Old 20th October 2018, 00:49   #53361  |  Link
SamuriHL
SamuriHL's Avatar
Yea, that would be accurate, at least paired with my 3770k. I don't know if having a faster CPU would make any difference or not. I doubt it. If you want all the bells and whistles, though, a 1070 would be a better choice. Then again, at this point I'd not buy anything but a 20x0. I suspect in the future those tensor cores will prove useful.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 20th October 2018, 02:43   #53362  |  Link
Tpain145
Hi, I want to know if a gtx 1070 ti can do the fallowing in madvr. I find it much cheaper than a gtx 1080. Can someone please try these settings and let me know the rendering times for 1080p@25,1080p@60, 720p@25,720p@60, 480p@25, 480p@60.
Scaling
1080p@25--4k
chroma upscaling== Sharp high
Image downscaling== SSIM ID Strenth 100%
scale linear light check
activate anti-ringing filter relaxed check
activate anti-bloating filter check
Image Upscaling Processing
algorighm quality: Artifact Removal:
Luma doubling: Sharp very high Reduce banding artifacts:
Luma Quadrupling: Sharp high default banding strength: Low
Chroma: Sharp high Strength during fade in and out: High
activate doubling/quadrupling
Doubling: only if scaling is 1.2x (or bigger)
Quadrupling: Only if scaling is 2.4x (or bigger)
If any (more) scaling needs to be done:
Upscaling algo: Jinc AR
Downscaling algo: SSIM ID100 AR
Upscaling refinement:
Enhance Detail 2.3
Soften edges 2
Add grain 3
SuperRes 3
Rendering: ?
1080p@60--4k Processing
Artifact Removal:
Image Upscaling
algorighm quality:
Chroma: Sharp high
Enhance Detail 2.3
Soften edges 2
Add grain 3
SuperRes 3
Rendering: ?
720p@25--4k Processing
chroma upscaling== Anti-Alias high Artifact Removal:
Image downscaling== SSIM ID Strenth 100% default banding strength: Low
scale linear light check Strength during fade in and out: High
Image Upscaling
algorighm quality:
Luma doubling: Sharp high
Chroma: Sharp high
Enhance Detail 2.3
Soften edges 2
Add grain 3
SuperRes 3
Rendering: ?
720p@60--4k Processing
Image Upscaling
algorighm quality:
Chroma: Sharp high
Enhance Detail 2.3
Soften edges 2
Add grain 3
SuperRes 3
Rendering: ?
480p@25--4k Processing
chroma upscaling== Anti-Alias,very high Artifact Removal:
activate anti-bloating filter check Reduce compression artifacts: Check
Strength: 8, quality: High
Image Upscaling Activate only if it comes for free (as part of NGU sharp): Check
algorighm quality: Reduce random noise: Check
Luma doubling: Sharp very high Strength: 1
Luma Quadrupling: Sharp very high
Chroma: Sharp very high
Enhance Detail 2.1
Soften edges 3
Add grain 1
SuperRes 3
Rendering: ?
480p@60--4k Processing
Image downscaling== SSIM ID Strength 100% default banding strength: Low
Strength: 12, quality: medium
algorighm quality: Strength: 1
Enhance Detail 1.3
Soften edges 3
Add grain 2
SuperRes 3
Rendering: ?
Tpain145 is offline   Reply With Quote
Old 20th October 2018, 16:29   #53363  |  Link
Warner306
@1080P24 -> 4K
Maybe, if you lowered chroma upscaling to low and got rid of SuperRes. SuperRes doesn't work well with NGU, anyways.
@1080P60 -> 4K
Not a chance if you want to use NGU very high image upscaling.
@720P24 -> 4K
Seems likely if you stick to NGU high upscaling and lower chroma upscaling to low or medium.
@720P60 -> 4K
The same settings as above could work.
@480P24 -> 4K
It would work if you lowered chroma upscaling to medium or high.
@480P60 -> 4K
You might have to lower image upscaling to NGU high.
Old 20th October 2018, 19:18   #53364  |  Link
Tpain145
@1080P24 -> 4K
@1080P60 -> 4K
@720P24 -> 4K
@720P60 -> 4K
@480P24 -> 4K
@480P60 -> 4K
Thank for the reply.
@1080P60 -> 4K
could it work if use image upscaling to NGU high ?.
Old 21st October 2018, 12:35   #53365  |  Link
mrmarioman
mrmarioman's Avatar
Question about 'Tone map HDR using pixel shaders'. Is this setting doing dynamic tone mapping, ala HDR10+?
And which value for peak nits should I use? I have a Sony X900F. Not sure which value should I put. Max nits 10% window? 100%? Real scene peak nits? sustained nits? also, should I use BT.2390?
mrmarioman is offline   Reply With Quote
Old 21st October 2018, 13:42   #53366  |  Link
HDR10+ doesn't do dynamic tone mapping it is providing dynamic meta data.
use the nit option that looks best to you.
Old 21st October 2018, 17:03   #53367  |  Link
madjock
@Tpain145
If the 1070 is all you can afford, you will just have to adapt to what you have.
A lot of these settings are subjective at best, so you may not even need half of them to be as high.
madVR is changing all the time, so various settings HDR wise also affect what you can do with the equipment you have/will have.
Old 21st October 2018, 18:26   #53368  |  Link
jkauff
One thing I've always admired about madshi's work is that madVR will improve rendering quality no matter what graphics hardware you have. I have a 9" tablet that runs Win 8.1 on an Atom chip, and at default settings madVR performs just fine.
A 1070 card upscaling to a 4K display will produce obvious PQ improvements with any level of NGU. The question then becomes, as always, is it worth spending the bucks on a new graphics card for the amount of improvement you're going to get beyond that. Only your eyes (and your wallet) can answer that one.
Old 21st October 2018, 18:54   #53369  |  Link
ABDO
@madshi, is it possible to add (auto white balance algorithm) to madvr, i try many avisynth plugins and scripts for that but The result not good at all, and most tvs can do a lot better than avisynth in this case i don't know why، i also try many profissional video editor but The result are good in some and bad in other, i know that you are too busy but i wish if you think about this great Feature in madvr
edit
or may be we can replace (auto wb) with manual (temperature) and (tint) if it safer
ABDO is offline   Reply With Quote
Old 21st October 2018, 22:21   #53370  |  Link
el Filou
el Filou's Avatar
White balance adjustment of content is a capture/production job, not a rendering job.
If you want to reproduce content with high fidelity you should calibrate your display, not use fake "auto white balance" processing.
HTPC: W10 1809, E7400, 1050 Ti, DVB-C, Denon 2310, Panasonic GT60 | Desktop: W10 1809, 4690K, HD 7870, Dell U2713HM | MediaPortal 1/MPC-HC, LAV Filters, ReClock, madVR
Old 21st October 2018, 23:20   #53371  |  Link
mclingo
Hi, please can someone check something for me, I dont know if this is something ive somehow missed before or i have a problem. Avengers infinity war, i'm seeing ghosted black vertical bars quite thick sometimes right from the start of the movie, they appear to me more pronounced when there is more popping out of the screen, is this normal,have I just missed this?
checked a few other 3D movies I have, nothing but I checked regnorock, that has then as well, sometimes thick sometimes very thin, sometimes not there at all.
Its like the movie isnt centered properly or something, i've check there is no zoom and my aspect ratio is correct, does this with all my players so not software issue I dont think.
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 19.2.2
KODI DS - MAD/LAV 92.14/0.72.2 - FSE / 3D / DIRECT3D11 / 10bit
Old 21st October 2018, 23:51   #53372  |  Link
ABDO
this make sense, i always thinking why madvr did not have auto wb, now i understood that it best to let this job to the display in the first place to make true White balance
thanks @el Filou to explained this.
Old 22nd October 2018, 11:32   #53373  |  Link
aduwind
MADVR preferred OS
Hi MASHDI,
Thank you for your superb work!!
Your preferred OS is Windows 8.1 yet?
Thanks in advance
aduwind is offline   Reply With Quote
Old 22nd October 2018, 13:00   #53374  |  Link
he was very clear that he recommends 8.1 over 10 the last time he did it in this thread is about a month ago.
Old 22nd October 2018, 16:14   #53375  |  Link
aduwind
OK
many thanks.
I'll try it.
Just starting to install in a new SSD.
Old 23rd October 2018, 07:20   #53376  |  Link
Betroz
Is this for real?
Betroz's Avatar
But...the newest build of MadVr works just fine under Windows 10 too.
My HTPC : i5 6600K | nVidia GTX 1080Ti | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 23rd October 2018, 07:32   #53377  |  Link
no one said it doesn't work on 10.
Old 23rd October 2018, 16:46   #53378  |  Link
whitestar999
A small query,does system ram mode(single/dual) & frequency matters for madvr. I have a ryzen 1200+B350mobo(yet to open) & used 1050Ti but no ddr4 ram.I am planning on getting a single stick 4gb 2400mhz ram for now. This system is mainly used for watching 720p/1080p videos connected to a 1080p TV.
whitestar999 is offline   Reply With Quote
Old 23rd October 2018, 17:09   #53379  |  Link
the ram speed shouldn't be important for madVR but 4Gb is asking for troubles this is a close call and depends a lot on how much your OS things it has to use.
Old 23rd October 2018, 17:55   #53380  |  Link
jkauff
4Gb might work fine if all you're doing is playing videos. You didn't say what OS you're using, but you'll want to look at the minimum requirements for the OS and how much RAM your video player uses. If you have an SSD, virtual memory won't be terribly slow if the OS needs to use it. Anti-virus programs can be major memory hogs, as can the Chrome browser if you keep a lot of tabs open, so factor in any other programs you'll be running on the machine.
You're going to want 8Gb eventually, but hopefully RAM prices will have come down by then.
