Old 16th August 2019, 14:50   #23581  |  Link
manolito
manolito's Avatar
Here is another "not helpful" comment...
If LAV Splitter and FFmpeg based source filters like FFMS2 and LSMASH all are buggy when it comes to opening OGG files then my conclusion is that the OGG format is obsolete or broken enough so that nobody cares to support it. Remux to MKV... (MP4 also works fine.)
Old 16th August 2019, 15:32   #23582  |  Link
LigH
LigH's Avatar
It is possible that the audio track uses the even more ancient Vorbis ACM codec which is not fully compatible to the output of e.g. oggenc2.
New German Gleitz board
Old 16th August 2019, 21:26   #23583  |  Link
filler56789
SuperVirus
filler56789's Avatar
You are correct
https://hardwarebug.org/2010/03/03/ogg-objections/
filler56789 is offline   Reply With Quote
Old 17th August 2019, 15:48   #23584  |  Link
clsid
File plays ok with LAV 0.68.1-4, and got broken by FFmpeg update.
Old 27th August 2019, 14:49   #23585  |  Link
richardpl
Looks like nobody care to open bug report on FFmpeg bug tracker.
richardpl is offline   Reply With Quote
Old 27th August 2019, 16:00   #23586  |  Link
filler56789
SuperVirus
PERHAPS because most people already know there exists a not-very-smart gatekeeper named cehoyos...
Old 29th August 2019, 00:13   #23587  |  Link
Stereodude
Does LAV support Sony's 8-bit (non-standard) HLG mode they implemented in their cameras? The 0.74.1.20 LAV filters baked into MPC-HC 1.8.7 + madVR 0.92.17 don't seem to see it as HDR. It does recognize the BT.2020 or BT.709 color in the MP4 files correctly.
Stereodude is offline   Reply With Quote
Old 29th August 2019, 02:05   #23588  |  Link
madVR doesn't support HLG.
Old 29th August 2019, 18:34   #23589  |  Link
filler56789
SuperVirus
...but I think he deserves to be pestered anyway
New ticket opened @ trac-dot-ffmpeg-dot-org:
http://trac.ffmpeg.org/ticket/8105
Old 30th August 2019, 07:16   #23590  |  Link
LigH
LigH's Avatar
And it already develops ... also into the opposite direction, though, they believe GPAC flagged the stream like MPEG-2 4:2:2 although it is 4:2:0, should have been multiplexed differently. Anyway, it is an "important" entry.
Old 4th September 2019, 06:45   #23591  |  Link
steakhutzeee
steakhutzeee's Avatar
Hello, i use MPC BE with madVR and LAV filters.
Should i disable the internal filters in MPC BE to let LAV Filters work as external filter?
Thanks in advance.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 4th September 2019, 07:03   #23592  |  Link
jkauff
Yes, according to the MPC-BE developers.
Old 4th September 2019, 07:40   #23593  |  Link
ryrynz
ryrynz's Avatar
It's not a requirement for madVR to work however.
Old 4th September 2019, 19:15   #23594  |  Link
steakhutzeee
Strange, because here https://forum.doom9.org/showthread.p...50#post1884050 users told me that i don't have to disable them.
Old 4th September 2019, 22:34   #23595  |  Link
ryrynz
ryrynz's Avatar
You don't have to but maybe LAV can do one or two things with MadVR that the BE internals do not and that was why they suggested it.. Is that still the case though?
Old 4th September 2019, 22:46   #23596  |  Link
steakhutzeee
Well that's why i select lav filters as preferred.
Tried to disable them and in the right click->filters, i see MPC Video/Audio etc.
If i enable them, i see instead LAV Video/Audio/Splitter.
So i think maybe they do that one or two things you mention. I don't know. Or there is more i'm ignoring?
Old 5th September 2019, 18:37   #23597  |  Link
VictorLS
I do so too and uncheck internal filters, namely TS and Matroska, H264 and HEVC (they have more priority in MPC-BE over preferred external filters) to achieve LAV Filters be used at all (as you describe tough).
VictorLS is offline   Reply With Quote
Old 5th September 2019, 19:51   #23598  |  Link
steakhutzeee
Thank you!
But i have noticed that with matroska, the lav filters start just fine. This do not happens to you?
I found matroska in internal filters-> source filters, and HEVC/H264 in internal filters -> video decoder.
Is this the right way i should do this? Anyway i can't find TS.
Old 5th September 2019, 21:17   #23599  |  Link
VictorLS
I'm sorry - I don't understand your question exactly - just want to say I prefer use LAV Filters instead of any other splitters/demultiplexers/sources and decoders for all formats I use - containers TS, MKV, MP4 (forget to mention in previous post) and encoded MPEG2, H264, H265, VPx video so I do setting of Sources as in attach below. Btw it's not need in MPC-BE to uncheck any audeo decoders in internal filters in my case - prefer LAV Audio Decoder enough.
I found matroska in internal filters-> source filters, and HEVC/H264 in internal filters -> video decoder. Is this the right way i should do this?
Yes.
Old 6th September 2019, 06:33   #23600  |  Link
steakhutzeee
Yes.
Sadly the image you attached is still in pending approval. What i was saying is that in MPC BE if i right click and select "Filters" i can see that i'm using LAV with the files you mentioned, with all internal filters active and lav as preferred.
It was a reply to the fact that you said that lav is not chosen correctly even if selected as preferred with those files.
So i was asking if this was not happening to you. To be sure i disabled the internal filters you mentioned anyway.
