Old 19th April 2010, 18:08   #12541  |  Link
tetsuo55
MPC-HC Project Manager
Originally Posted by Polcius View Post
Anyone can shed some light? Or some documentation page about MPC-HC?
I just want to know what ticking the "Dynamic Range Control" exactly does, and how does it interfere with soundcard settings.
Sorry, most team members do not believe in post-processing and cannot answer your questions.
tetsuo55 is offline
Old 20th April 2010, 06:20   #12542  |  Link
iron2000
Questioning User
Will there be a fix soon for QT and Real compatibility with EVR Sync?
8 Pro x64 | i5-3470 | 8GB ram | GT430 | Xonar DX | MPC-HC x86
iron2000 is offline
Old 20th April 2010, 11:43   #12543  |  Link
hoborg
Originally Posted by hoborg View Post
Hi.
Is there plan to update MP4 splitter to support this sample ?
It is working with Haali, but only black screen using "MP4Splitter.ax".
Please alow me return to this problem.
This is little mystery to me, i am not sure where the problems can be.
If you play this sample in latest builds on MPC-HC, it will play normaly, but only if DXVA is off - you will have only black screen when using DXVA, but audio is OK and play.
some tests:
MP4Splitter.ax + MPC video decoder/FFDshow DXVA decoder (DXVA on) - Black screen
MP4Splitter.ax + MPC video decoder/FFDshow decoder (DXVA off) - working fine
Haali splitter + MPC video decoder/FFDshow DXVA decoder (DXVA on) - working fine
Haali splitter + MPC video decoder/FFDshow decoder (DXVA off) - working fine
Few MPC-HC version ago, it doesnot work even with DXVA off.
So, where the problem have roots, it is splitter or decoder problem?
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline
Old 20th April 2010, 12:13   #12544  |  Link
tetsuo55
We have some ideas here but nothing concrete.
some tests:
Does it also have a black screen if you mux it to mkv? If not then you can report the bug to bento4 http://bento4.sourceforge.net/
tetsuo55 is offline
Old 20th April 2010, 12:18   #12545  |  Link
hoborg
Yes, MKV works, and i already report that to bento4.
But i am not sure this is really splitter bug, becouse it woks if DXVA is off.
My HTPC.
hoborg is offline
Old 20th April 2010, 12:22   #12546  |  Link
tetsuo55
You can open a ticket on the mpc-hc tracker, and mention that you reported it upstream but that it only affects dxva so it might be a problem in mpc-hc's dxva decoder.
tetsuo55 is offline
Old 20th April 2010, 12:31   #12547  |  Link
hoborg
I think it already exist here:
http://sourceforge.net/apps/trac/mpc-hc/ticket/24
My HTPC.
hoborg is offline
Old 20th April 2010, 12:33   #12548  |  Link
tetsuo55
Add the information from and link to the bento4 ticket then.
tetsuo55 is offline
Old 20th April 2010, 12:39   #12549  |  Link
hoborg
Already done:
http://zebulon.bok.net/trac/Bento4/ticket/9
My HTPC.
hoborg is offline
Old 20th April 2010, 13:05   #12550  |  Link
tetsuo55
Add the link to that ticket to http://sourceforge.net/apps/trac/mpc-hc/ticket/24
tetsuo55 is offline
Old 20th April 2010, 13:17   #12551  |  Link
hoborg
Done...
My HTPC.
hoborg is offline
Old 20th April 2010, 15:54   #12552  |  Link
XhmikosR
Originally Posted by Aleksoid1978 View Post
I can compile MPC-HC with VS2010, but ... it's not stable and has bug in GUI(like without themes support).
Even after yesterday's commits I still cannot compile mpc-hc with MSVC 2010 successfully. I'm getting the following errors when linking mpc-hc:
Error 62 error LNK2019: unresolved external symbol __imp____lc_codepage referenced in function _wcsrtombs C:\Users\USER\Desktop\mpc-hc\src\apps\mplayerc\MPCVideoDecRU.lib(wcrtomb.o) mpc-hc
Error 63 error LNK2001: unresolved external symbol __imp____lc_codepage C:\Users\USER\Desktop\mpc-hc\src\apps\mplayerc\MPCVideoDecRU.lib(mbrtowc.o) mpc-hc
https://sourceforge.net/apps/trac/mp.../153#comment:9
Can you describe how exactly you solved these errors?
My Specs
XhmikosR is offline
Old 20th April 2010, 19:47   #12553  |  Link
gngn
the hedgehog
gngn's Avatar
rev1802 of MPC-HC introduced some seeking-problems with DXVA on and H264 files that have b_pyramid=2 (and "b-pyramid=normal" is now default in x264 since r1455 Feb 21 2010)
when seeking the image freezes (but sound continues, even the video-playback time goes on). after a few seconds showing that frozen frame playback will start, first very jerky, until it becomes normal.
problem is more pregnant with HaaliSplitter then with the internal matroska splitter.
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 21st April 2010, 01:05   #12554  |  Link
torpedo
@clsid:
The SSE optimization of ffMpeg compilation has been deprecated since svn 1792. The current optimization option is MMX. Why the optimization option was reverted to MMX?
torpedo is offline
Old 21st April 2010, 01:32   #12555  |  Link
Superb
http://forum.doom9.org/showthread.ph...08#post1339108
http://forum.doom9.org/showthread.ph...54#post1339154
mingwex points to a removed variable (Microsoft removed it in VS2010).
Superb is offline
Old 21st April 2010, 05:21   #12556  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Try this libmingwex.a - http://aleksoid.tosei.ru/Dist/lib/libmingwex.7z
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline
Old 21st April 2010, 05:40   #12557  |  Link
Superb
@Aleksoid1978: did you simply remove this symbol from the lib itself? or did you compile a new, fixed mingwex lib (which doesn't import this deprecated/removed variable)?
Superb is offline
Old 21st April 2010, 06:02   #12558  |  Link
Aleksoid1978
Just remove ... as here - http://ffmpeg.arrozcru.org/forum/vie....php?f=1&t=891
Old 21st April 2010, 06:37   #12559  |  Link
_xxl
ffdshow user
_xxl's Avatar
FFmpeg has hand written optimizations and doesn't need any forced SSE optimizations, will just make ffmpeg slower, that was proven years ago.
_xxl is offline
Old 21st April 2010, 07:41   #12560  |  Link
tetsuo55
that proof is no longer valid and will have to be re-tested.
tetsuo55 is offline
dxva, h264, home cinema, media player classic, mpc-hc
