Old 11th April 2011, 14:55   #2001  |  Link
Floatingshed
Can any one help with this...
I've been creating .mp4 files with megui containing 1x264 stream and 1xaac stream using autoencode. For weeks all has been well.
Suddenly I find that when I play the mp4's all players report twice the actual duration. Demuxing and remuxing with YAMB fixes this fine.
I'm a bit baffled as megui and yamb both use mp4box to mux. Does anyone know what is going on? Thanks.
Floatingshed is offline   Reply With Quote
Old 11th April 2011, 20:03   #2002  |  Link
Zathor
2006 [MKV Muxer] added support for wav input files. Feature request #3253221
2005 [x264] added option for interlaced modes --tff and --bff. --interlaced has been removed. Bug #3204337
2004 [Audio Encoder] added option to choose the preferred decoder. Feature request #3053195
                     in case the preferred decoder cannot decode the input file the others will be tried, too
                     default order: NicAudio, FFAudioSource, DirectShow
2003 [One-Click] some profile adjustments
Zathor is offline   Reply With Quote
Old 14th April 2011, 19:04   #2003  |  Link
Lighto
The Black Reaper
Lighto's Avatar
There is a GUI bug with the NeroAAC config dialog.
The default constant bit rate value is always at 16 kbit/s until the user selects the constant bit rate radio button or the variable bit rate radio button.
Lighto is offline   Reply With Quote
Old 15th April 2011, 11:04   #2004  |  Link
doc_dvxm
HD Encod3r
Hi there...
I am using the latest development version of meGUI (2006). It crashes when I'm trying to load a .dgi file (properly indexed with activated & licensed DGAVCDecDI & DiAVC). Same script working fine when I am loading it on AvsP. The source is HD .h264.
There is no any problem with FFMS2 indexed and .dga files. Also it works fine with Directshowsource). Is it problem of newest meGUI? Unfortunately, I don't tried with previous version of meGUI. Can't compare. If no, I'll search at neuron2.net.
Thanx in advance...
doc
Specs: Win 7 64 Bit Ultimate + Intel i7 930 3.6 Ghz + 6 Gb RAM + ATI Radeon 5850 + ffdshow + MPC - HC
doc_dvxm is offline   Reply With Quote
Old 17th April 2011, 07:01   #2005  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
Originally Posted by doc_dvxm View Post
Hi there...
Thanx in advance...
doc
Isn't .dgi strictly for use with DGDecodeNV and Nvidia Cuda cards?
Lyle_JP is offline   Reply With Quote
Old 17th April 2011, 16:22   #2006  |  Link
doc_dvxm
HD Encod3r
DGDecodeNV requires NVIDIA Cuda cards. DGAVCDecDI is for all others...
Btw reinstalling of meGUI resolve the problem....
Old 17th April 2011, 20:46   #2007  |  Link
rapscallion
NY Frame of Mind
rapscallion's Avatar
Megui, Misc tab, under V.U.I. there is a box checked for "Force pic_struct" for all the Blu-ray presets.
Is this the same effect as the command line --pic-struct ?
"Talk to me Goose"
rapscallion is offline   Reply With Quote
Old 17th April 2011, 21:59   #2008  |  Link
Zathor
Only two minor fixes:
2008 [Worker] fixed "shut down worker when finished local queue"
              some cosmetics
2007 [Nero AAC Encoder] fixed cosmetic problem with wrong bitrate values in the configuration dialog. Bug #3286672
Old 18th April 2011, 00:51   #2009  |  Link
Lighto
The Black Reaper
Lighto's Avatar
I am pretty sure the command line --pic-struct is added when "Force pic_struct" is checked.
Old 18th April 2011, 01:03   #2010  |  Link
rapscallion
NY Frame of Mind
No, it's not visible in the command line, that's what prompted me to ask.
"Talk to me Goose"
Old 18th April 2011, 02:32   #2011  |  Link
Lighto
The Black Reaper
Lighto's Avatar
Old 18th April 2011, 03:34   #2012  |  Link
rapscallion
NY Frame of Mind
As I stated , Blu-ray presets...not divx, not there :
"Talk to me Goose"
Old 18th April 2011, 12:42   #2013  |  Link
Lighto
The Black Reaper
Lighto's Avatar
It would seems that -tff includes pic-struct in it.
pic-struct
Default: Not Set
Force sending pic_struct in Picture Timing SEI.
Implied when you use --pulldown or --tff/--bff.
Recommendation: Default
Old 18th April 2011, 14:08   #2014  |  Link
rapscallion
NY Frame of Mind
You know, it's funny Lighto, I read that in the MeWiki but didn't interpret that "implied" meant "turned on".
Thanks for the clarification!
"Talk to me Goose"
Old 19th April 2011, 08:08   #2015  |  Link
doc_dvxm
HD Encod3r
My problem with DGAVCDecDI still persist.
Sometimes MeGUI opens properly (I don't know why ??? ), but usually going to crash...
I've switched to the stable server and it update to 1939 (svn), but the result was same. Just like the 2008 (svn) update...
Btw, When I am using same script from the x264 commandline, it working properly...
Now I'm sure that it is a MeGUI problem... Or it is MeGUI - DGDAVCDecodeDI incompatibility ???
What's wrong??
Old 21st April 2011, 09:42   #2016  |  Link
rtjnyoface
Constantly learning
rtjnyoface's Avatar
Opening explorer makes megui freeze
After a couple times (or maybe a certain time frame) of opening explorer to find files, for instance a d2v file in a folder, megui freezes and I have to delete the process and restart it to continue the work. It only recently started happening after I updated from 1998 if I remember correctly. I've seen that it may be due to ffms but that thread I read was like a year ago. Anyone know what might be the issue, had seen the issue, or know if its' one currently being rectified?
Win7 x86
Megui 2008
rtjnyoface is offline   Reply With Quote
Old 22nd April 2011, 10:24   #2017  |  Link
Zathor
2009 [MediaInfo] adjustment for recent mediainfo builds
and 2008 has been released as stable
Old 22nd April 2011, 15:27   #2018  |  Link
MenotBumba
Could you please update x264 to 1937 ?
MenotBumba is offline   Reply With Quote
Old 22nd April 2011, 15:30   #2019  |  Link
Zathor
No, not at the moment. I need to prepare the gui first for the --bluray-compat switch.
Old 23rd April 2011, 13:04   #2020  |  Link
Renzz
There is a slight bug in audio encoding using Nero AAC and using FFAudioSource on the profile. I'm encoding .mpa files to .m4a, and when I try to delete the original .mpa afterwards, Windows tells me it's still in use by Megui. I have to completely close Megui to release it. Note: this only seems to affect the X64 version of Megui - as far as I can see the X32 version correctly closes the file (or at least lets me delete it).
Renzz is offline   Reply With Quote
