Old 8th October 2009, 17:53   #2421  |  Link
ACrowley
Originally Posted by LoRd_MuldeR View Post
Why do you complain about too low bitrate? You can't expect a specific bitrate from a specific CRF value, because CRF highly depends on the source.
So if the quality is okay at CRF 18 and 6-8 Mbps, then be happy
And if the quality is not okay for you at CRF 18, simply use an even lower CRF value. The CRF should be chosen by target quality, not by target bitrate.
For target bitrate encodes there is 2-Pass mode ...
im not complainig. I just wondering because i was expecting higher Bitrate with CRF 18. I usually encode 1080p with 8-15Mbps.
ACrowley is offline   Reply With Quote
Old 8th October 2009, 18:13   #2422  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
1. As said before, CRF highly depends on the source. So your current source may simply need fewer bits to look good.
2. MB-Tree RC redefined the CRF scale and generally reduces the bitrate requirement (that is: it retains better quality at same bitrate, or same quality at lower bitrate).
Maybe you are comparing a MB-Tree RC encode to an old encode that was done without MB-Tree ???
Old 8th October 2009, 18:23   #2423  |  Link
ACrowley
Its latest encode from Xmen Origins Wolferine Bluray.
The Source incldues a lot of Scenes with heavy Grain so i was suprised that the average Bitrate/Filesize is so low with crf 18.
Yes, some old encdes without MBtree have higher Bitrate/Size at CRF 18 so i cant compare it with ne MBtree encodes.
Maybe i should go down to crf 16 or 17
THX for your help
Old 8th October 2009, 18:27   #2424  |  Link
LoRd_MuldeR
Software Developer
Nobody can tell you what CRF values give acceptable quality for you, because this is highly subjective!
Simply use the highest possible CRF value that still gives good results for your eyes. If CRF 18 looks good for you, then no need to go any lower.
But if it looks bad for you, don't hesitate to try CRF 17 or 16
Old 8th October 2009, 18:42   #2425  |  Link
ACrowley
Im very satisfied with my 2pass VBR encodes which are mostly around 10-12Mbps average Bitrate.
I want the same Quality/Size. CRF was only a thought because it works faster. I will test it .
THX
Old 8th October 2009, 18:57   #2426  |  Link
LoRd_MuldeR
Software Developer
THX
Again: If you use CRF mode, then choose your CRF value with a specific level of quality in mind, not with a specific target bitrate in mind!
So you should adjust the CRF value until you get the desired quality instead of modifying it until you hit a specific bitrate. For the latter case we have 2-Pass mode
Old 9th October 2009, 21:14   #2427  |  Link
komisar
komisar's Avatar
Hey, guys, gcc-miscompiling-saga again...
I have tested unpatched builds again and found the following results:
1281 builds:
x264.nl gcc 3.4.6 -- OK
BugMaster gcc 4.3.3 TDM -- OK
BugMaster gcc 4.3.4 20090220 (prerelease) (x32.generic.Komisar) (not profiled) -- OK
Komisar gcc 4.3.4 (x86_64.core2.Komisar) -- OK
Komisar gcc 4.3.4 (x86.generic.Komisar) -- OK
Komisar gcc 4.4.1 (x86.core2.Komisar) -- FAILURE
JEEB gcc 4.3.4 20090220 (prerelease) (x64.generic.Komisar) -- FAILURE
techouse gcc 4.4.1 (x86_64.core2.Komisar) -- FAILURE
rack04 (patched build) gcc 4.3.4 (x86.core2.Komisar) -- FAILURE
gcc sucks again...
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 9th October 2009, 22:12   #2428  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Oh nice~
Thank you for your information, I'll get to building a new GCC and a new x264 as soon as I'll get home :/ Kind of hatin' the whole miscompilation stuff.
In short: *censored* (Holy Hanyuu I hate these cases)
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 9th October 2009, 22:58   #2429  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
what is the problem that is occurring in x264 with these 'broken' builds?
and what is the issue in gcc that's causing them
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 9th October 2009, 23:16   #2430  |  Link
LoRd_MuldeR
Software Developer
Komisar, how exactly do you test the builds? And does "FAILURE" mean crash, bad output or what? How would I realize?
BTW: Did anybody else test GCC 4.4.1 TDM-2 yet?
Old 10th October 2009, 06:35   #2431  |  Link
MythCreator
My build is compile by TDM GCC。。。And what things are failure on 4.4.X?
MythCreator is offline   Reply With Quote
Old 10th October 2009, 12:11   #2432  |  Link
LoRd_MuldeR
Software Developer
That's what I wonder too. There are basically two things that can happen:
1. Unexpected crash -> easy to detect and easy to fix (re-build until it stops crashing)
2. Bad output -> hard to detect, unless the output is broken so bad that it causes obvious artifacts
Since (1) does happen with my GCC 4.4.1 TDM-2 builds and there also is no obvious indication for (2), I'd assume these builds are okay.
But there may be a more subtle problem. So how do I check properly ???
Old 10th October 2009, 14:03   #2433  |  Link
techouse
Strictly Rhythm
techouse's Avatar
Yea, I wanna know that too. :/
techouse is offline   Reply With Quote
Old 10th October 2009, 16:10   #2434  |  Link
MasterNobody
LoRd_MuldeR, techouse
If you were at x264dev IRC yesterday you would know that it doesn't cause obvious artifacts. It is caused by used addressing in x264 and gcc. The quick workaround is replacing of all dct2x2[0][coeff] with dct2x2[coeff>>1][coeff&1] in macroblock.c
MasterNobody is offline   Reply With Quote
Old 10th October 2009, 16:12   #2435  |  Link
komisar
komisar's Avatar
Test made by "%x% --threads 1 --ssim -o %x%.264 TestVideo.y4m"
"FAILURE" mean BIG difference (above 5 kilobytes) (FAILURE) with x264.nl x32 build...
Raw stream of "OK"-bulds is identical with x264.nl x32 build...
Old 10th October 2009, 16:24   #2436  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
we discussed the issue on #x264dev last night and discovered the discrepancy in the output and the underlying cause in the code.
the underlying code was found in
x264_mb_optimize_chroma_dc within encoder/macroblock.c
the problem with the output not being bitwise equivalent is that the chroma macroblocks can be slightly different from what they should be.
the visual difference is generally unnoticeable and there's a slight bitrate difference when encoding in CRF mode.
the method to test if your build has this issue:
1. take a build that was listed as 'OK' by komisar and use it as a reference
2. ./x264_reference --qp 24 --ipratio 1 -o a1.h264 <input>
3. ./x264_reference --qp 25 --ipratio 1 -o a2.h264 <input>
4. ./x264_your_own --qp 24 --ipratio 1 -o b1.h264 <input>
5. ./x264_your_own --qp 25 --ipratio 1 -o b2.h264 <input>
if your build has problems then
a1.h264 & b1.h264 should be different
a2.h264 & b2.h264 should be bitwise equivalent
the problem has only been reported for mingw as of yet, so it's either only affecting mingw or no one's just tested for other platforms.
Old 10th October 2009, 19:04   #2437  |  Link
tph
dct2x2[2][2] could also be changed into dct2x2[4] instead (after adjusting all relevant code), at least that seems to do the trick for me and should theoretically be faster than doing some bit manipulation. The same probably holds for all other DCT arrays.
tph is offline   Reply With Quote
Old 10th October 2009, 19:12   #2438  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
that's the plan of attack as it already stands:
Originally Posted by #x264dev@irc.freenode.net
<kemuri-_9> so what is going to be done to fix the issue?
<pengvado> eliminate multidimensional arrays in any context that needs to iterate over multiple dimensions
<pengvado> if the standard doesn't allow that feature to work, then we can't use it
<pengvado> you know, most of the time it's not actually useful to treat dct as 2d...
Old 11th October 2009, 12:56   #2439  |  Link
techouse
Strictly Rhythm
techouse's Avatar
OK, I'll use this quick workaround and post 3 builds in a few minutes.
EDIT:
x264_x64_r1281_fix_unpatched | MD5
GCC 4.4.1 20090803 (x64.core2.Komisar), unpatched, generic, fprofiled
Patches used:
the quick GCC 4.4.x workaround
________________________________________________________________________________
x264_x86_r1281_fix_techouse | INFO
GCC 4.4.1 20090803 (x86.core2.Komisar), fprofiled, -march=core2
x264_x64_r1281_fix_techouse | INFO
GCC 4.4.1 20090803 (x86_64.core2.Komisar), fprofiled, -march=core2
Patches used:
x264_win_zone_parse_fix_06.diff
x264_hrd_pd_interlace.16_r1281.diff
Last edited by techouse; 11th October 2009 at 19:27. Reason: Fixed patched builds. Links remain the same, the binaries on the server have changed, so please RE-download them.
Old 11th October 2009, 13:21   #2440  |  Link
burfadel
Is this issue still present in the GCC 4.5.0 beta?
Using the latest ffdshow and mpc-hc from xvidvideo.ru both of which are compiled with gcc 4.5.0, they seem to work fine...
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
