Old 1st November 2009, 13:37   #10301  |  Link
tetsuo55
MPC-HC Project Manager
Originally Posted by ikarad View Post
could you explain how I post bug on the tracker because I don't understand how to do? it's very difficult
Go to this page: http://sourceforge.net/apps/trac/mpc-hc/newticket
Fill in the fields as best as you can.
make sure you used the troubleshooting guidelines before posting
: http://sourceforge.net/apps/trac/mpc...ing_guidelines
tetsuo55 is offline
Old 1st November 2009, 14:10   #10302  |  Link
Polcius
Has anyone found a way to: Cyberlink MPEG-2 decoder when DXVA is enabled + Subtitles?
I'm really interested in that combination. Any fix/alternative to use DXVA+Subs wil help.
Polcius is offline
Old 1st November 2009, 15:03   #10303  |  Link
tetsuo55
simply enabling the built in subtitle renderer will solve your problem afaik
tetsuo55 is offline
Old 1st November 2009, 17:24   #10304  |  Link
JaDz
Originally Posted by Snowknight26 View Post
MPC-HC now tries to play all H.264 content with DXVA regardless of resolution/refs and causes noticable corruption in the video and occasionally on the desktop.
Same here. Windows 7, ATI 4850.
JaDz is offline
Old 1st November 2009, 19:41   #10305  |  Link
Polcius
No, it doesn't work.
Polcius is offline
Old 1st November 2009, 20:02   #10306  |  Link
clsid
You need to disable DXVA in the Cyberlink decoder or use the internal MPEG-2 decoder.
clsid is offline
Old 1st November 2009, 20:57   #10307  |  Link
gngn
the hedgehog
gngn's Avatar
works fine here. the usual settings for DXVA on XP: VMR9renderless as output renderer, the internal subtitles renderer on.
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 1st November 2009, 23:06   #10308  |  Link
Polcius
Yes but if I do that I can't use DXVA in the internal MPEG2 decoder.
gngn, I don't fully understand this graph XD
Polcius is offline
Old 2nd November 2009, 00:07   #10309  |  Link
gngn
the hedgehog
gngn's Avatar
admittedly, "that" graph was pretty much pointless
i put up a new screenshot to show that DVD-subs + DXVA (in my case mpeg2-IDCT) works on XP. dunno about win7 thou
gngn is offline
Old 2nd November 2009, 01:15   #10310  |  Link
Polcius
But do you use any special settings in MPC-HC? (I mean, "not default")
Polcius is offline
Old 2nd November 2009, 05:49   #10311  |  Link
GrofLuigi
Member of a Library
What is SPCDisableAnim=1 in ini file?
GL
GrofLuigi is offline
Old 2nd November 2009, 05:50   #10312  |  Link
namaiki
In options -> subtitles -> disable animation (is ticked).
If auto-load subtitles is checked in playback, the internal subtitle renderer is enabled and then soft subtitle animation like karaoke will stay still on the screen.
namaiki is offline
Old 2nd November 2009, 06:30   #10313  |  Link
boyumeow
boyumeow's Avatar
MPC-HC 1326
Изменения/Changes:
* CHANGED: Allow screensaver to activate when audio only (sleep is still stopped).;
Hi, I need someone to confirm that the above status not only allow screensaver to activate when audio only but happens when video too. Thanks.
boyumeow is offline
Old 2nd November 2009, 07:34   #10314  |  Link
Tenki
Two problems in this version right now.
Two problems in this version (1326) right now.
1.If I use DXVA, VobSub won't run, so I can't see any subtitles.
(this problem is since 130x, the previous version are ok.)
DXVA off:
http://img97.imageshack.us/img97/4628/nodxva.jpg
DXVA on:
http://img3.imageshack.us/img3/2817/dxva.jpg
You can see The DirectVobSub are disappear when DXVA run.
2. If I use MPC-HC to play DVD, MPC-HC can't change other subtitles when playing.
Tenki is offline
Old 2nd November 2009, 07:42   #10315  |  Link
namaiki
Tenki, you need to enable 'auto-load subtitles' and use the internal subtitle renderer if you want to use DXVA.
In MPC-HC, View -> Options -> Playback -> and make sure there is a tick next to 'auto-load subtitles'.
namaiki is offline
Old 2nd November 2009, 07:42   #10316  |  Link
73ChargerFan
73ChargerFan's Avatar
I'd like copies of older mpc-hc releases, svn 1180 through 1235 or so.
If anyone has one or more, please pm me. Thanks.
73ChargerFan is offline
Old 2nd November 2009, 08:43   #10317  |  Link
Snowknight26
When no DX9 compatible device (no video card) is installed in a machine running MPC-HC, several errors are throw:
EVR: CreateDevice failed, DX9AllocatorPresenter failed, D3DERR_NOTAVAILABLE
VMR9: CreateDevice failed, D3DERR_NOTAVAILABLE
VMR7: No video
Overlay: No video
Old renderer: Crash <-- shouldn't happen
System default (Video Renderer): No video
Should at least get video as it works fine in graphedit using Video Renderer.
Snowknight26 is offline
Old 2nd November 2009, 09:08   #10318  |  Link
namaiki
VMR7: No video
Overlay: No video
Just curious, but what video card and OS?
namaiki is offline
Old 2nd November 2009, 10:25   #10319  |  Link
Tenki
namaiki, thank you.
But it only solve the first problem.
If I use MPC-HC to play DVD (file-> open disk), MPC-HC still can't change other subtitles when playing.
Tenki is offline
Old 2nd November 2009, 10:39   #10320  |  Link
namaiki
Tenki, in 'Navigate -> Subtitle Language', what options do you see there when playing that DVD?
namaiki is offline
dxva, h264, home cinema, media player classic, mpc-hc
