24th December 2012, 09:16 | #2881 | Link |
You are using an AVI input container. MeGUI currently cannot extract the audio track from that container and therefore it must be converted.
Workaround: Convert your file in a MKV with mkvmerge (MeGUI\tools\mkvmerge\mmg.exe - just drag & drop your file into it and hit "start muxing") Use this file as input in OneClick. |
24th December 2012, 13:16 | #2883 | Link | |
When I encode DVDs, avs contains (most used settings scenario): SetMemoryMax(1024) SetMTMode(5, 4) LoadPlugin("path\dgmpgdec158\DGDecode.dll") MPEG2Source(***) SetMTMode(2) QTGMC(settings) SelectEven() Crop() When I encode H.264, avs contains (most used settings scenario): LoadPlugin("path\ffms2.dll") FFVideoSource(***) Crop() spline36resize() Now I fail to see how the above avs scenarios could create dependencies with ac3filter, office groove, canon decoder and other seemingly random stuff. |
24th December 2012, 19:50 | #2886 | Link |
issues updating core (update bug?)
I am having an infinite loop of update notices for the core. Everything else updated correctly, but MeGUI keeps asking me to update core from 2153 to 2237, which I do, then it tells me MeGUI needs to restart. I say OK, but then it never starts up again, even if I wait an hour, lol. I finally manually restart and get same message.
I tried force reinstall as a context menu choice in the Update Window, but that didn't do anything differently. If I can get you more info to help fix this bug, please let me know. I just don't know what you may need. |
25th December 2012, 01:17 | #2888 | Link | |
As a workaround you can use the 2237 file from the sourceforge page and copy it over your installation. |
26th December 2012, 01:39 | #2889 | Link |
Had the same problem as djmasturbeat. Downloaded a fresh copy from sourceforge. When I run it, it automatically starts downloading updates for all components. The local date for every file is listed as 1/1/0001.
edit: Went back to an old version and disabled updates. Last edited by unknownsoldierX; 26th December 2012 at 01:46. |
26th December 2012, 05:22 | #2890 | Link |
I disabled all AV/spyware and issue persisted, so that was not the issue that I can perceive.
There was some errors about the file downloading, but unable to download, and then errors aboutbeing unable to unpack the zip then unable to delete the zip. I looked and the zip was in the cache, too. I watched it alternately at times use the main or backup server for update, both failed on core install. edit, here is one of the logs Code:
-[Information] [12/25/2012 5:13:44 PM] Updating core. File 1/3. --[Information] [12/25/2012 5:13:44 PM] Could not unzip C:\MeGUI\update_cache\megui-core_2237.zip. Deleting file. --[Error] [12/25/2012 5:13:44 PM] Could not delete file C:\MeGUI\update_cache\megui-core_2237.zip --[Error] [12/25/2012 5:13:44 PM] Failed to download file core with error: CouldNotDownloadFile. I finally deleted my MeGUI directory other than my profiles and jobs and logs, and just unpacked the newest build. For the record: pretty fresh install of Windows7x64, with barely anything installed yet, not even ffdshow/haali or LAVF, etc. Mostly just DVD Decrypter, a stand alone stable MPC-HC and some browsers and AV/spyware, and the stuff for Mobo (mostly drivers). I won't know if the bug persists till a new core is released for stable servers. I suppose this should have gone here top start with, since I am using a vanilla MeGUI now, and this seems like a bug for MeGUI http://forum.doom9.org/showthread.php?t=151159 apologies for misplaced post, but since I started it here, thought I would follow up here. Last edited by djmasturbeat; 26th December 2012 at 05:53. |
26th December 2012, 13:03 | #2892 | Link |
Knowing your script content would be useful to understand the reason for this issue. At least of the script line which contains this filter. But probably better the whole script, as it may depend on surrounding context.
29th December 2012, 21:38 | #2893 | Link | |
[Error] Log -[Information] Versions --[Information] [12/24/2012 10:20:50 AM] MeGUI: 2153 (svn) --[Information] [12/24/2012 10:20:50 AM] Operating System: Windows 7 Ultimate Edition x64 SP1 (6.1.65536.7601) --[Information] [12/24/2012 10:20:50 AM] .Net Framework: 4.0 (4.0.0.0) --[Information] [12/24/2012 10:20:50 AM] AviSynth: 2.5.8.5 (12/21/2008 9:46:54 PM) --[Information] [12/24/2012 10:20:50 AM] AvisynthWrapper: 1/2/2009 8:34:04 PM --[Information] [12/24/2012 10:20:50 AM] ICSharpCode.SharpZipLib: 0.85.5.452 (8/8/2008 2:31:12 AM) --[Information] [12/24/2012 10:20:50 AM] LinqBridge: 1.0.0.0 (5/28/2009 7:24:34 AM) --[Information] [12/24/2012 10:20:50 AM] MediaInfo: 0.7.61.0 (10/21/2012 4:29:05 PM) --[Information] [12/24/2012 10:20:50 AM] MediaInfoWrapper: 0.7.53.0 (8/23/2012 2:33:43 PM) --[Information] [12/24/2012 10:20:50 AM] MessageBoxExLib: 1.0.2218.28317 (12/20/2008 2:53:04 AM) --[Information] [12/24/2012 10:20:50 AM] SevenZipSharp: 0.64.3890.29348 (1/2/2011 4:59:32 PM) --[Information] [12/24/2012 10:20:50 AM] 7z: 9.20 (11/18/2010 10:27:34 PM) -[Error] Update detection --[Information] [12/24/2012 10:20:51 AM] Connecting to server: http://megui.org/auto/stable/ --[Information] [12/24/2012 10:20:52 AM] There is 1 file which can be updated. --[Information] [12/24/2012 10:24:05 AM] Updating core. File 1/1. --[Information] [12/24/2012 10:24:05 AM] Could not unzip C:\MeGUI\update_cache\megui-core_2237.zip. Deleting file. --[Error] [12/24/2012 10:24:05 AM] Could not delete file C:\MeGUI\update_cache\megui-core_2237.zip --[Error] [12/24/2012 10:24:05 AM] Failed to download file core with error: CouldNotDownloadFile. --[Information] [12/24/2012 10:24:05 AM] Update completed --[Error] [12/24/2012 10:24:05 AM] Files which have been not sucessfully updated: 1 Last edited by djmasturbeat; 29th December 2012 at 21:40. |
3rd January 2013, 13:25 | #2895 | Link | |
Means that even though I had avs installed and configured, megui still used its version. |
7th January 2013, 20:32 | #2897 | Link |
There is now a quite big leap in the version number of MP4Box used by MeGUI (from 0.4.6-DEV-rev2735 to 0.5.1-DEV-rev4234:4272M).
Was it just time to do something, or are there specific new features MeGUI will take care of now? |
8th January 2013, 10:12 | #2898 | Link |
Swallowed in the Sea
better apple devices support...
The last MP4Box version adds eac3 files support + mvc/svc + few others things (not supported into megui though). Last edited by Kurtnoise; 8th January 2013 at 10:20. |
8th January 2013, 12:56 | #2899 | Link |
hei i start encoding 4 mkv videos 2 of them have very similar size but the others have 150mb difrence i use oneclick encode and the settings are all the same the source is same for all and the size of source are similar why i have this problem last befor . why some files are much bigger than others? how can i fix this i want all have similar size i dont care about 10 mb but 100or150 is to high i user 2passencode with bitrate mode and i dont want to user filesize limit each time i want to encode is there any solution in settings to encode all files in similar size ?
