Old 13th December 2010, 13:21   #15381  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
patch update .
Set the name of the audiotrack to audiochannel.
And this option should be set in the custom channel mapping in the time before the speaker for the opening of 2!
mpc-hc_x86_rev2769_with_AudioChannel
http://www.mediafire.com/?l02y0nyzeo56p52
patch
http://www.mediafire.com/?2ypv6v669k2kj8k
betaking is offline
Old 13th December 2010, 13:34   #15382  |  Link
v0lt
I repeat. Why is it needed? For what great purpose should be so quick to switch channels?
a useless feature.
v0lt is offline
Old 13th December 2010, 13:39   #15383  |  Link
Superb
MPC-HC 1.4.2769 (xvidvideo.ru vs2010 x86):
When the player is at Compact or Minimal mode (pressing 1 or 2 in the keyboard) and NOT showing in full screen, clicking on the video doesn't pause/resume it.
Is this an intended behavior or a bug?
Superb is offline
Old 13th December 2010, 13:47   #15384  |  Link
betaking
betaking's Avatar
a useless feature.
Features may be useless, but I think it is stupid fast operation of the! Because the majority of video users in China are a lot of play left and right channels of a bilingual video!
betaking is offline
Old 13th December 2010, 15:14   #15385  |  Link
zhfi
It's quite useful to chinese!
latest updated source code here:
http://ifififi.svn.sourceforge.net/v...fififi/mpc-hc/
zhfi is offline
Old 13th December 2010, 15:25   #15386  |  Link
namaiki
^Probably for VCDs.
namaiki is offline
Old 13th December 2010, 18:28   #15387  |  Link
sansnom05
This is intended cause those two modes have no caption bar to move window around, so you can click & drag to move it. Right now you can only use Space to pause/resume video in those 2 modes, but this can be changed in the future.
Thanks for your effort to contribute code for mpc-hc. One thing important though: source file is not the best way to provided patches, better way is to use any source control software for generating .diff/.patch, you should mention which revision you patch is against too.
sansnom05 is offline
Old 13th December 2010, 20:11   #15388  |  Link
janos666
Originally Posted by XhmikosR View Post
Well, if it's a bug in lcms you should contact the developer of lcms. Nothing I can do, except for reverting the commit.
I talked with Marti Maria. He says that MPC-HC is actually using MS ICM instead of LittleCMS!
He tested my ICM display profile with lcms and he says that it's ok. But he has brownish image with my profile when he uses the latest MPC-HC.
So, the current hypothesis is that this problem exists on your side.
But it's strange that colors shifted after you updated the lcms code. There should be some kind of correlation and he must be wrong with this MS ICM idea.
janos666 is offline
Old 13th December 2010, 21:02   #15389  |  Link
Superb
Guys, AMD Catalyst 10.12 drivers are out on AMD.com.
There are two packs to choose from: old CCC and new CCC.
Superb is offline
Old 13th December 2010, 21:49   #15390  |  Link
XhmikosR
I have no idea, a_afra added support for lcms.
My Specs
XhmikosR is offline
Old 13th December 2010, 23:08   #15391  |  Link
hayan
Single-monitor system can't exit from fullscreen mode pressing alt+tab, win+tab and win key. (non-d3d-fullscreen mode)
Can only press Esc key, alt+enter and d-click(mouse).
MPC-HC 1.4.2735+
Fix : prevent exit from fullscreen when lost focus on multi-monitor system;
hayan is offline
Old 14th December 2010, 02:27   #15392  |  Link
janos666
What a surprise: He is Hungarian (like me). I sent him a message.
janos666 is offline
Old 14th December 2010, 04:03   #15393  |  Link
zhfi
the patch for mpc-hc svn2769 here:
zhfi is offline
Old 14th December 2010, 08:45   #15394  |  Link
tetsuo55
MPC-HC Project Manager
I vote to add the audiochannel patch, its really usefull (but again due to chinese background)
Also Catalyst 10.12 is out, some interesting changes, for one DIVX DXVA should get enabled on 6xxx cards, anyone have one so they can show the id with dxvachecker?
it also updates openGL to 4.1.
tetsuo55 is offline
Old 14th December 2010, 09:00   #15395  |  Link
v0lt
Please add this patch.
mov-png_,8bps,3iv1,3iv2_support.patch
v0lt is offline
Old 14th December 2010, 09:31   #15396  |  Link
entrecour
subtitles
In case you missed this post, the attachments are now approved. Can anyone replicate this?
http://forum.doom9.org/showthread.ph...50#post1462850
entrecour is offline
Old 14th December 2010, 11:14   #15397  |  Link
hfpsilva
hi,
some on can help me ? the new release of mpc-hc don't save the configurations on the options menu, how can i save the configs for the new release?
hfpsilva is offline
Old 14th December 2010, 11:28   #15398  |  Link
Kazuya
Kodi + Potplayer addict
Originally Posted by Kazuya View Post
Hello !
Is there any chance the OSD looks a little... nicer ?
This colors are really freaky !
Am I the only one who dislike this OSD ???
Hometheater builder and acoustic specialist (www.kazcorporation.com)
Kazuya is offline
Old 14th December 2010, 11:34   #15399  |  Link
namaiki
I don't use D3D Fullscreen so I never see that. Seems functional enough, though.
edit: the one at the top is fine...
namaiki is offline
Old 14th December 2010, 11:51   #15400  |  Link
Kazuya
I'm talking about the OSD on top of the screen too.
Functional yes, but in a hometheater which looks like a real theater with 3 meters width screen it's a real disaster !
MPC wants to be the BEST player ever, I think it has to make a little make up to really access to the top !
Kazuya is offline
dxva, h264, home cinema, media player classic, mpc-hc
