Old 4th June 2016, 06:38   #38241  |  Link
Dlget
In debug mode log size increases as more time madVR runs.
But this memory leak seems to occur after long time of playback.
& with that time log will become like 4-5GB???
should i just run video for 5min & post log?
Win 7 Ultimate x64
Core i5 2500K 4.2Ghz,Asus p8z68 v pro gen 3
Corsair 2x4GB DDR3 @1600Mhz
Asus Gtx 960 strix OC
Dlget is offline   Reply With Quote
Old 4th June 2016, 07:18   #38242  |  Link
ryrynz
ryrynz's Avatar
Check it isn't related to your decoders/media player first.
Then check media, certain types of files causing it? reset madVR defaults to see if it isn't a certain setting that's causing it etc.
Then once you narrow it down you can provide specifics on how to reproduce it.
Old 4th June 2016, 10:29   #38243  |  Link
Dlget
I suspect LAV video decoder 0.68.1 with hardware decoder when used for 1080p n above produce these.
Anyway thanks for reply.
Reverting to 0.67 to test if that works fine.(in 0.67 i don't remember having full RAM coz of video playback)
Win 7 Ultimate x64
Old 4th June 2016, 11:03   #38244  |  Link
CHEF-KOCH
madVR + LAVFilters User
CHEF-KOCH's Avatar
@Dlget
You already talked about memory leak so I guess you're right but this not belongs in here.
You need to report this in the official bugtracker. With video example, hardware configuration and your settings.
I would isolate this by trying to disable LAV and see if that happens with internal filters too. If it's only related to LAV you need to open an ticket on LAVFilters. But's impossible to say without any example video.
Edit: Just found this, don't know if it's you.
Edit2: See if DUMo detects newer drivers and try to update them.
CHEF-KOCH is offline   Reply With Quote
Old 4th June 2016, 11:04   #38245  |  Link
nevcairiel
Thousands of people play videos using LAV Video and/or madVR, if there was a memory leak, someone would've noticed.
Its far more likely something specific to your system or setup.
nevcairiel is online now   Reply With Quote
Old 4th June 2016, 18:09   #38246  |  Link
jkauff
Sysinternals has a nice little utility called RAMmap that will show you in real time which programs are using how much memory.
https://technet.microsoft.com/en-us/...ls/rammap.aspx
Old 4th June 2016, 23:56   #38247  |  Link
petran79
I upgraded Motherboard RAM and CPU and now the GPU has issues. Since CPU is better, the Nvidia GTX660 reaches over 90 % load when I enable NNEDI or similar algorithms. With previous CPU I'd get framedrops. As a result after 10-15 minutes I get occasional freezes due to GPU overload, even after I close the media player. I have to restart the system for problem to dissappear. Till I get one of the new and more powerfull GPUs this summer, I'll stick with Jinc
petran79 is offline   Reply With Quote
Old 5th June 2016, 07:38   #38248  |  Link
hiepbg
New deringing artifacts filter + reduce dark halos is too heavy
New settings are great, low noise, sharp image.
New deringing artifacts filter + reduce dark halos is too heavy for my graphic cards (8750M), but without it, everything still great
If i enable deringing artifacts filter, rendering times increase from 18ms to > 40ms with high bitrate 720p video (>10000kbps), and framerate drops quickly.
hiepbg is offline   Reply With Quote
Old 5th June 2016, 17:44   #38249  |  Link
Uoppi
When doing 720p -> 1080p, madVR OSD has started showing Jinc chroma upscaling (on the row after luma) in addition to the Super-XBR chroma upscaling that I've chosen for the profile.
I have no idea why this is happening because previously it's always been SuperXBR chroma only (meaning only one row in the OSD showing chroma instead of two, i.e. for some reason now Jinc chroma is showing up all of a sudden). I haven't changed any settings. My rendering times are screwed up because of this.
Uoppi is offline   Reply With Quote
Old 5th June 2016, 19:16   #38250  |  Link
XTrojan
Does CPU bottleneck the GPU? My GPU Never hits 90% usage before it starts dropping frames. but my CPU never goes above 50% anyway. using software decoder
XTrojan is offline   Reply With Quote
Old 5th June 2016, 21:15   #38251  |  Link
no that is normal.
Old 6th June 2016, 00:09   #38252  |  Link
amayra
Quality Checker
amayra's Avatar
there any way to disable exit fullscreen when i double click with mouse button in exclusive mode ?
I love Doom9
amayra is offline   Reply With Quote
Old 6th June 2016, 00:20   #38253  |  Link
ryrynz
ryrynz's Avatar
That's done in your media player.
Old 6th June 2016, 13:58   #38254  |  Link
strumf666
netflix
Is it possible to use madvr for netflix?
strumf666 is offline   Reply With Quote
Old 6th June 2016, 17:56   #38255  |  Link
Warner306
Maybe when combined with Kodi DSPlayer. Netflix addons exist. I think they have limitations when it comes the resolution and supported audio formats, but these addons will allow you to play Netflix content through Kodi.
DSPlayer is not available for Kodi v17. However, MPC-HC is and it can be used with the new interface, InputStream, which allows the playback of DRM-protected content. There is already an Amazon Instant Video addon that offers seamless playback similar to the Windows native app. Netflix will likely follow.
Kodi v16 allows playback of Netflix content -- but with restrictions, I'm sure. Kodi 17 is the way forward for streaming apps and Kodi. But no native madVR like DSPlayer.
MPC-HC + Kodi. See here for instructions: http://forum.kodi.tv/showthread.php?tid=209596.
Old 7th June 2016, 14:42   #38256  |  Link
chros
chros's Avatar
bug in source decoding matrix and source primaries selections?
I have a FullHD screen with BT.709 colorspace (calibrated with 3DLUT and only the BT.709 entry is filled on the calibration tab of the display).
I just downloaded these LG 4K demos http://forum.doom9.org/showthread.ph...80#post1769080 (Thanks Patrik for posting the links!)
MadVR properly detects the simple HDR ones (not the dolby vision ones), e.g. LG_2_DEMO_4K_O_H_5_Chess.mkv, and uses BT.2020 for both matrix and primaries (and HDR metadata).
Some of them doesn't have any colorspace declaration (e.g. LG_2_DEMO_4K_O_H_2_Dolby Trailer.mkv) and MadVR uses BT.709 (best guess) for primaries and for matrix.
If I hit source decoding matrix toggle, I can only select from these: BT.709 , BT.601 .
If I hit source primaries toggle, I can only select from these: BT.709 , SMPTE C, EBU/PAL .
Shouldn't I able to select the other ones (DCI-P3, BT.2020) as well with both of these options?
If I assign keyboard shortcuts to DCI-P3 and BT.2020 then I can select them as primaries. Though there's no option for the matrix.
One more question: If I'm certain that a source uses BT.2020 (let's say) what source decoding matrix and source primaries should I use on my BT.709 calibrated FHD display? (I guess BT.2020 for source primaries and BT.709 for decoding matrix, but I'm not sure).
Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 7th June 2016, 14:56   #38257  |  Link
Sunspark
There's a strange thing happening that I cannot figure out, I can trigger a bug with a specific certain combination upscaling 1920x1080 to 2048x1152. The render times will be about 5ms for the first minute, and then after that minute it shoots up to 35ms, stays there and starts choking with presentation glitches galore.
There is something very specific tied to the use of ReconSoft with the anti-ringing in Jinc. Broadwell HD Graphics 6000, Windows 7 D3D9 Overlay Exclusive mode.
Bug triggers with this combination-
Chroma: ReconSoft
Image: Jinc AR
Does not trigger on these combinations below-
Chroma: ReconSoft
Image: Jinc (without AR)
Chroma: ReconSoft
Image: Lanczos 3 or 4 AR
Chroma: Mitchell-Netravali AR
Image: Jinc AR
Chroma: Jinc AR
Image: Jinc AR
Old 7th June 2016, 18:38   #38258  |  Link
thermal throttling of the GPU or the GPU get's power capped.
1920x1080 to 2048x1152 with these setting in 5 ms is more than strange with a GPU like that.
Thanks
you should ignore HDR files that are just broken with incorrect infos. correct meta data is key to display them correctly!
it doesn't matter to what your display is calibrated as long as madVR knows that.
so the primaries info should be the primaries of the source no matter the calibration target.
Old 7th June 2016, 18:45   #38259  |  Link
chros
chros's Avatar
As huhhn says, check with e.g. GPU-Z whether your GPU falls back to a lower performance state.
Old 7th June 2016, 19:04   #38260  |  Link
kasper93
MPC-HC Developer
* added workaround for weird crash with latest AMD beta drivers
They released new drivers with fixed DXVA processing (which was acting strange with 16.5.2 and 16.5.3 drivers). Not sure if this was the crash, but if the workaround is somehow hacky you might recheck if it's needed.
kasper93 is offline   Reply With Quote
