Old 6th July 2016, 07:29   #1981  |  Link
pinterf
Ideally we shouldn't have distinct names for each format conversion, just one function with parameters. But it started when only Y8, YV12 and YUY existed besides rgb.
pinterf is offline
Old 6th July 2016, 08:00   #1982  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
There are already ConvertAudioTo8bit/16bit/Float, and no one complained to those name.
I think ConvertVideoTo8bit/16bit/Float are simple enough.
my repositories
Chikuzen is offline
Old 6th July 2016, 08:30   #1983  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by ultim View Post
- (pinterf) Floating point formatting bug fix, hopefully resolving issues like this.
Sorry, not
@turment on Telegram
tormento is offline
Old 6th July 2016, 08:47   #1984  |  Link
pinterf
Originally Posted by tormento View Post
Sorry, not
Are you sure you use the fresh 2022 version? What does avsmeter say (avsmeter -avsinfo) ?
Downloaded ultim's version, and also mine, no artifact. Changed back to a previous r1858, and my intermediate r1908-pfmod, and the artifact came back.
pinterf is offline
Old 6th July 2016, 08:49   #1985  |  Link
TurboPascal7
TurboPascal7's Avatar
Originally Posted by MysteryX View Post
Here's an idea for a new feature. Someone wrote AvsFilterNet to allow writing plugins in .NET. One issue is that the .NET plugin must be loaded by AvsFilterNet which is not practical for the user. A .NET library can't be loaded directly by AviSynth.
Could AviSynth+ natively provide an interface for .NET plugins?
First of all, .NET really wouldn't simplify stuff too much. Plugins rarely contain anything but the most trivial code and C++ is perfectly fine for that these days.
Second, I see no reason why something like AvsFilterNet couldn't just autoload other plugins on its own. What's the point of moving something like this into the core?
Me on GitHub | AviSynth+ - the (dead) future of AviSynth
TurboPascal7 is offline
Old 6th July 2016, 08:52   #1986  |  Link
pinterf
Yes, those are tasks for today. 8 bit comes without dithering options first. Float will have a scale parameter defaulting to 0-1.0.
pinterf is offline
Old 6th July 2016, 08:58   #1987  |  Link
pinterf
Another suggestion I've received and I like it, is to move these functions into a plugin. This plugin will be distributed along with the core for some time.
I was thinking the same. And there can be other converting functions (real.finder mentioned lnterleaved16 format), that can ease the transition until filters handle the new colorspaces natively.
pinterf is offline
Old 6th July 2016, 09:04   #1988  |  Link
jpsdr
Euh... Where do you get the new avisynth.h header ? I don't see any link, and it's not put in the package of the new release. Do i have to search it on the github repo ? It would be easier to put it with the release.
Edit : Found it (i think...) on searching on github.
jpsdr is offline
Old 6th July 2016, 09:12   #1989  |  Link
tormento
Acid fr0g
tormento's Avatar
Sorry. I had so many mkv outputs that I watched the wrong one.
No artifacts here.
Without going too much OT, can you please paste here the latest modified version of SMDegrain you are using and the script too?
tormento is offline
Old 6th July 2016, 09:23   #1990  |  Link
pinterf
No artifacts here.
Nice. Avisynth Plus Customer Service is happy.
I tested with this script
SetFilterMTMode("DEFAULT_MT_MODE", 2)
SetFilterMTMode("lsmashvideosource", 3)
lsmashvideosource("13HoursCUT.mp4", format="YUV420P8")
Crop(0, 140, 0, -140)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8)
and for the comparison I used the script from here
pinterf is offline
Old 6th July 2016, 09:27   #1991  |  Link
tormento
Acid fr0g
tormento's Avatar
What about this?
tormento is offline
Old 6th July 2016, 09:32   #1992  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Good question. I'm searching for it.
MysteryX is offline
Old 6th July 2016, 09:33   #1993  |  Link
tormento
Acid fr0g
tormento's Avatar
@real.finder
Can you please explain me the following changes?
  1. add Prefilter auto 16 (lsb) support
  2. add TV_range bool
  3. less lsb if not use lsb things and get ready for yv16 and yv24
Thanks
tormento is offline
Old 6th July 2016, 09:40   #1994  |  Link
Groucho2004
Some odd behaviour (XP64, 4GB RAM) using a script that should cause Avisynth throw an out of memory error:
Script:
setmemorymax(16000)
n = 12
colorbars(width = 1920 * n, height = 1080 * n, pixel_type = "rgb32").killaudio().assumefps(25, 1)
turnleft().pointresize(width() - 1920, height() - 1080)
turnright().pointresize(width() + 1920, height() + 1080)
Exception with r2022:
Exception 0xC0000005 [STATUS_ACCESS_VIOLATION]
Module:   D:\WINNT\system32\vcruntime140.dll
Address:  0x000000000207CA44
Exception with r1576:
GetFrameBuffer: Returned a VFB with a 0 data pointer!
size=1194393631, max=3196588032, used=3583180893
I think we have run out of memory folks!
This happens for both, x86 and x64.
r1576 throws what you would expect. I tried the same with the last of pinterf's builds - No exception thrown, Avisynth simply never returns from the first GetFrame() call.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 6th July 2016, 12:31   #1995  |  Link
pinterf
Script:
setmemorymax(16000)
n = 12
The cause is possibly the resizer temporary buffer allocation failure that is not caught. I think "simply does not return" means: with 8G RAM, the first frame was OK, but even a turnleft took 1200 seconds.
More info later.
pinterf is offline
Old 6th July 2016, 12:47   #1996  |  Link
Groucho2004
The cause is possibly the resizer temporary buffer allocation failure that is not catched I think "simply does not return" means: with 8G RAM, the first frame was OK, but even a turnleft took 1200 seconds.
More info later.
Thanks for looking into this.
I should have mentioned that I used AVSMeter to test this which reports the module in which an exception occurs. Then again, you probably knew that.
Old 6th July 2016, 12:59   #1997  |  Link
pinterf
The basic frame is 1.2Gbytes (23040x12960 rgb32)
When the horizontal resizer works, it creates a *21120 x 23040 sized (1.9GByte) videoframe, plus two temporary buffers, one 1.1Gbyte and a 1.9GByte one.
No wonder that with 4/8GB physical RAM is not enough (and this is the real limit, not the declared 160000MB you set in SetMemoryMax, it is overridden). 1.1GB for the Colorbars source frame, another 3-4x frame size during the resize process.
The 1200sec/frame was because of the OS memory swapping.
*This may be suboptimal to work with a new_horizontal*original_horizontal sized temporary frame, maybe it is needed for the horizontal resizer, because it works as turn+resize+turnback. Have to check it.
pinterf is offline
Old 6th July 2016, 13:05   #1998  |  Link
Groucho2004
I'm aware of how much memory these frame sizes need (more or less).
I'm not sure if you realize that the point of that script is simply to force Avisynth to run out of memory and see how it behaves.
So, the only question is why the new version behaves differently.
Old 6th July 2016, 13:16   #1999  |  Link
sl1pkn07
Pajas Mentales...
any installer for dummies?
greetings
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
Old 6th July 2016, 13:29   #2000  |  Link
ryrynz
ryrynz's Avatar
Groucho has an installer but it's for 1858. Perhaps he can update it with the latest build and link it.
If you're needing a hand installing it then you'll likely wish to read a guide on how to use Avisynth as well.
ryrynz is offline
