Old 7th June 2016, 22:31   #1281  |  Link
bilditup1
bilditup1's Avatar
Here it is built with VC10. You'll need the runtimes for VC2010.
Hmm. appears to be dead now - do you think you could put this up somewhere again, please?
bilditup1 is offline   Reply With Quote
Old 7th June 2016, 23:01   #1282  |  Link
Groucho2004
I added it to my "Avisynth Stuff" thread.
Old 8th June 2016, 01:16   #1283  |  Link
bilditup1
bilditup1's Avatar
Ah, thanks a lot.
Old 11th June 2016, 00:24   #1284  |  Link
Katie Boundary
Katie Boundary's Avatar
The missouri.edu server seems to be down at the moment. Has anyone mirrored the non-VC10 versions of these?
If I ask "How do I do X?" or "what happens if I do X?", and X is a very bad thing that no one would ever normally do, assume that I already know this, and that I have Katie reasons for asking anyway.
Katie Boundary is offline   Reply With Quote
Old 11th June 2016, 00:55   #1285  |  Link
Reel.Deel
http://avisynth.nl/index.php/Externa....26_Decimation
Old 11th June 2016, 01:23   #1286  |  Link
Katie Boundary
Originally Posted by Reel.Deel View Post
"The requested URL /~kes25c/TIVTCv105.zip was not found on this server."
Maybe because that page just has a link to the copy on the missouri.edu server, which is down...
Old 11th June 2016, 01:37   #1287  |  Link
Reel.Deel
Oops, here's the correct link: http://web.archive.org/web/201404201.../TIVTCv105.zip.
Edit: not sure why the archive.org link on the wiki is no longer working, it was when I added it not too long ago.
Edit 2: updated the wiki.
Old 11th June 2016, 05:00   #1288  |  Link
Katie Boundary
Ooh, nice! I shall add it to my regrowing library of tools.
Old 10th January 2017, 05:34   #1289  |  Link
Katie Boundary
I'm confused. This part:
Originally Posted by tritical View Post
TDeint will try either weaving the average of f and i, or simply f or i
...seems to contradict this:
Second, this filter is using a new form of modified ELA interpolation that I have been working on recently. It takes into account the direction of the normal line to the gradient vector when deciding in which direction to average, and attempts to tune the interpolation so that it can adapt to any edge direction within its range.
So... does it average two pixels like linear interpolation, or does it perform wacky edge-detection motion-compensation magic?
Also, how does it handle situations in which neither f nor i looks like what the "target" pixel should be, a common situation in 60hz content, particularly with animated text? YADIF has a spatial interlacing check for this.
EDIT: I performed a side-by-side test with TDeint(mode=1) and YADIF(mode=1), running the Andromeda episode "Ouroboros" through each of them, downscaling to 624x352, and then exporting to an Xvid Full Quality First Pass. File sizes were 739 MB for TDeint and 788 MB for YADIF, indicating that TDeint is quantifiably less "noisy".
Old 21st April 2017, 19:23   #1290  |  Link
pinterf
Hi, after having spent some weeks (didn't know that this would take this much time ) on porting TIVTC to 64-bit (and an SSE2 capable 32 bit version), finally finished the first step of the update.
Download TIVTC 1.0.6 (beta)
32 bit users would also try it, it is faster than the original one, at least or my machine (not to mention the x64 version, which is much faster).
Since all inline asm was rewritten in simd intrinsics or C, along with new SSE2 additions, and none of the old mmx/isse code is running in this version, please don't kill your existing 1.0.5, treat it as a beta, though I was trying to test it until it gave identical results to the (fixed) original code. Feedbacks are welcome.
# TIVTC v1.0.6 (20170421)
This is a modernization effort on tritical's TIVTC (v1.0.5) plugin for Avisynth
**v1.0.6 (20170421) - pinterf**
- project migrated to VS 2015
- AVS 2.6 interface, no Avisynth 2.5.x support
- some fixes
- x64 port and readability: move all inline asm to simd intrinsics or C
- supports and requires SSE2
- MMX and ISSE is not supported, but kept in the source code for reference
- source code cleanups
**v1.0.5 (2008) - tritical**
- see old readmes
Future plans: support additional color spaces, now YV12 and YUY2 is supported
pinterf is offline   Reply With Quote
Old 22nd April 2017, 10:22   #1291  |  Link
DJATOM
DJATOM's Avatar
It seems Tfm can't properly analyse with Prefetch and just skipping frames.
#TFM v1.0.4 by tritical
field = top
crc32 = 5dcb7f8a
4 c - [0]
8 c - [0]
12 c - [0]
16 c - [0]
20 c - [0]
24 c - [0]
28 c - [0]
32 p - [0]
TDecimate mode 1 is not working with Prefetch:
Error requesting frame 1199
TDecimate:  internal error during pre-buffering (n1=1509,n2=1510,pos=0,nbuf.FrameSO=1505,nBuf.frameEO=1510)!
TDecimate mode 5 is slower with Prefetch (I think it's due to Tfm: ~140fps vs ~400fps on my HW).
I didn't checked other modes.
DJATOM is offline   Reply With Quote
Old 22nd April 2017, 11:25   #1292  |  Link
pinterf
Thanks, the MT things did not change in this version, what mt mode is effective for that?
And some scripts would be wecome, there are so many parameters and combinations that I cant figure out the frequent use cases (and since I never had to use this plugin, nor have I experience with it)
Old 22nd April 2017, 11:34   #1293  |  Link
DJATOM
DJATOM's Avatar
The main purpose of MT is fully working chain. TFM/TDec might not benefit from MT, but other filters do. Also about analysing: we should forbid non-sequential access if possible.
Ok, I'll give you my test case after work.
Old 22nd April 2017, 11:59   #1294  |  Link
stax76
stax76's Avatar
Since I'm adding it to staxrip profile suggestions are welcome.
Old 27th April 2017, 00:16   #1295  |  Link
real.finder
TIVTC 1.0.6 is unstable in little complex script with 1080i, it's slower than the 1.0.5 and crash after few seconds
See My Avisynth Stuff
Old 27th April 2017, 07:26   #1296  |  Link
pinterf
How can I reproduce? If it is too complex then effective parameters would help.
Old 27th April 2017, 10:02   #1297  |  Link
real.finder
I see it show this message too https://s14.postimg.org/ohd4vits1/Ne...ript043157.png
a=ColorBarsHD(width=1440, height=1080)
a+a+a
converttoyv12
#~ ThreadRequest()
DecombUCF()
#~ ThreadRequest()
Crop(0, 0, 0, -160).StackVertical(Crop(0, Height()-80, 0, 0)).TDecimate(1,clip2=last)
#~ ThreadRequest()
Spline36Resize(1280, 720)
this not crash but it will crash if I uncomment the ThreadRequest lines (in avs 2.6 ofc)
Old 27th April 2017, 10:49   #1298  |  Link
pinterf
Originally Posted by real.finder View Post
...this not crash but it will crash if I uncomment the ThreadRequest lines (in avs 2.6 ofc)
Thanks. I need only a FrameCache plugin. I can't find the binaries, there is no link in http://avisynth.nl/index.php/External_filters
Old 27th April 2017, 10:54   #1299  |  Link
real.finder
it's in warpsharp.dll
Old 27th April 2017, 11:55   #1300  |  Link
pinterf
Reproduced, but so far it's not TIVTC 1.0.6 specific for me.
It crashes in
avs [error]: Avisynth: access violation at 0x00003CBC in C:\Program Files (x86)\AviSynth\plugins\TDeint.dll
attempting to read from 0x69706D6F
or from AvsMeter:
AviSynth 2.60, build:Feb 20 2015 [03:16:45] (2.6.0.5)
Avisynth: access violation at 0x00003CBC in C:\Program Files (x86)\AviSynth\plugins\TDeint.dll,
attempting to read from 0x00000000
AVS 2.6.0.5
Original TIVTC 1.0.5
TDeint 1.1 (2007) (crash above)
TDeint 1.1 (2012 version - rebuild(?)) (hang)
EDIT: Crashes also without ThreadRequest.
tdeint, tivtc
