Old 3rd December 2009, 19:42   #10701  |  Link
Mercury_22
Originally Posted by 73ChargerFan View Post
How can the trak wiki be edited? The URL in Part A #6 has a typo.
https://sourceforge.net/apps/trac/mp...ompile_the_MPC
Part B #4c & #4d both reference the same environment variable. Should they be together, like path?
Part B #3, the path has an extra space in it?
Part B #2, Alexins's Cross-Mingw.GCC Core - There are two versions, static or shared pthreads. Does it matter which is used?
Part A #1 - I'd rather not pay $300 for Dev Studio 2008 / Vis C++ 2008. Can Express be retrofitted with ATL & MFC, by copying headers or libraries?
Also in Part A 5) a) & b) wasn't supposed to be the paths for x64 too ?
And did someone manage to compile MPC-HC on a x64 OS (Windows 7) using just (exactly) this guide ?
Is it complete for a x64 OS ?
Windows 10 1803 x64, HD7790 Adrenalin 18.9.1, HDMI Full RGB 4:4:4
Mercury_22 is offline
Old 3rd December 2009, 21:49   #10702  |  Link
tetsuo55
MPC-HC Project Manager
Part A #6 - i dont see it, what do you mean exactly
Part B #4c & #4d - Nice catch, fixed
Part B #3 - It defines the path and variable, thats why there is a space
Part B #2 - I don't know what the difference between the two is.
Part A #1 - Its hardcoded to block those two.
Part A 5) a) & b) - x64 compilation is not in the new guide yet (still working out some stuff)
But yes, if you had the missing stuff it would compile for x64 OS (this guide is partly based on xvidvideo.ru compiling instructions from alexins)
tetsuo55 is offline
Old 4th December 2009, 13:59   #10703  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
I'd hazard a guess the "[[BR]]" in the URL (which, in it's current state, leads to an error page on Microsoft's site) is the problem here...
now playing: [artist] - [track] ([album])
Leak is offline
Old 4th December 2009, 14:37   #10704  |  Link
XhmikosR
Originally Posted by Bumsfalara View Post
Downloading subtitles with Revisions 1373 and 1378 is not possible, I always get some kind of "seek-error".
Switched back to 1369, which is working fine.
It happens randomly and I reproduced once with 1378 but next time without changing anything, I couldn't. I think this error is caused by opensubtitles.org being overloaded at that time, and has nothing to do with unrar update in rev1372.
If you actually rename vsEDEE.tmp to vsEDEE.htm and open it with your browser you'll see this, which is a javascript:
Παρασκευή, 4 Δεκέμβριος 2009 15:35:48
OpenSubtitles.org is overloaded
We are sorry, but our servers are overloaded (error 500). Please reload page or wait 11.3 seconds.
We are working on fix. Thanks for understanding.
My Specs
XhmikosR is offline
Old 4th December 2009, 15:13   #10705  |  Link
seabro
Follow this steps then report back :
http://sourceforge.net/apps/trac/mpc...ing_guidelines
Nothing.. same stuff!! DXVA still not working!
seabro is offline
Old 4th December 2009, 18:17   #10706  |  Link
tetsuo55
the case of the missing space.
Fixed
tetsuo55 is offline
Old 4th December 2009, 18:20   #10707  |  Link
tetsuo55
show us the screenshots asked for in the bug report portion of that link, also upload a sample.
tetsuo55 is offline
Old 4th December 2009, 23:40   #10708  |  Link
DeepBeepMeep
DeepBeepMeep - The built in splitters will render all audio tracks, and has an Audio Switcher to switch between them. Make sure it is enabled under options; then while playing, right click and use the Audio submenu to change tracks.
Thanks for the info. I know now why I had two audio switchers: I was forcing to add to the graph ffdshow audio Processor instead of ffdshow audio Decoder.
I have a solution now. But there is obviously an inconsistency between the internal splitters: the TS splitter has its own audio switcher. This means one has to disable the internal audio switcher whenever one plays a ts file and enables it to play a mkv file, this is not very convenient.
DeepBeepMeep is offline
Old 5th December 2009, 13:02   #10709  |  Link
blenky
This is one HUGE thread so apoligies if this question has been ask (many time) before.
Looking at getting an ASrock 330 and installing W7/XBMC/MPC-HC.
Currently I have the Popcorn Hour media player which is very good at setting the correct refresh on my TV based on the video source setting the TV to 24hz for blu ray, 50hz for PAL etc.
How is this achieved using MPC-HC?
Thanks in advance.
blenky is offline
Old 5th December 2009, 21:45   #10710  |  Link
ikarad
Originally Posted by BatKnight View Post
I've noticed that when playing a full Bluray disc using MPC's internal TS splitter the subtitles (presentation graphics, I think) aren't recognized. It shows: no subtitles.
But when using Haali Media Splitter, it shows the subtitles.
Is support for presentation graphics subtitles in the to-do list of MPC-HC, or am I missing something?
Auto-answer: I was missing something, because now it show the subtitles... Sorry for this post.
2nd EDIT: Looks like some m2ts shows with internal filter but others don't, so my first statement is right
3rd EDIT: After all, the subtitles show, but they take long seconds before they do, and I was misleaded into believe they werent' showing
Thanks
Bat
There are many bugs with blu-ray subtitle not corrected. We must wait but Tetsuo55 told that it's not a priority. I hope these bugs will be corrected in 2010 before 2011.
For myself, It is the only bugs that I meet with MPc-HC since one year (2008).
ikarad is offline
Old 6th December 2009, 13:37   #10711  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
to xhmikosr:
i think you beark someting code form mpc-hc!
Revision 1367 - Directory Listing
Modified Sat Nov 28 21:58:29 2009 UTC (7 days, 14 hours ago) by Spec-Chum
Added /GS, /NXCOMPACT and /DYNAMICBASE to filters pt2 (XhmikosR)
Revision 1366 - Directory Listing
Modified Sat Nov 28 21:04:28 2009 UTC (7 days, 15 hours ago) by Spec-Chum
Added /GS, /NXCOMPACT and /DYNAMICBASE compile options, where available (XhmikosR)
to all mpc-hc develop pls look this bug repot:https://sourceforge.net/apps/trac/mpc-hc/ticket/152 i think this bug not for my used video codec and media Splitter.
beacause i use other player or use mpc-hc 1356 or use he biuld for my test3 play is fine (use same video codec same media Splitter) ! and he say:Then the change that caused your crash is the /GS, /NXCOMPACT and /DYNAMICBASE switches compiler switches.
betaking is offline
Old 6th December 2009, 14:39   #10712  |  Link
boyumeow
boyumeow's Avatar
Hi, I got PDM.Keylogger (kernel mode memory patch) detected by Kaspersky, just need to confirm its alright in MPC-HC r1393, was it cause by the new "Capture" thingy? Thanks.
boyumeow is offline
Old 6th December 2009, 14:44   #10713  |  Link
tetsuo55
Originally Posted by betaking View Post
to xhmikosr:
Hi, you misunderstand.
There is no new bug, instead the existing bug that was hidden before has become visable now and has to be fixed.
We are not sure yet if that bug is in elecard or in mpc-hc
To be clear, the problem is unrelated to that commit, but that commit exposes the problem.
tetsuo55 is offline
Old 6th December 2009, 14:58   #10714  |  Link
betaking
betaking's Avatar
sorry ,but problem not happen other player(zoomplayer) or mpc-hc 1356!
betaking is offline
Old 6th December 2009, 15:03   #10715  |  Link
tetsuo55
like i said in the bug report, the change you mentioned "reveals" the bug. This bug has always been there but was never discovered before this.
The only question now is, is elecard killing mpc-hc or is mpc-hc killing elecard.
For this we will need a debug-symbols build from casimir.
tetsuo55 is offline
Old 7th December 2009, 05:47   #10716  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic HomeCinema (x86/x64), svn 1400
Supported languages: BR, BY, CN, CZ, DE, EN, ES, FR, HU, IT, KR, PL, RU, SE, SK, TR, UA
Changes log
(1394-1400)
Fixed : blank item for appcommand;
Added : support of Broadcom Video decoder for VC1, H264 and Mpeg2 (hardware acceleration);
Moved "Show OSD" option to Player page;
Updated MinGW32 link in compilation instructions;
Advise Show OSD option requires MPC-HC to be restarte;
Updated resources to reflect the latest "Show OSD" changes;
Increased the size of the "Show OSD" box for all resources;
Updated the two Chinese resources to reflect the latest changes.
Win10 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX Vega 64,TV Philips 40PFS6909/12, MED1000X3D
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline
Old 7th December 2009, 07:08   #10717  |  Link
Snowknight26
Ctrl+C and File->Close change the main window form to different sizes.
Snowknight26 is offline
Old 7th December 2009, 09:46   #10718  |  Link
betaking
betaking's Avatar
can not compilation last mpc-hc
mplayerc.cpp
.\TunerScanDlg.cpp : warning C4819: 该文件包含不能在当前代码页(936)中表示的字符。请将该文件保存为 Unicode 格式以防止数据丢失
.\TunerScanDlg.cpp(40) : error C2001: 常量中有换行符
.\TunerScanDlg.cpp(40) : fatal error C1057: 宏展开中遇到意外的文件结束
MainFrm.cpp
.\mplayerc.cpp(1274) : error C2065: “IDS_NAVIGATE_TUNERSCAN”: 未声明的标识符
.\MainFrm.cpp(7825) : error C2121: “#”: 无效字符 : 可能是宏展开的结果
.\MainFrm.cpp(7825) : error C2146: 语法错误 : 缺少“)”(在标识符“㴊㴽㴽㴽”的前面)
.\MainFrm.cpp(7825) : error C2059: 语法错误 : “)”
.\MainFrm.cpp(7832) : error C2121: “#”: 无效字符 : 可能是宏展开的结果
.\MainFrm.cpp(7832) : error C2146: 语法错误 : 缺少“)”(在标识符“㴊㴽㴽㴽”的前面)
.\MainFrm.cpp(7832) : error C2059: 语法错误 : “)”
betaking is offline
Old 7th December 2009, 10:12   #10719  |  Link
betaking
betaking's Avatar
new bug repot
today my frinend use mpc-hc 1400 and add haali media Spiltter to external Filters and mpc-hc play some mkv files is crash !but he use mpc-hc 1356 play is fine not crash setting is same ! you can download Capture picture at here!
http://h.imagehost.org/download/0992/Desktop_6
betaking is offline
Old 7th December 2009, 10:56   #10720  |  Link
tetsuo55
mplayerc.cpp
MainFrm.cpp
all those errors are caused by codepage problems, are you using unicode?
new bug repot
Judging from the last screenshot memory was completely corrupted.
Are you sure your friend isn't infected with a virus/trojan/rootkit?
Is he using windows 7?
tetsuo55 is offline
dxva, h264, home cinema, media player classic, mpc-hc
