Old 29th October 2011, 11:02   #1  |  Link
PTDown
[Help] Audio OOS
Hi folks!
Im tryng encode a .mp4 with 50fps (Digital TV). When i encode to 25fps (PAL) the audio is oos. So i have to use FFMS2, but he does not recognize .aac
Here is the script:
Import("C:\Program Files\AviSynth 2.5\plugins\NAA.avs")
FFIndex("C:\Users\Ricardo Vieira\Desktop\Entrevista\1025205953DVB-TRTP 1_852_1782_0_929.mp4")
AudioDub(FFVideoSource("C:\Users\Ricardo Vieira\Desktop\Entrevista\1025205953DVB-TRTP 1_852_1782_0_929.mp4"),
FFAudioSource("C:\Users\Ricardo Vieira\Desktop\Entrevista\1025205953DVB-TRTP 1_852_1782_0_929.aac"))
nnedi3(field=-2)
SelectEven()
crop( 2, 2, -2, -4)
Spline36Resize(640,480)
NAA()
Error:
SAMPLE: http://dl.dropbox.com/u/30743665/102...0_929_0_30.mp4
Help please.
Best Regards,
PTDown.
PTDown is offline   Reply With Quote
Old 29th October 2011, 20:02   #2  |  Link
cobo
Your script as you've posted it has a line-break in the middle of the audiodub() call, but that wouldn't return the error you're getting, so I assume that is not a problem with the script you're using.
Check to make sure that the .aac file is named exactly the same as in your script and that it's in the location indicated. I think that is the problem, because otherwise your script works without returning an error for me.
cobo is offline   Reply With Quote
Old 29th October 2011, 22:06   #3  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
@PTDown:
You need to rename .aac file different with the .mp4 file, or specify different cache files for each file. EDIT: You don't need to rename as Gavino pointed out. Actually, you don't need to demux audio, FFAudioSource works just fine with mp4 container.
Also, because your video is interlaced H.264, you should add threads=1 to FFVideoSource.
the_weirdo is offline   Reply With Quote
Old 29th October 2011, 22:54   #4  |  Link
Gavino
Avisynth language lover
Why? The cache filename is formed by adding .ffindex to the source name, including the original suffix.
So xxx.mp4 and xxx.aac will create/use distinct cache files.
Old 30th October 2011, 14:05   #5  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
Oops. I forgot about that. I saw his post and thought FFAudioSource was confused the index which created by FFIndex but completely forgot that they have distinct cache files. Now I wonder why he got that error message.
Old 1st November 2011, 00:14   #6  |  Link
vampiredom
Try using MpegAutoIndexSource() -> http://forum.doom9.org/showthread.php?t=162930
You'll need a license for Donald Graft's tools for NV or DiAVC, however, which is required for interlaced MPEG-4 video. The example below assumes you have this and a CUDA-capable video card [NV=true]. Replace this with "DI=true" if you are wish to use DiAVC instead.
MpegAutoIndexSource("1025205953DVB-TRTP 1_852_1782_0_929.mp4", NV=true)
nnedi3(field=-2)
SelectEven()
crop( 2, 2, -2, -4)
NAA()
Audio sync should be fine.
vampiredom is offline   Reply With Quote
aac, audio, audiodub, ffindex, mp4
