Old 20th May 2019, 19:52   #1801  |  Link
aldix
well, okay, but that doesn't answer the question why basically the exact script and the exact same encoding settings that work with avisynth script + simple x264/265 gui do not work with .vpy script.
aldix is offline   Reply With Quote
Old 20th May 2019, 21:33   #1802  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
That's probably a completely different issue.
First of all, try to resolve your obvious x264 crash problem. VapourSynth input can not work, as long as x264 is crashing on you! It would be best to just stick with the vanilla x264.exe that ships with Simple x264/x265 Launcher.
Secondly, encoding from ".vpy" script requires that an up-to-date version VapourSynth is installed on your machine – x264.exe can not read ".vpy" scripts directly, the frames need to be pipe'd via vspipe.exe.
Simple x264/x265 Launcher does that automatically for you. But, if you think that Simple x264/x265 Launcher did not detect VapourSynth even though it is installed, then run x264_launcher.exe with parameter "--console" and…
It is supposed to look like this: https://i.imgur.com/dfyuEwa.png
Old 22nd May 2019, 20:00   #1803  |  Link
aldix
but the same x264 does not crash with an avisynth script, though. i really don't know how more clearly can i put it lol.
Old 22nd May 2019, 20:30   #1804  |  Link
LoRd_MuldeR
Software Developer
If you refuse to systematically track down your problems, one after the other, or if you don't provide the necessary information, then I can not help.
  • If the x264.exe process crashes on you – which it did according to the log you posted earlier – you obviously have a problem with x264. As long as you do not fix that problem, anything else will be futile! Whether the source was pipe'd in from avs2yuv.exe (Avisynth) or from vspipe.exe (VapourSynth) does not matter. And, as said before, the exit code STATUS_ILLEGAL_INSTRUCTION indicates that x264 has crashed because it tried to execute an instruction not supported by your CPU. This means whatever x264.exe you are using was compiled with "optimizations" not compatible with your CPU. Does x264 still crash, if you use the x264.exe that ships with Simple x264/x265 Launcher?
  • If VapourSynth input is not working – which probably is a completely unrelated problem – then the first thing you need to check is whether VapourSynth is installed properly on your system and whether it has been detected correctly. I already told you how to launch x264_launcher.exe with the debug console enabled. So, go check the debug output and see whether VapourSynth has been detected. Or, at the very least, post your debug output!
Old 1st June 2019, 00:12   #1805  |  Link
aldix
indeed, my sincere apologies.
was indeed for some brain-fart reason trying to get the boardwell version of the tmod to work until this very moment. the regular, latest build works issue-free just as the vanilla x264 does.
thank you for your software!
Old 14th July 2019, 20:33   #1806  |  Link
LoRd_MuldeR
Software Developer
Simple x264/x265 Launcher v2.91
https://github.com/lordmulder/Simple...ases/tag/v2.91
Version 2.91 [2019-07-14]
* Updated x265 to version 3.1+2
* Updated build environment to Visual Studio 2019 with Update-1
* Various improvements to Avisynth/VapourSynth detection
Old 16th July 2019, 23:28   #1807  |  Link
RTW47
Rome Total War
RTW47's Avatar
for me Simple x264 Launcher v2.91.1170 (64-bit) is unable to detect 32-bit and 64-bit VapourSynth. (Windows 7 SP1)
At this point only VapourSynth (64-Bit) R46 (non-portable) was installed using this new separate installer for 64-bit. (since R46).
64-bit vapoursynth installation:
C:\Program Files\VapourSynth\
        ├─ core
        ├─ docs
        ├─ pismo
        └─ etc…
yet Simple x264 Launcher tried looking for vspipe.exe and vapoursynth.dll inside non-existing core64 folder:
[Check for VapourSynth support]
VapourSynth thread has been created, please wait...
VapourSynth Dir: C:/Program Files/VapourSynth
VapourSynth EXE: C:/Program Files/VapourSynth/core32/vspipe.exe
VapourSynth DLL: C:/Program Files/VapourSynth/core32/vapoursynth.dll
VapourSynth 32-Bit edition *not* found!
VapourSynth EXE: C:/Program Files/VapourSynth/core64/vspipe.exe
VapourSynth DLL: C:/Program Files/VapourSynth/core64/vapoursynth.dll
VapourSynth 64-Bit edition *not* found!
VapourSynth thread finished.
VapourSynth could not be found -> VapourSynth support disabled!
renaming core to core64, would make detection work for 64-bit vapoursynth, however everything else such as vapoursynth editor would fail by default.
After instaling Python 3.7.4 (32-bit) and VapourSynth (32-bit) R46, now both 32-bit and 64-bit (non-portable) versions of vapoursynth are installed:
32-bit vapoursynth installation:
C:\Program Files (x86)\VapourSynth-32\
       ├─ core
       ├─ docs
       ├─ pismo
       └─ etc…
Simple x264 Launcher now keeps looking elsewhere, but paths are still not correct to detect 32-bit VS and (or) 64-bit VS:
VapourSynth Dir: C:/Program Files (x86)/VapourSynth-32
VapourSynth EXE: C:/Program Files (x86)/VapourSynth-32/core32/vspipe.exe
VapourSynth DLL: C:/Program Files (x86)/VapourSynth-32/core32/vapoursynth.dll
VapourSynth EXE: C:/Program Files (x86)/VapourSynth-32/core64/vspipe.exe
VapourSynth DLL: C:/Program Files (x86)/VapourSynth-32/core64/vapoursynth.dll
that new installer likely changed some folder names etc., since I clearly remember seeing core32 / core64 folders (at least for non-portable vapoursynth).
GOTO:EOF
RTW47 is offline   Reply With Quote
Old 17th July 2019, 22:37   #1808  |  Link
LoRd_MuldeR
Software Developer
It appears there were some significant changes in latest VapourSynth release, which broke "our" detection routines
I will have to look into that, as soon as I have some spare time. This is probably not going to happen before next week, because I am very busy right now and I will be on a trip this weekend...
Old 17th July 2019, 23:24   #1809  |  Link
RTW47
Rome Total War
RTW47's Avatar
I'm not in a hurry, take your time and have a safe journey.
GOTO:EOF
