17th November 2019, 16:40 | #17781 | Link |
Try this
nmap.exe -Pn -sT -p 1000 192.168.0.101
17th November 2019, 18:11 | #17783 | Link |
I'm getting the same results as Privateer, the above line caused the encoding server to react - this works for each encoding server when the port and IP address is changed as required, the previous one did not.
No reaction from the encoding client though. Last edited by Ronski; 17th November 2019 at 18:15. |
17th November 2019, 18:15 | #17784 | Link | |
This at least means that nothing is blocking connection and EncodingServer v1.16 is also ok. So it has to be some weird bug in EncodingClient...
17th November 2019, 18:38 | #17786 | Link | |
Ok. Jokes aside! I will post debug version of encodingclient for those reporting this issue. It should help me to track down where in code bad things happens...
18th November 2019, 01:14 | #17787 | Link | |
Grumpy Old Man.
OMG, you're now my new BFF
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
18th November 2019, 01:19 | #17788 | Link |
Grumpy Old Man.
Not sure if you had a look at the screenshots I posted back at #17756, but I kinda thought back then, (even tho I was swapping and changing EC's & ES's around), that EC seemed to be looking for, and/or detecting the wrong ports.
18th November 2019, 09:14 | #17789 | Link |
i thought i'd report back to everyone that looks like another update came out over the weekend that updated Lmash and Core. looks like this latest update fixed the slow "gathering information" problem once again, and when you click on "start" encoding, it doesn't take forever for CPU cores to load up anymore.
i am going to image this version of RB and set it aside for backup. but i agree with Paul Dunne in regards to version control, it would be a good idea to either post all the versions for users to download, or at the very least, have some kind of pop up that notifies user a new update is available and only upon clicking "yes", the update goes through. this way users can at least get a chance to backup their RB version prior to updating. otherwise we'll constantly run into downloading and updating to the broken version. obviously, everyone's setup is different. so what's broken for one person may very well work fine for others. but some kind of measure should be implemented regarding updates. we love updates and new features, and thank the author for that, but a layer of version control/protection is much needed. |
18th November 2019, 09:50 | #17790 | Link |
Atak, i see encodingclient/server uses ports 61200 and upwards (maybe) internally when it works (before the 1.16 update) maybe something with those ports...or the using of them.
MCFish Last edited by MCFish; 18th November 2019 at 09:55. |
18th November 2019, 12:54 | #17791 | Link |
(Hard+Bett+Fast+Strong)er
Atak_Snajpera : thank you agin for this great job.
Could you be pleased to add these feature :
... to encode files from DSLR / Camera to lower resolution / proxy file but with the same timecode of the sources 0gg / augur.
Asic / CPU / GPU / Food farming |
18th November 2019, 15:23 | #17792 | Link |
Run this debug version and show me what messages you get
https://www.mediafire.com/file/9zic1...lient.exe/file example screenshot from my machine
18th November 2019, 15:58 | #17793 | Link |
CheckIP(192.168.0.8:1000)=false
CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false etc etc etc
MCFish |
18th November 2019, 16:07 | #17794 | Link | |
18th November 2019, 16:27 | #17795 | Link |
I assumed you meant i should enter it in 'Distributed Encoding Server IP'
it went so fast past me, but got something CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false IP="192.168.1.2:1000" CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false CheckIP(0.0.0.0:0)=false Starting workerthread CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false Connecting to "192.168.1.2:1000" CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false CheckIP(192.168.0.8:1000)=false CheckIP(192.168.0.2:1000)=false CheckIP(192.168.0.12:1000)=false There was a timout further down, guess it was for 192.168.1.2
MCFish Last edited by MCFish; 18th November 2019 at 16:33. |
18th November 2019, 16:36 | #17797 | Link |
I have located a bug in my function CheckIP. This function basically checks if ip values entered by user are in valid range of 0-255. It also checks other things like number of dots and if port is divisible by 1000 but that was not a problem here. Problem was that if you had 0 in ip (for example 192.168.0.1) then function was returning FALSE and hence no connection to server. This explains why it worked for me since I have IPs without zero value (192.168.1.100)
18th November 2019, 16:42 | #17798 | Link |
This version should work now
https://www.mediafire.com/file/zat5j...lient.exe/file
18th November 2019, 16:49 | #17800 | Link |
Ok then BRACE YOURSELF! AUTO-UPDATE IS COMING!
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th November 2019 at 16:54. |
