6th April 2009, 19:10 | #1901 | Link |
Hi DeanK,
One problem more : trying to build a disk from h.264/mpeg (sound) files, as I do from time to time, I got this : ac3to refuded to convert audio! And the audio track is - and was in the past - mpeg Audio Version 1 layer 2 file. eac3to is the latest one, avisynth as well - 2.5. Any ideas ? Thanx in advance! |
6th April 2009, 19:16 | #1902 | Link | |
FinalCut´ter
Main thing for me: support of mpeg2 HDV ... and that is perfect. Edit: made a ac3 sound file from AppleTv file (very fast) and named it after the AppleTV file. Using option "add external audio tracks" in multiAVCHD I get my working AVCHD structures. Last edited by kenguru2005; 6th April 2009 at 19:28. |
6th April 2009, 19:28 | #1903 | Link | |
Programmer (or just 教务长)
6th April 2009, 19:59 | #1904 | Link |
FinalCut´ter
Ok now eac3to even refuses to convert my audio from HDV mov files ... I do not know why this is broken now.
[20:55:09] Converting Quicktime video file to AVCHD (Y:\Movies\AVCHD\film01.mov). [20:55:10] Endian: little [20:55:10] Track has 2 channels. [20:55:10] Sampling: 48000 [20:55:10] Resolution: 16 [20:55:10] Format: PCM [20:55:10] Extracting PCM audio (mplayer)... [20:55:23] eac3to refused to convert audio! [20:55:23] Extracting V_MPEG-2 video (mplayer)... [20:55:37] Completed successfully! Last edited by kenguru2005; 6th April 2009 at 20:16. |
6th April 2009, 21:21 | #1907 | Link | |
There is a file multiAVCHD.pid - if present - multiAVCHD thinks that another instance is running. Last edited by deank; 6th April 2009 at 21:23. |
6th April 2009, 21:32 | #1909 | Link | |
FinalCut´ter
And this pid.-file returns ... a resets my ini what have you done? It works again ... Processing 1 input file/folder. [22:33:25] Converting Quicktime video file to AVCHD (Y:\Movies\AVCHD\film01.mov). [22:33:26] Endian: little [22:33:26] Track has 2 channels. [22:33:26] Sampling: 48000 [22:33:26] Resolution: 16 [22:33:26] Format: PCM [22:33:26] Extracting PCM audio (mplayer)... [22:33:50] Adding AC3 encoded audio track... [22:33:50] Extracting V_MPEG-2 video (mplayer)... [22:33:55] Completed successfully! [22:33:55] Total of 2 tracks found in this file. Last edited by kenguru2005; 6th April 2009 at 21:37. |
6th April 2009, 21:40 | #1910 | Link | |||
pid file should be deleted once the program closes, doesn't it? Right... ini get's reset if you do multiple launches. I do not advice you to do so.... I fixed it just now. Last edited by deank; 6th April 2009 at 21:53. |
6th April 2009, 21:47 | #1911 | Link |
FinalCut´ter
I don´t know why pid file isn´t deleted anymore ... but i`ll test, perhaps it´s fixed in 504?
No, still a pid problem in 505 ... Is this pid problem also under windows or just a problem of virtual machines? Last edited by kenguru2005; 6th April 2009 at 22:04. |
6th April 2009, 22:32 | #1913 | Link | |
Hmm... Can you send me a small sample... I'm a bit tired and maybe I overlooked something... Or mediainfo about the file. but first EXECUTE multiUPDATE.exe and try now Last edited by deank; 6th April 2009 at 22:38. |
7th April 2009, 00:19 | #1917 | Link |
Hi Dean
I tried this app last night for the first time and after a few false starts due to me, it seemed to work, but I haven't tried to play the output on the PS3 yet because I tried to just playback the output MTS files on my computer and one set would only play the audio and not the video. The original M2TS plays fine. The other set I processed did play audio and video from the processed output folder. Anything come to mind that would cause one to play video and another not to? PS, the one that did not play video, only audio, was an m2ts file. The files that did play fine were already in an AVCHD folder structure. Last edited by tyee; 7th April 2009 at 00:24. |
7th April 2009, 05:36 | #1918 | Link | |
FinalCut´ter
The german translation .... I´ll test. |
7th April 2009, 07:51 | #1919 | Link | ||
I asked for manual update, because sometimes I do changes to multiAVCHD, but not to the build number, so autoupdate will not update your .exe, but multiUPDATE will. |
