#1461 | Link |
Yep, new versions out there: TDeint 1.7 (September 2020) and TIVTC 1.0.22 (August 2020)
Bugfix versions. |
#1462 | Link |
I've mentioned this elsewhere, but tfm's comb-detection algorithms are crap. The cthresh and mthresh have to be set as low as 1 or 2 to detect all combing that is readily visible to the human eye, and yet anything below 7 produces staggeringly high false positives. What are the chances that we'll ever get better comb-detection?
If I ask "How do I do X?" or "what happens if I do X?", and X is a very bad thing that no one would ever normally do, assume that I already know this, and that I have Katie reasons for asking anyway. |
#1464 | Link |
Broadcast Encoder
Donald is right. Besides, Ferenc is the only person who picked up the project and maintained it after it was abandoned by tritical, so he didn't create it and he's not accountable for what you consider a design flaw of an automated solution.
For what it's worth, it's not perfect, but it works and if it wasn't for Ferenc we wouldn't have had it compatible with proper high bit depth... Still, it's an open source project, if you think there are some things that can be done better, anyone can fork it, modify it, test it and open a push request. ![]()
Broadcast Encoder Avisynth memes Videotek - Audacity XP LUT Collection - FFAStrans SafeColorLimiter - AAA |
#1465 | Link |
New TIVTC version: TDeint 1.7 (September 2020) and TIVTC v1.0.23 (20201020)
[TIVTC] RequestLinear: fix: initial "internal error - frame not in cache" |
#1466 | Link |
Broadcast Encoder
Thanks for the update.
#1467 | Link | |
I was working with a problem source a few days ago. TDeint was missing small sections of combing. All it took to fix it was reducing the value for MI and changing the metric used for combing detection. TDeint(mode=1, tryWeave=true, MI=50, metric=1) TFM has the same MI and metric arguments as TDeint. |
#1468 | Link |
Good point H.H.
Also, methinks Metric=0 by default, whereas Metric=1 seems to work betterer ![]()
#1471 | Link |
mt_convolution("1","-1 2 6 2 -1",u=3,v=3) should do it
See My Avisynth Stuff |
#1472 | Link |
I have a question. After using tfm and tdecimate, you've turned a 60 fields/sec interlaced video into 24 FPS progressive video.
Given a frame number within that 24 FPS video, how do you determine which fields were combined to make that given frame? Is there a function I can call to query for the field numbers? Do I need to parse the TFM log file? Do I need to manually match the pixels of the frames? (whoops, this probably belongs in a different thread) Last edited by Dwedit; 6th November 2020 at 01:05. |
#1473 | Link | |
If the internal display=true (p, c, n, b, u) matches and/or debugmode output are not enough info for the field matching step, and display=true not enough for the decimation step, and you want original field numbers - You can explicitly label the field numbers pre field matching (e.g. using stackvertical with blankclip, separatefields(), selecteven/odd and showframenumber (now field number), with top and bottom labels ;exclude those labels from the actual calculations by using the TFM y0,y1 exclusion band parameters. Tdecimate has the clip2 parameter, so you calculate metrics on the input clip (without labels), but display clip2 with the field info for preview purposes. (Of course you don't want to encode the display version with field info, adjust the script for final encode) eg. Code:
orig=MPEG2Source("blah.d2v) origpad = stackvertical(blankclip(orig, height=64), orig) toppad=origpad.assumetff().separatefields().selecteven().showframenumber(x=0, y=20) bottompad=origpad.assumetff().separatefields().selectodd().showframenumber(x=100, y=20) padded=interleave(toppad, bottompad).assumetff().weave() fieldmatchedpad=padded.TFM(pp=0, y0=0, y1=64) origfieldmatched=orig.TFM(pp=0) IVTC = origfieldmatched.TDecimate(clip2=fieldmatchedpad) IVTC So if current frame was 90, but top left says 113, top right says 112, it means IVTCed frame 90 was derived from top field of original frame 113, bottom field of original frame 112 Last edited by poisondeathray; 7th November 2020 at 03:28. |
#1474 | Link |
Okay, a bit more information...
I'm working on a plugin that will detect 60FPS motion (end credits and other moving text) overlayed over 24FPS telecined video. Telecined video has a repeating 2-field, then 3-field sequence. If you are looking for moving text at 60 fields per second, you'd want to look at a 3-field sequence. First and Third field will have an identical background, and only the text should move. This filter would run in conjunction with TFM and TDECIMATE. But in order to figure out whether we are in a 3-field sequence or a 2-field sequence, I'd need to go from Decimated Frame Number to two source Field Numbers, and also know which field number was discarded from a 3-field sequence. Is there any good place to add such a query function? |
#1475 | Link | |
That info is not retained in a filter chain with different plugins or filters. You'd have to modify TFM and TDecimate Is it for a detection plugin only? or is the plugin going to do something about it eg. create mask , or filter it, or something ? What is the end goal or intended purpose? e.g. lets say you detect frames 100-200 have 59.94 overlay motion over 23.976 BG. Now what ? |
#1476 | Link |
the change log seems to say that greyscale supported, but with
source Converttoy8() TFM() ![]()
See My Avisynth Stuff Last edited by real.finder; 14th December 2020 at 04:35. |
#1477 | Link |
Thanks for the report.
Download TIVTC 1.0.24 EDIT: see 1.0.25 later Code:
**v1.0.24 (20201214)** - Fix: TFM: do not give error on greyscale clip
My AviSynth+ repo on github, Other repos: RgTools, Masktools2, MvTools2, TIVTC, Average Last edited by pinterf; 14th December 2020 at 20:26. |
#1478 | Link | |
#1479 | Link |
Yep, that poor TDecimate has 'chroma'=true by default. What a cruel world. Had to mod all other TIVTC filters as well to silently set chroma=false for greyscale clips. Because you could still set chroma=true for them manually. Stay tuned.
#1480 | Link |
Download TIVTC 1.0.25 + TDeint 1.8
** TDeInt v1.8 (20201214) - Fix: TDeint: ignore parameter 'chroma' and treat as false for greyscale input **v1.0.25 (20201214)** - Fix: TFM, TDecimate and others: treat parameter 'chroma' as "false" for greyscale clips **v1.0.24 (20201214)** - Fix: TFM: do not give error on greyscale clip |
tdeint, tivtc |
