13th December 2008, 06:36 | #5181 | Link | |
Also what CPU do you have (because i think it's too slow for 22mbits of h.264 thus why you have your problem) |
13th December 2008, 07:05 | #5182 | Link |
Can anyone verify the latest (from sourceforge) MPCVideoDec.ax x64 works with WMP x64 or Vista Media Center x64? work
Thanks Edit: it does work, however in my case it was conflicting with other codec's see here
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server Last edited by Emp3r0r; 15th December 2008 at 06:31. |
13th December 2008, 10:04 | #5184 | Link |
1) There is a bug with MPC home cinema under VISTA home premium 32bits and subtitles.
I use mpc home cinema (1.2.908)+ vobusb (2.38) to see subtitles. Under XP there isn't delay between video and subtitles but under vista there is nearly two seconds (1.6 seconds precisely). I notice that when i launch .vob files (or .ifo file which miss pub) instead of using "launch dvd function" there isn't delay between video and subtitles under vista but when I use "launch dvd function" under vista there is a delay of two seconds and consequently subtitles are delayed. I try all version of mpc home cinema but there is the same problem. I would like to know if this bug is known and if this bug will be corrected in a new version of mpc home cinema. I try with two différent PC under vista and there is the same problem. 2) the support of M2TS presentation graphics streams is buggued with subtitle in some blu-ray disc like japan anime. Even with the last official version (1.2.908) of MPC HC some subtitles aren't displayed. I would like to known if these bugs will be corrected in a new version. Thanks. (excuse me for my bad english) Last edited by ikarad; 13th December 2008 at 10:11. |
13th December 2008, 10:13 | #5185 | Link |
Easy feature request
Hi Developers,
1) thanx for the great work 2) a fantastic feature would be to choose whether the controls in fullscreen mode are at the bottom (as they are now) or at the top. Me and a couple of friends have the problem that we have some speakers slightly in the 16x9 frame. This of course makes using the controls hard. We used Zoomplayer where you are rather flexible in configuring the user interface. But the only really necessary function would be the possibility to display the controls and seek bar at the top instead of the bottom. That would finally enable us to ditch zoomplayer and go full open source! regards, Casshern |
13th December 2008, 12:26 | #5186 | Link | |
- open the M2TS - select all elementary streams - select "blu ray" as output - enter some trim duration to have 1mn of video with subtitles inside - upload sample to zshare or something
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
13th December 2008, 14:46 | #5187 | Link |
MPC-BE DEV
Media Player Classic HomeCinema (x86), svn 922
Media Player Classic HomeCinema (x64), svn 922 Supported languages: CN, CZ, DE, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA Changes log CHANGED: Hotkeys added to support more remote control keys; FIXED : Save thumbnails crash in x64; CHANGED: Support for Theora in Matroska internal splitter
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
13th December 2008, 15:45 | #5188 | Link |
Thanks for the response. Definitely DXVA, usually 10% or under CPU when using the mpcvideo filter. Note the cpu has no issues with the raw H264 stream, or similar bitrate H264 files created from blu ray rips, and the CPU is powerful enough to play the movie in software mode with Coreavc filter. It's a dual core Opteron @2.4 Ghz.
13th December 2008, 18:07 | #5189 | Link | |
http://www.zshare.net/download/5268802709403859/ the other link is a txt file with all subtitles (1 kB) http://www.zshare.net/download/5268532167381f2b/ Last edited by ikarad; 13th December 2008 at 18:10. |
13th December 2008, 20:42 | #5190 | Link | |
13th December 2008, 21:33 | #5191 | Link |
the hedgehog
i downloaded the sample and the test-build, it worked, but: i had to select the subtitles from the splitters menu, they weren't loaded, and i got some weird OSD display and not the subtitles:
after going fullscreen the subtitles were displayed properly. with Haali splitter i dont get audio+subs with this sample, but it works with the internal splitter of MPC-HC
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on |
13th December 2008, 22:41 | #5192 | Link | |
In the video I gave you, there is one case: - 5 subtitles are displayed with a noticeable delay (ie. They start later than expected, however they end exactly as they should), ** In the 1min video I gave you, here are the subtitles which start with a delay: “8 00:00:12,679 --> 00:00:15,148 Just relax and sleep .” “13 00:00:41,641 --> 00:00:44,644 My name's Eluluu.” “15 00:00:47,714 --> 00:00:50,984 And this is my house .” “17 00:00:52,986 --> 00:00:57,323 Well , I found you collapsed in the forest.” “21 00:01:03,630 --> 00:01:07,133 You're through the worst of it, that's what Grandma says.” EDIT: I made a mistake, I have said that one subtitle ends sooner than expected but it is wrong. In fact the original subtitle ends really slightly before the character stops speaking, this has leading me to make this mistake. Last edited by ikarad; 13th December 2008 at 23:36. |
14th December 2008, 06:14 | #5194 | Link |
mpc-hc needs to revert to ffmpeg if its over or under level 4.1 with 3-4refs on 1080p and 5-8refs on 720p i think it was
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview) "Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat |
14th December 2008, 11:53 | #5195 | Link |
HD2400Pro with MPC HC DVXA1 (WinXPsp3) => EVR works but with issues
Bonjour Casimir; hi all!
I am using MPC HC h264 (1080p@24fps in this case) Internal Decoder on both: (1) -> HD2400 => VGA => CRT Monitor (2) -> HD2400 => DVI->HDMI => LCD HDTV With (1) VGA, I can use either: -> VMR9 DXVA1 => GPU @ 30% -> Haali Renderer DXVA1 => GPU @ 4% -> EVR Custom DXVA1 => GPU @ 4% With (2) DVI->HDMI, I can use only: -> VMR9 DXVA1 => GPU @ 30% abd I have black screen for: -> Haali Renderer DXVA1 => GPU @ 0% -> EVR Custom DXVA1 => GPU @ 0% With DXVA1 disabled, HDTV display is just fine and I can use either VMR9, Haali Renderer and EVR. Can't find out why I can't EVR-DXVA1 on my DVI->HDMI HDTV Screen. Have any idea why and how to have EVR on my HDTV? Also, how can it be VMR9 uses about 10 times more GPU than Haali Renderer and EVR (all Pixel Shader disabled always)? Thanks for any help you could provide me :-) Note: I use RivaTuner to monitor GPU usage.
3GHz P4 DualCore, 2GB RAM, ATi HD2400Pro DVI/HDMI, Catalyst 9.4, Win XP MCE2005 sp3, Samsung 37" full-HD, x264, MPC-HC r1120 |
14th December 2008, 12:31 | #5196 | Link |
Under XP don't work EVR+DXVA1. EVR work only in Vista, DXVA2. With Haali render DXVA not work.
Under XP you must use VMR9 for DXVA1 is work.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
14th December 2008, 13:59 | #5197 | Link |
Otaku
I think that DXVA does not use the GPU like a game uses because the DXVA/Hardware video decoding is DSP core logic inside the GPU, so those values are not related to video decoding.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
14th December 2008, 14:53 | #5198 | Link |
Thanks. Right, it is not possible to DXVA1 with EVR on my DVI->HDMI=>HDTV; at least for me, yet. But...
Still, the fact is I can do very nice and low power use on GPU DXVA1 with EVR or "Haali Renderer" / WinXP when I display the image on VGA. Makes me think there could be a limitation with DXVA to HDTV. Ever heard of that? And any solution if any?
3GHz P4 DualCore, 2GB RAM, ATi HD2400Pro DVI/HDMI, Catalyst 9.4, Win XP MCE2005 sp3, Samsung 37" full-HD, x264, MPC-HC r1120 Last edited by azulazules; 14th December 2008 at 17:09. |
14th December 2008, 15:41 | #5200 | Link | |
Casimir already tried to fix it, but the problem lies inside the RealMedia SDK, which is very old. So if you want it to be fixed, go ask RealNetworks to release an updated SDK.
MPC-HC 2.1.7.2 |
