Old 12th January 2007, 18:29   #61  |  Link
Eretria-chan
Hmm... well, doesn't it just work to convert it to mkv/mp4 first and then encode it?
Anyhow, good luck. I'll definitely be waiting for an update!
Eretria-chan is offline   Reply With Quote
Old 12th January 2007, 19:05   #62  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Open file dialog is now in english...
Old 12th January 2007, 19:10   #63  |  Link
Sirber
retired developer
Sirber's Avatar
must be coz of my lazarus french version no?
Detritus Software
Sirber is offline   Reply With Quote
Old 12th January 2007, 19:14   #64  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Probably. However the changelog is on detritus.
Old 20th January 2007, 13:30   #65  |  Link
Eretria-chan
Any chance of mkv this time around?
Old 20th January 2007, 15:11   #66  |  Link
Sirber
retired developer
Sirber's Avatar
input or output?
Detritus Software
Old 20th January 2007, 18:40   #67  |  Link
Eretria-chan
Output and input, of course. Does it support mkv input?
A few more things:
- Select output dialog has french text (I assume it is anyway, "una directory").
- Use new XP-style dialog for "Add Files" instead of old, ugly file dialog?
- Recovery for possible I/O error. Select another output location? I just ran into an I/O error at the merging process because I forgot to change output dir and have set no permissions to C:\ to keep apps from saving junk there.
- Maybe change default output directory from C:\ to something else? C:\, at least for me, can be a dangerous directory.
- Recovery, the process of moving on to the next file in the queue if the encoding process fails (can I take it that it's planned?).
EDIT:
Error:
Cannot open destination file F:\Downloads\Temp\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4: I/O Error
I'll tell you, however, that I can perfectly well copy and create files in that directory.
EDIT2: Is the video somehow raw? Mkvmerge can't mux it because it doesn't recognize it.
Old 22nd January 2007, 01:02   #68  |  Link
Sirber
retired developer
Sirber's Avatar
@Eretria-chan
Gonna do a write checkup in output folder. The next file should be encoded in case of error. GOnna recheck the code.
Video is RAW indeed.
Detritus Software
Old 22nd January 2007, 01:05   #69  |  Link
Sirber
retired developer
Sirber's Avatar
new build online. changelog and download on my site.
Detritus Software
Old 22nd January 2007, 23:45   #70  |  Link
Eretria-chan
I'll have a look and do more tests tomorrow then. I'll let you know the results.
Things I noticed right away is that the select output directory still isn't english and version says "Bencos v2007-01-06 loaded," which clearly isn't the case.
More testing tomorrow ^_^
Test 1 - Encode to C: Failed. Reason: Cannot open destination file c:\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4: I/O Error
Test 2 - Encode to F:\Downloads\Temp: Failed. Reason: Cannot open destination file F:\Downloads\Temp\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4: I/O Error
It looks like nothing has changed with this build...
Old 27th January 2007, 16:37   #71  |  Link
Sirber
retired developer
Sirber's Avatar
@Eretria-chan
You can the changelog on my site. Your issues haven't been checked yet. We are focusing our efforts to get rid of the MoFu delay problem:
http://www.detritus.qc.ca/forum/viewtopic.php?id=29
Detritus Software
Old 27th January 2007, 16:46   #72  |  Link
Amnon82
Paldo-GNU/LinuxMaintainer
Amnon82's Avatar
@Siber: when do you think you guys have the first linux version ready?
Amnon82 is offline   Reply With Quote
Old 27th January 2007, 17:04   #73  |  Link
Sirber
retired developer
Sirber's Avatar
Someone just needs to compile one using Lazarus, but with the audio delay problem, currently encoding with bencos is a bit useless...
compile bencos, in the installation path, soft-link all the needed encoders and bencos should work.
Detritus Software
Old 2nd February 2007, 17:48   #74  |  Link
Sirber
retired developer
Sirber's Avatar
I think I found and fixed the audio delay problem. More infos here:
http://www.detritus.qc.ca/forum/view...p?pid=110#p110
Detritus Software
Old 2nd February 2007, 17:54   #75  |  Link
Eretria-chan
Nice work! Now if the program would just merge the encoded sources together, I could actually test the newly encoded file...
Old 2nd February 2007, 17:56   #76  |  Link
Sirber
retired developer
Sirber's Avatar
what do you mean, merge encoded sources? Past source which had delay problem will still have it using older bencos version. You will need to recode them using bencos 2007-02-02.
Detritus Software
Old 2nd February 2007, 22:48   #77  |  Link
Eretria-chan
The problems I have reported already. It fails to merge on the end.
And yes, there is write permission in F:\Downloads\Temp and no, it's not an invalid filename, as I can rename and copy a file with that filename just fine.
Old 2nd February 2007, 22:52   #78  |  Link
Sirber
retired developer
Sirber's Avatar
What if you do the merge manually?
Detritus Software
Old 3rd February 2007, 02:19   #79  |  Link
Eretria-chan
Well, mkvmerge fails because the video is raw. I haven't tested with whatever you're doing. I don't have the command line, and I suppose I'll have to do another encode to see if I can figure it out...
Old 3rd February 2007, 02:20   #80  |  Link
Sirber
retired developer
Sirber's Avatar
mp4box -add video.264 -fps 23.976 -add audio.mp4 -new out.mp4
Detritus Software
aac, bencos, gui, webm, x264
