Old 16th October 2007, 17:19   #81  |  Link
2Bdecided
If it's a total re-write (that's what I feared), I guess I'll use the old workarounds to get the best out of it (i.e. doing both turnright turnleft AND turnleft turnright to give it two stabs at it!).
Of course the other AviSynth resizers are (AFAIK) linear in nature, so working in one dimension then the other, or the opposite, or both together, would all give identical results. That's certainly not the case with EEDI2 and NNEDI, since they're not linear, and not designed to work in both dimensions anyway.
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 16th October 2007, 17:45   #82  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
<stickler>Nearly identical </stickler>
David (a different one)
wonkey_monkey is offline   Reply With Quote
Old 18th October 2007, 11:17   #83  |  Link
Terka
any news about the new version?
Terka is offline   Reply With Quote
Old 18th October 2007, 19:11   #84  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
We finished training a lot of NN's for Tritical, so I assume he is running with those somewhere. He may be a little busy elsewhere with school work and what not, but be happy in the conclusion that steps are being taken in the direction of a new version.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 24th October 2007, 22:37   #85  |  Link
Terka
how to correctly use yadifmod v1?
how to get the :edeint clip: in there?
Old 25th October 2007, 06:48   #86  |  Link
manolito
manolito's Avatar
Try this:
AssumeTFF (or BFF)
interp = nnedi()
yadifmod(edeint=interp)
Cheers
manolito
Old 25th October 2007, 08:30   #87  |  Link
Terka
thank you, ill try; its working fine
Old 26th October 2007, 01:05   #88  |  Link
superuser
thnks will try it out ... :thumbup:
superuser is offline   Reply With Quote
Old 29th October 2007, 07:46   #89  |  Link
yup
Hi manolito!
Advice script for make 50fps from 25fps interlaced source.
AssumeTFF (or BFF)
interp = nnedi()
give 25 fps output.
With kind regards yup.
yup is offline   Reply With Quote
Old 29th October 2007, 09:46   #90  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Read the manuals, they both tell you how to get double-rate output. (Hint: field and mode.) They're not just for decoration!
Old 29th October 2007, 12:39   #91  |  Link
tritical
Don't fear, it is still being worked on . I've just been busy working on some other projects the last week or two. A bit of good news is that I got permission to run the training program on my university's 512 cpu cluster, and I'm doing some test runs as I write this. A new version should be ready in a week or two (no promises though ).
tritical is offline   Reply With Quote
Old 29th October 2007, 22:28   #92  |  Link
Chainmax
Huh?
Chainmax's Avatar
How does one enlarge an image by 2x in both directions using NNEDI v1.3?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 29th October 2007, 23:13   #93  |  Link
Adub
Adub's Avatar
turnright
turnleft?
function nnediresize2x(clip c, bool pY, bool pU, bool pV)
v = c.nnedi(dh=true,Y=pY,U=pU,V=pV).turnleft()
v = v.nnedi(dh=true,Y=pY,U=pU,V=pV).turnright()
return v
Site:Adubvideo
Old 30th October 2007, 00:18   #94  |  Link
Chainmax
Huh?
Chainmax's Avatar
Doesn't that only need to be done with older versions (the ones you had to put PointResize before or something like that)?
Old 30th October 2007, 11:38   #95  |  Link
tritical
That function is correct. With dh=true, nnedi will double the height (without the need to use pointresize before nnedi). So to resize 2x you need to do that for both the width and height... hence the need to rotate.
Old 30th October 2007, 15:59   #96  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Are you sure? The last time I tried it (using it to resize an image then tracing it in Inkscape for further resizing and coloring it with GIMP... ) it also wanted a "field=0" to work...
np: Savath & Savalas - Apnea Obstructiva (Golden Pollen)
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 30th October 2007, 21:38   #97  |  Link
manolito
manolito's Avatar
Yes, this is true. Whenever you specify "dh=true" then "field=0" or "field=1" has to be present, too. "field=-1" does NOT work in this case (contrary to what tritical says).
This is even true if the source only has one field (analog TV capture @720 x 288 PAL).
Cheers
manolito
Old 16th November 2007, 02:15   #98  |  Link
Chainmax
Huh?
Chainmax's Avatar
There is a parameter called 'field' to control which field is kept and double vs same rate output (same as the field parameter in eedi2).
Sorry for my dumbness, but I wanted to update my IVTC/Deinterlacing/Bob lines I have as templates. Does the quote mean that the equivalent to these lines:
Interp = SeparateFields().SelectEven().EEDI2(field=0)
interp = separatefields().eedi2(field=3)
would be these:
Interp = SeparateFields().SelectEven().NNEDI(field=0)
interp = separatefields().NNEDI(field=3)
Old 22nd November 2007, 05:25   #99  |  Link
tritical
@Leak/manolito
Yep, you both are correct. The current error checking requires field=0 or field=1 with dh=true. That's a bug.
@Chainmax
is the same as
Interp = nnedi(field=0)
interp = nnedi(field=3)
Old 26th December 2007, 08:43   #100  |  Link
g_aleph_r
Is there any chance we can see a multithreaded version like eedi2mt? or maybe Cuda enabled?
Pleeeease
g_aleph_r is offline   Reply With Quote
deinterlace, nnedi
