Old 28th November 2009, 21:39   #241  |  Link
Rodger
Little support/idea from my site, if not already known.
calling "rundll32.exe powrprof.dll,SetSuspendState" within a txt file named as a *.cmd does send the PC into sleeping mode.
A Shutdown / StandBy Option really is neccesary, when encodes take 2-3 hours or even more with "insane" settings.
File Type: zip Ruhezustand.zip (170 Bytes, 33 views)
Rodger is offline   Reply With Quote
Old 2nd December 2009, 14:46   #242  |  Link
reik
first, i like your tool and use it for 1080p rips.
Can you add a small feature please? --> A logfile destination folder..
I would like to have a view on the quants from 1.pass just if the 2.pass has still started.. So i can see, if its worth waiting to complete the 2.pass or to abort and start again with more or less bitrate.
Keep on!
reik
reik is offline   Reply With Quote
Old 3rd December 2009, 18:45   #243  |  Link
turbojet
Sounds good in practice reik and I've been searching for an estimated quality indicator in x264 for awhile now. But I found out ratefactor given from the first pass can be very inaccurate depending on what settings differ between first and second pass. It's better than nothing though. A few months ago I asked an x264 developer about rate factor updates/display during second pass for an accurate quality estimation. He said it would be added and I'm hopefully waiting for it.
Old 4th December 2009, 00:16   #244  |  Link
henryho_hk
Download link seems broken...
henryho_hk is offline   Reply With Quote
Old 4th December 2009, 00:22   #245  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Works for me
Old 4th December 2009, 07:31   #246  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
Works here also
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 4th December 2009, 08:59   #247  |  Link
egrimisu
egrimisu's Avatar
I ha ve problem, everithing forks fine if using mpegsource or directshowsource or DGDecode_mpeg2source, but when using avisource the x264 launcher freezes at the step "preparing for encode" . However i can suspend it with no problems, or minimeze it.
I7 920 @ 3.60GHz + Thermalright Ultra 120 Extreme
Asus P6T Deluxe, 6GB Corsair XMS3 1600MHZ 8-8-8-24
2x1TB Samsung + 1x500GB Samsung,
Corsair 520W, Thermaltake Soprano DX
GeForge GTX280
egrimisu is offline   Reply With Quote
Old 4th December 2009, 15:01   #248  |  Link
LoRd_MuldeR
Software Developer
Probaply an issue with Avisynth/AVISource or (more liekly) the result of a borked VFW Codec. Try FFmpegSource2 as a replacement for AVISource.
Old 4th December 2009, 19:23   #249  |  Link
yesgrey
There is a typo in the benchmarking text. It appears "Analayzing source file:".
Old 5th December 2009, 11:15   #250  |  Link
LoRd_MuldeR
Software Developer
Thanks, will fix the typo with next release!
Old 5th December 2009, 17:49   #251  |  Link
JoeH
Thanks!
Just a note to thank you for this tool. The interface is nice and I love being able to use the 64-bit for that extra bit of speed!
One feature I'd love to see in future editions is the ability to do a 2-pass encode.
JoeH is offline   Reply With Quote
Old 5th December 2009, 17:55   #252  |  Link
LoRd_MuldeR
Software Developer
Automated 2-Pass already is implemented. Maybe you want batch processing?
Old 6th December 2009, 14:14   #253  |  Link
JoeH
Oooooooooooops! I actually originally wanted to do the the automated two pass with the benchmark and saw it wasn't yet implemented and just figured I couldn't do a simple encode either. But it works great. Batch processing would always be come in handy occasionaly but isn't as essential for me.
Honestly one thing I was thinking would be nice to see that I've never seen in any X264 GUI is some sort of a checkbox to activate / require the different options necessary to make an encoding compatible with a Blu-ray Standalone. I know for example that the --nad-hd (or whatever it's called) needs to be activated, but then there are a couple other things as well like max bitrate and such that are recommended / required.
I always used the MeGUI options for Standalone, but now that those presets are not working properly it is something I need to look into.
Old 7th December 2009, 22:51   #254  |  Link
LoRd_MuldeR
Software Developer
Updated x264 to r1360 (Komisar's builds) and fixed one typo.
Old 8th December 2009, 13:42   #255  |  Link
XadoX
XadoX's Avatar
Oops! (404). Can not download the file.
XadoX is offline   Reply With Quote
Old 8th December 2009, 13:45   #256  |  Link
LoRd_MuldeR
Software Developer
DropBox has disabled public downloads for my account. Too much traffic
Will upload to another mirror, once I get back home...
[EDIT]
Re-uploaded. The download link in the first post has been updated accordingly.
Old 9th December 2009, 08:17   #257  |  Link
egrimisu
egrimisu's Avatar
avisource work jsut great with megui, i believe there is nothing wrong with it
my script look like this:
DGDecode_mpeg2source("d:\misu\nana22\VTS_01_1.d2v")
source1=DGDecode_mpeg2source("d:\misu\nana22\VTS_01_1.d2v").trim(0,38011)
source2=AviSource("D:\Misu\nana22\hfyu_1.avi")
a=source1.animeivtc(mode=1,aa=0,mt=true).assumefps(30000,1001)
b=source2
a+b
GeForge GTX280
Old 9th December 2009, 09:30   #258  |  Link
LoRd_MuldeR
Software Developer
b=source2
a+b
There really is no reason why AVISource should work only in MeGUI, but not in another GUI.
Given that you use the same version of Avisynth and the same source clip...
Old 9th December 2009, 16:53   #259  |  Link
Rodger
I miss the call of the plugin itself in that script....may be the reason
Old 9th December 2009, 19:39   #260  |  Link
deets
and odd situation, when i chose slower, my video stops after a few seconds. no encode error, it just freezes on the first few frame but the time carries on.
if i chose any lower preset, the video encodes just fine.
im using a script created by dgdecnv and a 1080i source from BBC HD.
just wondered if it could be anything obvious?
deets is offline   Reply With Quote
