (around 90% of P3 without filter). Both deliver a significantly larger color volume than the rec-709 calibration, for HDR/SDR WCG content of course.
With madVR, especially if you use 3D LUTs, it's usually better to select a DCI-P3 calibration as it tends to be closer to the actual capability of the display and madVR can simply discard the BT2020 container and deliver P3 which is used to grade the majority of current content, even if it's delivered within a BT2020 container. But with a consumer source you don't have the choice, they either output rec-709 or BT2020 so you have to select one or the other if you want to track the correct saturations.
Win10 Pro x64 b1809 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 398.11 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25PR2
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 16th March 2019, 19:24   #55368  |  Link
el Filou
el Filou's Avatar
Or check "scale chroma separately if it saves performance", which will allow use of better downscaling and/or not compromise on HDR tonemapping quality if you are GPU limited.
HTPC: W10 1809, E7400, 1050 Ti, DVB-C, Denon 2310, Panasonic GT60 | Desktop: W10 1809, 4690K, HD 7870, Dell U2713HM | MediaPortal 1/MPC-HC, LAV Filters, ReClock, madVR
Old 16th March 2019, 19:37   #55369  |  Link
cyberscott
Originally Posted by RXP View Post
Does anyone know if the LG C6 is fine for 12 bit output or should I just leave it at 8 or 10 bit?
I own a LG C6 and I've noticed no additional banding or issues with 12 bit enabled in the Nvidia control panel with madVR. Of course, all equipment has variations so best thing to do is a "stare and compare" with a paused video or better yet a .pgn screen capture with 12 bit on and off.
Even so, madVR's 8 bit processing is excellent so even with 12 bit not enable, you'd be hard pressed to see a difference, I'd think.
cyberscott is offline   Reply With Quote
Old 16th March 2019, 20:50   #55370  |  Link
ryrynz
ryrynz's Avatar
Yeah that's usually the case.. The benefits of using 10/12bit are typically small to non apparent.
Old 16th March 2019, 20:51   #55371  |  Link
tp4tissue
tp4tissue's Avatar
@cybscott
Does it show banding even at rgb 444, 12bit @ 23/24 hz ?
Sometimes it's the sharpening algorithm which screw up 4:2:2 conversion, leading to (banding), but it's not actually banding, it's just bad sharpening.
Ghetto | 2500k 5Ghz
Old 16th March 2019, 21:24   #55372  |  Link
fourbigkids
fourbigkids's Avatar
Thanks @tp4tissue and @el Filou. Looks like I have some testing to do! :-)
fourbigkids is offline   Reply With Quote
Old 16th March 2019, 23:20   #55373  |  Link
cyberscott
@cybscott
For my HTPC set-up, I exclusively use RGB Full, 444 @ 4k. The C6 HDMI input is set to "PC" I have madVR set to use "switch to matching display mode" for 2160p23, 2160p29, 2160p50, and 2160p59. My current video card is a RTX 2080 TI.
Some of the videos I watch have banding already in the source and some with little to no banding in the source. If I look at a scene that has little to no banding, running the Nvidia control panel at 12 bit with the appropriate display mode, it does NOT add any additional banding or video noise that was already part of the source.
I don't typically use any additional sharpening algorithms beyond what is built into NGU-AA, which I use exclusively for my content.
Old 16th March 2019, 23:50   #55374  |  Link
Alexkral
I guess you mean select a DCI-P3 calibration on the screen if it happens to have one, or create it, because otherwise sending DCI-P3 is wrong.
Alexkral is offline   Reply With Quote
Old 17th March 2019, 00:30   #55375  |  Link
Manni
Re-read what I wrote, and that is clearly what I said in the context of my post. Remember we were discussing display modes. I also mentioned the BT2020 container, but maybe that's too technical
Old 17th March 2019, 00:56   #55376  |  Link
j82k
I suggest everyone running their LG Oleds at 12-bit or in PC-mode to check out Rtings 16-bit gradient test pattern played in madVR.
https://www.rtings.com/images/test-m...ent-16-bit.tif
My LG C8 shows noticeable banding, especially visible in the darker green gradient when using either 12-bit or 8/12-bit PC-mode. In 8-bit, non-pc mode it looks fine.
It was the same on my C6 so I don't really understand if something is wrong with my setup or if other people just don't notice the banding.
By the way PC-mode also forces 3:2 pulldown even when outputting 23.976 Hz.
So you get 4:4:4 chroma and lower input lag but you'll also get color banding and forced 3:2 pulldown.
j82k is offline   Reply With Quote
Old 17th March 2019, 01:46   #55377  |  Link
SamuriHL
SamuriHL's Avatar
Yup, that's well known for the C8, unfortunately.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 17th March 2019, 07:47   #55378  |  Link
jmone
So I spent the afternoon trying to get my JVC x7500 working without dropping/repeating frames and I think I've worked it out. The JVC is very picky about what signal it will accept and all the ones offered by madVR outside the normal ones did not work. So I started with the EDID / CTA profile (but it would have a drop/add about 1 per hour) and tweaked that a bit. While madVR's config GUI says this setting will last 7.79 hours, I can confirm it worked perfectly for just under 2 hours. Interestly, is that madVR kept updating the reported display calculation from 23.9758 @ 1 min, to 23.97608 but the end of the movie as well as the expect drop.repeat frames.
jmone is offline   Reply With Quote
Old 17th March 2019, 08:25   #55379  |  Link
arcspin
@jmone
Can you please tell us what you did to tweak your settings.
I'm in a similar situation and would very much appreciate some guidance.
I have read the tutorial found here:
http://madvr.com/crt/CustomResTutorial.html
Is it something similar you did?
Best regards
arcspin is offline   Reply With Quote
Old 17th March 2019, 12:01   #55380  |  Link
jmone
@arcspin, yes that is the correct tut but I then manually changed the values as per the 1st pic (just type them in then press "test mode" to see if they work for you).
