Old 16th September 2007, 00:27   #21  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
@revgen: if you cannot use something else than Paint then just ensure to set the image size to 1x1 pixels via
Image -> Attributes
before pasting an image!
this will avoid the white borders!
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 16th September 2007, 00:30   #22  |  Link
Revgen
Image -> Attributes
I have no idea how to use paint.
I'll do it next time.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 16th September 2007, 00:48   #23  |  Link
tritical
scharfis, I put up a new nnedi.dll at the same location as before. Can you dl it and see if it fixes the problems with sse. The last one I put up always used sse (then compared the results for each routine to the C version) so opt didn't do anything.
tritical is offline   Reply With Quote
Old 16th September 2007, 00:58   #24  |  Link
scharfis_brain
brainless
this version behaves like the original one:
- no debugview output
- opt=1 produces a nice output
- opt=2 produces garbage
btw.: I am working with AVS 2.58
Old 16th September 2007, 01:13   #25  |  Link
tritical
One more time, same link as before. If it still doesn't work I'm out of ideas.
Old 16th September 2007, 04:30   #26  |  Link
scharfis_brain
brainless
Still the same:
(to quote myself)
- opt=2/0 produces garbage
EDIT: I just tested it in Microsoft VirtualPC on a fresh, virgin-like install of WindowsXP.
The result was the same:
- opt=1 OK
- opt=2/0 Garbage
Is it possible, that my CPU is faulty and processes SSE commands in a wrong way?
Are there programs to check for correct execution of commands (or command sets like SSE)?
Old 16th September 2007, 07:04   #27  |  Link
tritical
I don't know of any programs to check correct execution of sse, but I also haven't looked for one. The only thing that makes the findCluster sse routine (which is the only one that doesn't work correctly on your computer) different from the other sse routines is that it uses the 'comiss' instruction. The rest of it is almost exactly the same as one of the other routines which works correctly.
Maybe someone else with an athlon xp can test?
Old 16th September 2007, 08:05   #28  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
same bug with my AthlonXP 1800+
Old 16th September 2007, 10:11   #29  |  Link
tritical
Here are the C/sse routines, maybe someone can see something I can't:
int findCluster_C(const float *input, const float *clusters, const int n)
   int idx;
   float mdiff = FLT_MAX;
   for (int i=0; i<n; ++i)
      float diff = 0.0f;
      for (int j=0; j<100; ++j)
         diff += (input[j]-clusters[j])*(input[j]-clusters[j]);
      if (diff < mdiff)
         mdiff = diff;
         idx = i;
      clusters += 100;
   return idx;
__declspec(align(16)) const float sse_floatmax[4] =
      { FLT_MAX, FLT_MAX, FLT_MAX, FLT_MAX };
int findCluster_SSE(const float *input, const float *clusters, const int n)
   int idx;
   __asm
      xor eax,eax
      mov edx,n
      mov esi,clusters
      movaps xmm7,sse_floatmax
i_loop:
      mov edi,input
      mov ecx,5
      xorps xmm0,xmm0
      xorps xmm1,xmm1
twenty_loop:
      movaps xmm2,[esi]
      movaps xmm3,[esi+16]
      movaps xmm4,[esi+32]
      movaps xmm5,[esi+48]
      movaps xmm6,[esi+64]
      subps xmm2,[edi]
      subps xmm3,[edi+16]
      subps xmm4,[edi+32]
      subps xmm5,[edi+48]
      subps xmm6,[edi+64]
      mulps xmm2,xmm2
      mulps xmm3,xmm3
      mulps xmm4,xmm4
      mulps xmm5,xmm5
      mulps xmm6,xmm6
      addps xmm1,xmm2
      addps xmm3,xmm4
      addps xmm5,xmm6
      addps xmm0,xmm3
      addps xmm1,xmm5
      add esi,80
      add edi,80
      sub ecx,1
      jnz twenty_loop
      addps xmm0,xmm1
      movhlps xmm1,xmm0
      addps xmm0,xmm1
      movaps xmm1,xmm0
      psrlq xmm1,32
      addss xmm0,xmm1
      comiss xmm0,xmm7
      jae check_loop
      movss xmm7,xmm0
      mov idx,eax
check_loop:
      add eax,1
      cmp eax,edx
      jl i_loop
   return idx;
Old 16th September 2007, 13:35   #30  |  Link
ARDA
@tritical
First of all thank for this contribution; in a fast look (didn't analyze code) if I don't remember wrong
psrlq xmm1,32 is a SSE2 instruction not supported in old SSE capables cpus. All xmm instructions in SSE
are just for floating point ones.
I have not my papers here but ALMOST sure about that.
Best regards for this project
ARDA
ARDA is offline   Reply With Quote
Old 16th September 2007, 15:51   #31  |  Link
IanB
Avisynth Developer
Yep, psrlq xmm1,32 is an SSE2 instruction.
A convienient reference is distrib/include/SoftWire/InstructionSet.cpp
One of SHUFPS, UNPCKLPS or UNPCKHPS is probably what you want.
IanB is offline   Reply With Quote
Old 16th September 2007, 16:14   #32  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
I'm loving this filter. It's really fast and does a terrific job when used with yadifmod.
I could'nt ask for more.
Terranigma is offline   Reply With Quote
Old 16th September 2007, 19:17   #33  |  Link
Revgen
Originally Posted by tritical View Post
I bobbed your sample using yadif with nnedi for spatial prediction. Result: test.avi
Oops! Looks like I missed this post.
That's not too bad at all for Yadif. I'll try it out myself later.
Moe: Why?
Old 16th September 2007, 19:35   #34  |  Link
tritical
Thank you ARDA and IanB. I replaced psrlq with shufps. The funny thing is I originally added movaps/psrlq to replace pshufd so that it wouldn't require SSE2.
I put up a new version at the same link as before. scharfis or Fizick, could you test it when you have time?
Old 16th September 2007, 19:46   #35  |  Link
scharfis_brain
brainless
@tritical: it works this way now and it is much faster!
Many thanks!
Old 16th September 2007, 19:54   #36  |  Link
Chainmax
Huh?
Chainmax's Avatar
Revgen, could you try to include TDeint+NNEDI+TMM on your comparison?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 16th September 2007, 20:33   #37  |  Link
Revgen
Hmm... I didn't know about TMM until you mentioned it. I'll try it out as soon as my other encode is finished.
Moe: Why?
Old 17th September 2007, 06:06   #38  |  Link
Revgen
Okay I checked out TDeint+TMM+NNEDI. The good news is that it rivals MVBob (with either EEDI or NNDI in the script) in terms of quality and stability. The bad news is that it's about as slow as MVBob too. And this is with Threads=2 enabled for NNEDI. It doesn't come close to MCBob though, regardless of whether MCBob is using the NNEDI or not.
[Hint]I wonder if Tritical would be interested in adding an Emask parameter to Yadifmod.[/Hint]
It would be nice to see what result we get with Yadif combined with NNEDI and TMM.
Moe: Why?
Old 17th September 2007, 07:35   #39  |  Link
tritical
If you were to going to use tmm/nnedi you would get the same output as using tdeint+tmm+nnedi... there wouldn't be anything for yadif to do. It doesn't matter anyways, because yadif doesn't use a motion mask like tmm outputs. Yadif doesn't make a straight weave or don't weave decision. It starts with the spatial prediction, and then limits that value to be within 'diff' of the weaved prediction (average of pixels from the prev and next fields). 'diff' is calculated from temporal differences and spatial differences.
There is one obvious improvement that can be made to yadif, and that is to slide the temporal window. Right now it is basically a five field check that checks only the middle case... so, for example, it will never output the weaved prediction if the center field (the one being turned into a frame) is within 2 fields (ahead or back) of a scenechange. The only downside is the added computational complexity. Making it check all five cases is on my list of things to do.
Old 17th September 2007, 10:39   #40  |  Link
2Bdecided
Thanks for more toys to play with!
What's the difference, algorithmically, between NNEDI and EEDI2? (Apart from EEDI2 wanting the fields, and NNEDI throwing one field away from a frame?)
Should I stop using EEDI2 and start using pointresize.NNEDI?
Cheers,
David.
2Bdecided is offline   Reply With Quote
deinterlace, nnedi
