20th May 2005, 04:55 | #21 | Link |
Hi Elic,
simply changing the specs is a very bad idea since XCD even made it into hardware playback devices and it would break compatibility then. An addendum would be possible though as long as it doesn't break backwards compatibility. Like i.e. extending the XCH/Backup system accordingly, we kept that very simple. Let's see if de_xt is still active, we could enter into a new discussion of that issue then. Cheers Koepi
Koepi's new media development site |
20th May 2005, 08:41 | #22 | Link |
@ Koepi
> XCD even made it into hardware playback devices Wow! I didn't even heard about it! Where can I read more about them? > extending the XCH/Backup system accordingly, we kept that very simple. Thanks, I shall get a grasp of specs more closely > Let's see if de_xt is still active, His last message on forum was on December 2004. I wrote a PM to him on 5 May, and still no reply
-= Elicit Gingers =- |
20th May 2005, 10:17 | #23 | Link | |
To my knowledge, every mpeg4-enabled player supports XCD too. Back to de_xt, give him some time. Sometimes it can take 4 weeks until somebody realises there's something in his mailbox I'll try to contact avih as well, he is also involved into XCD. Cheers Koepi
26th May 2005, 08:53 | #24 | Link |
New version (1.21) of RR is released as update package (rr-1.21.update.zip, 93011 bytes, contains only rrenc.exe, rrdec.exe and whatsnew.*) which is to be combined with previous version.
No new features, just fixes: - bug in polynom math library caused crash on CPUs without SSE (due to inattentive read help on Intel compiler); - bug in --process-dir switch handler. @ Koepi I searched more info about Gericom Bellagio AD2020 DVD-Player but didn't realise if it uses CD-level XCD (CLX) or file-level XCD (FLX), i.e. seems to be it can playback just mode2-form2 files regardless of disc structure (or maybe manufacturer have detailed specs closed). In my city, I didn't find DVD-players in sale which would claim to be XCD compatible. Although, I don't pretend to buy standalone DVD player, I'm totally satisfied by my PC DeXT is still in silence
1st February 2006, 21:34 | #25 | Link |
Hi there!
Nowadays, I got the site - http://elicit.vn.ua and uploaded all of my stuff there. Site is under construction, sorry about uncomfortabilities. The new version (RR 1.24) has many fixes of minor bugs and nearly invisible optimization. It is also splitted onto two packages: http://elicit.vn.ua/files/rr/rr-1.24.main.zip - main executables and minimalistic set of docs, and http://elicit.vn.ua/files/rr/rr-1.24.extra.zip - example of use and modified mode2cdmaker with sources. All of previous versions are also available here. Some hole in version numbering is caused by extensive refactoring and thus couple of semi-raw builds which remain unpublished.
1st February 2006, 22:38 | #26 | Link |
nice stuff!
14th February 2006, 23:47 | #27 | Link |
Version 1.25 (2006/02/13)
Lightweight (rr-1.25.update) package (main files only); designed to use together with rr-1.24.extra package. Changelog: Code:
Common: - few small bugs fixed. rrenc: - support for absolute paths added (in --process-dir mode only) in source filelist (when --source-dir is empty) and in destination files (when --target-dir is empty); - new command-line option added: --multi-track - new RR-list option added: -u - output of command-line into RR-list added; - built-in help improved and slightly reordered, info about errorlevels added. rrdec: - new RR-list option added: -u - built-in help improved and slightly reordered.
16th February 2006, 08:19 | #28 | Link |
Version 1.26 (2006/02/15)
Lightweight (rr-1.26.update) package (main files only); designed to use together with rr-1.24.extra package. Changelog: Code:
Common: - fixed few bugs in support of absolute paths. rrenc: - new command-line option added: --keep-old-ext (as m2cdm -extname). rrdec: - fixed serious bug in 1.25 which might cause mixing of directories; - support for XDC-discs made with -extname option.
20th February 2006, 21:32 | #29 | Link |
Version 1.27 (2006/02/20)
Lightweight (rr-1.27.update) package (main files only); designed to use together with rr-1.24.extra package. Changelog: Code:
Common: - max linesize of .rrt file increased up to ~1080 bytes (for long comments, especially rrenc's command-line copy); - fixed bug in comment processing module (crash if buffer overflows); - new RR-list option added: -e <ext> - custom extension of XCD files; - GUI front-end integration is slightly improved.
-= Elicit Gingers =- Last edited by Elic; 22nd February 2006 at 21:01. |
21st February 2006, 02:36 | #30 | Link |
beaware you still link to version 1.26!
22nd February 2006, 21:07 | #31 | Link |
bond
> beaware Oops... Thanks for warning. Maybe I was slightly sleepy
24th February 2006, 22:27 | #32 | Link |
Version 1.28 (2006/02/24) (for use together with rr-1.24.extra, as usual ). Changelog:
Common: - fixed bug in command-line parser.
27th February 2006, 23:35 | #33 | Link |
Version 1.29 (2006/02/27) is an update to rr-1.24.extra, as usual. Changelog:
Common: - fixed bug in m2cdm paramfile composer; - GUI front-end integration is improved (status line output).
30th June 2010, 02:19 | #34 | Link |
It's very difficult to find RR packages today (official site is dead and most of other sources are also invalid), so I decided to upload the latest versions here.
30th June 2010, 13:19 | #35 | Link | |
If you could add rr-1.24.main.zip as well so the package is complete |
2nd November 2012, 14:39 | #38 | Link |
RR revived as open source (GNU GPL v3): cd-rr.
Version 1.30 (2012/11/02) - changelog: Code:
Common: - example of use (window$ only). rrenc, rrdec: - port to Linux added. m2cdm: - preserve original timestamps of files placed on disc; - some compiler warnings fixed; - use compilation date instead of predefined one.
-= Elicit Gingers =- Last edited by Elic; 2nd November 2012 at 21:38. |
