Old 5th November 2005, 17:41   #21  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
By the way, when i try to increase speed of MVTools, i found that "searchparam" of MVAnalyse is really =2 by default. The documentation says, that it is =1.
Old 5th November 2005, 18:04   #22  |  Link
Didée
Hah, interesting finding about searchparam's default!
Originally Posted by Fizick
What you made it is post-processing.
Yes. As is deblocking.
But if we will use this "cured" compensated frame for noise reduction, it will have exactly same pixels values in this cured regions as current frame. Strange denoising.
Fizick, did you actually *look* at my sample? Ideally with switching forth-back between "source" and "compensated(PP)", at some 200% or 400% zoom?
Old 5th November 2005, 18:41   #23  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
I understand, that is is not full pixels equivalence, but we must not use it anyway
Old 5th November 2005, 22:51   #24  |  Link
Didée
"We must not" ?? Which god has decided so?
If you think the result will be better with using some UltraSmearyMegaBlurryDeblocking for that purpose, well, I won't hold you back from doing so
But I'll tell you the findings I've come to so far, in respect to denoising:
When using a broad repair for badly compensated blocks, then at best you'll only be able to flatten down the block's content ... together with the detail that might have been in before. But things might even get worse, since the content of the "bad" block might happen to be completely unrelated, in which case deblocking will not help, but create a smeary mess.
However when repairing with Repair(reference,4) plus alittle additional sharpening, you effectively get the content of the original block, BUT with a sort of "noise-of-its-own". That's because the bad block's pixels might be brighter or darker than those of the original block, which is a random relation. Then, sharpening the rather flat result of Repair(4) thereof will recreate a reasonable representation of the original block from the compensated-and-repaired one, but with "another kind" of noise. And this is perfectly suited for denoising.
But let's stop the arguing, do whatever you consider to be the best. I've dropped my point (to not get accused of "hiding the miracles" somewhen later), and - penultimate argument - it is already working on my side, rather nicely.
Old 6th November 2005, 00:25   #25  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
let's stop.
Old 6th November 2005, 22:02   #26  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
v.0.9.11.1 (Released 06.11.2005)
Added half-pel support to MVFlow.
Increased quant limit to 60 in DeBlock for very strong deblocking.
Corrected documentation.
http://www.avisynth.org/fizick/mvtools/
Old 7th November 2005, 00:04   #27  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
is it possible for you to add a motion blurrer based on mvFlow() ?
possible parameters like
blurlength: 0 - no blur ; 0.5 blur for the half the duration of a frame; 1 - blur for the duration of one frame ; 2 - blur over the duration of 2 frames
precision: 1 - do nothing; 2 - two pixels; 10 - pixels etc...
maybe you could leave out the precision parameter, if you are drawing lines of 'blurlength' (vectorlength*blurlength) instead of pixels, so there would never occur any ghosting.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 7th November 2005, 18:58   #28  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
scharfis_brain,
I will think about blur.
Now MVFlow is used mstly for compensation.
I have a plan to add motion interpolation (bi-directional and masked), probably MVFlowInter function.
About your request about YUY2. You do not get me answer, do you need in YUY2 motion estimation or in YUY2 compensation only?
Old 7th November 2005, 20:45   #29  |  Link
scharfis_brain
brainless
I'd be glad, if you could implement the YUY2 space
Estimation can be done in YV12 space. (of course, YUY2 would be a nice-to-have, too )
But for compensation YUY2 is a must, when dealing with field-stuff.
Old 8th November 2005, 18:16   #30  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Really great to see the features I miss in this great tool. I do however get deallocation crashes using this script:
highquality=true
source=last
vectors_b = source.MVAnalyse(isb = false, lambda = 1000, pel = (highquality) ? 2: 1)
vectors_f = source.MVAnalyse(isb = true, lambda = 1000, pel = (highquality) ? 2: 1)
inter12=mvinter(source, vectors_f, vectors_b, time=12.0, thSCD2=70, thSCD1=100)
inter25=mvinter(source, vectors_f, vectors_b, time=25.0, thSCD2=70, thSCD1=100)
inter75=mvinter(source, vectors_f, vectors_b, time=75.0, thSCD2=70, thSCD1=100)
inter88=mvinter(source, vectors_f, vectors_b, time=88.0, thSCD2=70, thSCD1=100)
interleave(source,inter12,inter25,inter75,inter88)
temporalsoften(2,255,255,5,2)
selectevery(5)
Source is 624x352. (This is btw a very good motion blur)
Regarding YUY2, using YV16 in 2.6 will probably be easier since it's planar. There are however a lot of "width / 2" and "height / 2", instead of the PVideoFrame->GetRowSize(PLANAR_U) & PVideoFrame->GetHeight(PLANAR_U), which will make adding new colorspaces harder.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 8th November 2005, 22:01   #31  |  Link
Manao
YUY2 or YV16 will be the same, since internal data will need to be planar anyway ( nobody in their right mind would work on interleave data for ME / interpolation / compensation ).
I can do the YUY2 adaptation. Not quite yet ( I'll be rather busy till sunday ), but after that, I'll have some free time. It's "almost" "just a matter" of changing "nHeight / 2" by "nHeightUV" ( I won't use the PvideoFrame->*, because width & height are needed at initialization time anyway, and because the core is made as much as possible to be independant from avs 2.5 ).
Manao is offline   Reply With Quote
Old 8th November 2005, 22:13   #32  |  Link
mg262
Clouded
mg262's Avatar
FWIW, kassandro wrote some Planar2Interleaved and Interleaved2Planar functions that might save you a little time here. I think they're part of RemoveGrain.
a.k.a. Clouded. Come and help by making sure your favourite AVISynth filters and scripts are listed.
mg262 is offline   Reply With Quote
Old 8th November 2005, 23:53   #33  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Manao,
We must use not-squared blocks for YUY2 (YV16) chroma (4x8 ?)
sh0dan,
I will try to find a bug.
But I reaaly want to remove MVInter and replace it by MVFlowInter tomorrow.
Old 9th November 2005, 21:04   #34  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
v0.9.12
Added MVFlowInter function. MVInter function will be removed in next release (it is worse).
Changed scale of ml parameter for kind=2 of MVMask to more optimal default.
Fixed small bug in Bilinear.asm (strange pixels near right border for pel=2).
Old 10th November 2005, 14:17   #35  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
mvflowinter is looking good! just upconverting something to 100fps to check it out.
it'd be cool to have an mvfps style function though - trying to calculate appropriate time values for turning 60/1.001 fps to 50 fps is doing my head in. i was thinking about doing it with a scriptclip, but i'm sure disaster lies in that direction.
Old 10th November 2005, 14:37   #36  |  Link
scharfis_brain
brainless
59.94 <-> 50 conversions can be made easily by calculating approx 300 fps (59.94*5) or exactly 300 fps (50*6) and then do changefps afterwards.
the remaining stutter of the 1000/1001 thing can be neglected, cause it will only be a 'stutter' of 1/300 sec.
Old 10th November 2005, 19:26   #37  |  Link
scharfis_brain
brainless
I am running in big trouble with mvflowinter()
loadplugin("d:\x\mvtools0912.dll")
loadplugin("d:\x\tdeint.dll")
loadplugin("d:\x\DGDecode.dll")
#load interlaced video
mpeg2source("D:\FORUM\castellandw\PALMPEG2Clip.d2v",cpu=4)
i=tdeint(mode=1,type=3,link=0,mthreshl=7,ap=25)
vf=mvanalyse(i,isb=false,blksize=4,lambda=1000,lsad=1000,pnew=100,plen=0,pel=2)
vb=mvanalyse(i,isb=true ,blksize=4,lambda=1000,lsad=1000,pnew=100,plen=0,pel=2)
a17=mvflowinter(i,vb,vf,time=16.7,ml=100)
a20=mvflowinter(i,vb,vf,time=20.0,ml=100)
a33=mvflowinter(i,vb,vf,time=33.3,ml=100)
a40=mvflowinter(i,vb,vf,time=40.0,ml=100)
a50=mvflowinter(i,vb,vf,time=50.0,ml=100)
a60=mvflowinter(i,vb,vf,time=60.0,ml=100)
a67=mvflowinter(i,vb,vf,time=66.7,ml=100)
a80=mvflowinter(i,vb,vf,time=80.0,ml=100)
a83=mvflowinter(i,vb,vf,time=83.3,ml=100)
#interleave(i,a20,a40,a60,a80).changefps(50) # NTSC2PAL
interleave(i,a17,a33,a50,a67,a83).changefps(59.94,linear=false) #PAL2NTSC
It immediately closed VDub on open without any error message.
when I commented out the lines a20, a40, a60, and a80 it ran for a while but closed VDub after approx 50 frames linear acces after jumping to a random time in the video file.
but nontheless, the interpolation results are pretty good. A little bit lesser wobbling on occlusions and it is read for usage in an standards conversion script.
btw.: can you code in an error protection for appearing and vanishing logos and subtitles? Cause mvflowinter makes a funny kind of interpolation out of it
Old 10th November 2005, 21:18   #38  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
scharfis_brain,
what is your system config?
Some words about 1.001:
Internally i use time not as float but as byte integer, so gradations are from 0 to 256.
Old 10th November 2005, 21:34   #39  |  Link
scharfis_brain
brainless
My system configuration:
AthlonXP 1600+ with 768MB RAM
running WindowsXP SP2
and currently AVS 2005-May-05 without plugin-autoloading
Old 11th November 2005, 07:04   #40  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Firstly try remove unused a20, a40, a80 lines.
At construction stage MVFlowinter creates huge arrays.
MVTools eat many memory generally.
Also try latest more stable AViSynth.
I must ask Manao, why 10 frames per mvclip is created.
And why MVtools strore compensated frames (large!) in vector clips. In my opinion, we must compensate in various Compensation functions. For example in MVDlow I do not use pre-compensation info. Also often it is better to estimate pre-filtered clip, but compensate original source. So, probably mode=0 in MVompensate is almost unusable. What anybody think about it?
