Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 26th December 2008, 15:31   #41  |  Link
buzzqw
HDConvertToX author
update the linux build (again), just some gui glitch (and fixed the Donate button ... )
But I'm confusing with a cropping. If I want to omit crop values, do I put 0 in these values or width x height? I need some clarity on this question.
yes, for NO CROP but 0 on all values
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 28th December 2008, 13:53   #42  |  Link
buzzqw
HDConvertToX author
fixed muxing on No audio (both for linux and windows build)
BHH
Old 29th December 2008, 08:30   #43  |  Link
Selur
Selur's Avatar
@buzzqw: did you find a workaround for http://forum.doom9.org/showthread.php?t=140261 ? (strange connection between sample rate and bitrate when encoding to aac audio)
Old 29th December 2008, 17:30   #44  |  Link
buzzqw
HDConvertToX author
well.. i don't pass sample rate to mencoder , i let mencoder select it (or can be selected by user) (and i use only mencoder, not ffmpeg)
can you use sox as a prefilter for sampling ?
BHH
Old 29th December 2008, 19:35   #45  |  Link
yeye69
How about multiple sound tracks?
yeye69 is offline   Reply With Quote
Old 29th December 2008, 19:46   #46  |  Link
buzzqw
HDConvertToX author
autox264 can handle input file with multiple audio tracks (change pid in audio options) , BUT can output only one audio track at time
BHH
Old 29th December 2008, 21:21   #47  |  Link
Selur
Selur's Avatar
one could, but the problem is this:
say you got a stereo source with 380kBit/s@48kHz and you want a 60kBit/s@48kHz stereo aac file with you end up with 96+kBit/s instead of 60kBit/s. So the problem is that the output bitrate strongly depends on the output sample rate if you just take the sampel rate of the input (48kHz) you can't get a bitrate around 60kBit/s you always end somewhere between 80kBit/s-160kBit/s and as far as I could test it then there's no way of knowing what the output size will be.
All in all it isn't really a problem if it doesn't bother you if you get a 60kBit/s or a 132kBit/s audio output. (doesn't kill you for normal dvd encodes aiming for 1CD+ but it's really a pain if you want some low bitrate encodes for the net; that's what I needed when I stumbled over this problem. )
Haven't found a workaround for it myself and for low datarates I now use neroaacenc, just wanted to know if you were aware of the problem and may be knew a way to fix it.
Cu Selur
Old 29th December 2008, 22:10   #48  |  Link
buzzqw
HDConvertToX author
understud, that a pita
i will encode some sample files at different audio bitrate with autox264... just to look at audio bitrate
thanks for the input
BHH
Old 31st December 2008, 08:45   #49  |  Link
buzzqw
HDConvertToX author
update windows build
now autox264 propose the same input folder as output folder
when saving with extension "mkv" autox264 set automatically mux to mkv
BHH
Old 2nd January 2009, 13:16   #50  |  Link
buzzqw
HDConvertToX author
update the windows build (later for linux)
added support for multi audio
BHH
Old 4th January 2009, 23:29   #51  |  Link
Mad_Martha
Mad_Martha's Avatar
Hi , thanks for this prog..
Question : How would I go about a non-cropped , Anamorphic encode to an mkv - encode at original res then use mkvmerge to set DAR ?
Problem - Have noted that even when I set the cropping to all zero , clicking anywhere on the cropping tag re-enters values into the crop fields.
(and conversely - when changing the crop fields to zero it changes the output resolution away from what was previously set)
Another problem I got is that when trying to encode - audio is processed but then everything just stops - does not get to trying to encode video , just halts after the audio.(the terminal window closes and nothing else happens)
I pasted the encode line directly into a terminal window and got the following :
mencoder -vf harddup,crop=720:576:0:0,scale=720:576,hqdn3d=2:1:2 -sws 2 -aspect 1.7778 -of rawvideo -o autox264.h264 -nosound -ovc x264 -x264encopts bitrate=2114ass=1:threads=auto:bframes=8artitions=i4x4,i8x8,p8x8,b8x8:8x8dct:direct_pred=auto:me=tesa:subq=8:b_adapt=2:turbo=2:frameref=16:deblock=-1,-2:weight_b:me_range=32:trellis=2:mixed_refs:b_pyramid:level=4.1:ratetol=1 "/home/madmartha/Videos/Clockwork.mpg" -nosound
MEncoder 2:1.0~rc2-0ubuntu17 (C) 2000-2007 MPlayer Team
CPU: Intel(R) Pentium(R) III CPU family 1400MHz (Family: 6, Model: 11, Stepping: 1)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
Option x264encopts: Bad argument b_adapt=2
success: format: 0 data: 0x0 - 0x2d3e804
MPEG-PS file format detected.
VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 6500.0 kbps (812.5 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [hqdn3d=2:1:2]
Opening video filter: [scale w=720 h=576]
Opening video filter: [crop w=720 h=576 x=0 y=0]
Crop: 720 x 576, 0 ; 0
Opening video filter: [harddup]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
Try appending the scale filter to your filter list,
e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
[swscaler @ 0x883e3d0]SwScaler: using unscaled yuv420p -> yuv420p special converter
FATAL: Cannot initialize video driver.
Exiting...
cheers , [MM]
Mad_Martha is offline   Reply With Quote
Old 5th January 2009, 09:07   #52  |  Link
buzzqw
HDConvertToX author
you are using a very old mencoder build
i think that these optionts are not avaiable for you
":b_adapt=2" , set the b adapt to 1
"me=tesa" , set to a lower value
(or update the mencoder build...)
BHH
Old 5th January 2009, 17:01   #53  |  Link
buzzqw
HDConvertToX author
update both builds (win and linux)
better ffmpeg encoding
better ffmpeg path detection
added support for NO video encoding (will encode only audio)
BHH
Old 9th January 2009, 15:07   #54  |  Link
Crono141
Dumb question: Is it possible to get a PPC build for PS3 ubuntu?
Crono141 is offline   Reply With Quote
Old 9th January 2009, 15:20   #55  |  Link
buzzqw
HDConvertToX author
i can't compile for PPC sorry
but autox264 is FOOS, so if you have a license of purebasic you can compile
BHH
Old 10th January 2009, 10:36   #56  |  Link
buzzqw
HDConvertToX author
update to 0.13
update both builds, windows and linux
added support for encoding with x264 (via avisynth)
added support for decoding with avisynth (and encoding with x264) , using dgavcdec, ffmpegsource, directshowsource
added support for copy audio/copy video/no audio/no video
better encoding with ffmpeg
now autox264 is a multi encoder (x264/ffmpeg/mencoder) for h264 codec!
Old 13th January 2009, 20:58   #57  |  Link
Selur
Selur's Avatar
for windows&linux ?
Old 14th January 2009, 09:49   #58  |  Link
buzzqw
HDConvertToX author
for windows&linux ?
for both
if you download autox264 AND applications pack (first post) when you start the application, it will find automatically the new decoding/encoding capabilities
in case of use avisynth (dgavcdec or ffmpegsource or dss) mencoder is used only for audio encoding, while autox264 will build a minimal avisynth script (crop/resize/denoise/filtering as requested, and of course decoding with dg/ff/dss) and will encode with x264
it works for linux (under wine) too
BHH
Old 14th January 2009, 12:14   #59  |  Link
yeye69
Something wrong for me with latest version, can't analyze any source file
Old 14th January 2009, 14:12   #60  |  Link
buzzqw
HDConvertToX author
windows or linux ? if win..got the applications pack ?
what's source file ?
could you provide a sample ?
and last dumb question: have you hit "Analyze with..." ?
BHH
gui, linux, mencoder, windows, x264
