27th March 2009, 09:51 | #8623 | Link | |
User of free A/V tools
eac3to FLAC compression
How to make FLAC CLI encodes bit-to-bit identical with eac3to First download the latest FLAC library package and replace libFLAC.dll in the eac3to folder with the downloaded one. Run your CLI encoder with the following options: Code:
flac.exe --best --no-seektable --no-padding --tag=WAVEFORMATEXTENSIBLE_CHANNEL_MASK=0X0 --tag=VALID_BITS=16 --tag=HDCD=0 inputfile.wav Last edited by kypec; 27th March 2009 at 10:34. Reason: Workaround found |
27th March 2009, 15:38 | #8624 | Link |
Duplicate Subtitle Tracks
When extracting from a VOB, EAC3TO 3.14 is frequently outputing duplicate subtitle tracks - for instance
Movie - 6 - Subtitle (DVD), 1857 captions.sup and Movie - 6 - Subtitle (DVD).sup The two files have identical contents. The command line is EAC3TO vts_01_1.vob+vts_01_2.vob+vts_01_3.vob+vts_01_4.vob+vts_01_5.vob+vts_01_6.vob Movie.mkv -seekToIFrames -lowPriority |
28th March 2009, 02:44 | #8626 | Link |
Hi madshi.
Could you please take a look at this file. http://d01.megashares.com/?d01=72e4388 It's recorded from DTV. It has 5.1 channels during main broadcast and switches to 2.0 channel during the ad breaks. Converting to flac results in the audio during the ad breaks being high pitched.
http://www.7-zip.org/ |
28th March 2009, 16:35 | #8627 | Link | |
Are you sure the audio is not being corrupted somewhere in your avisynth / soundout chain? If you convert your target flacs back to wav are they identical? |
29th March 2009, 09:27 | #8629 | Link |
Sorry to bother, some eac3to -decodeHdcd questions ;
Any reason to why eac3to with -decodeHdcd switch gets 6 dB gain lower than standard decoding ? If so, is it OK to add +6dB as a switch while doing conversions ? Madshi, Is there a possibility to add -deEmphasis switch option to eac3to ? Best regards, narshorn narshorn |
29th March 2009, 10:09 | #8630 | Link | |||||||||
Argh, why did nobody tell me before!? It makes things much simpler... Quote:
AC3 encoding is only supports with 5.1 and 2.0 right now. Other formats will be supported in a future version. Quote:
IIRC this movie had several playlists. The main playlist has messed up audio. Try some of the other playlists. At least one of them works fine. This is a mastering problem, not an eac3to bug. |
29th March 2009, 10:59 | #8631 | Link | |
Clown_BD handles this.... see here Code:
[a06] Creating file "C:\Temp\Batman Begins\Audio_6_English.THD+AC3"... Code:
A_AC3, "C:\Temp\Batman Begins\Audio_6_English DELAY 200ms.THD+AC3", timeshift=200ms, lang=eng
Blu-Ray Movie Only Copies : Clown_BD Blu-Ray Movie Only DVD Conversion : Clown_BD Blu-Ray Copies With Menus : Clown_BD BD Copier Last edited by mrr19121970; 29th March 2009 at 11:09. |
29th March 2009, 11:33 | #8632 | Link | |||||||||||||
(1) Does the DTS decoder still work for eac3to? (2) Does it handle those 7.1 DTS-MA tracks with funny speaker placement correctly? That was the only thing that could be improved. Apart from this the old ArcSoft DTS decoder was already pretty perfect. Quote:
29th March 2009, 11:56 | #8633 | Link | ||||||||
If you can find a good reason for that? It's still on my to do list... Quote:
Nice! |
29th March 2009, 12:02 | #8634 | Link |
eac3to v3.15 released
http://madshi.net/eac3to.zip Code:
* "24.975" is now interpreted as "25.000/1.001" * Blu-Ray "sup" are demuxed with DTS set to 0 again, proper fix will come later * fixed: error code not set for "source file format could not be detected" * fixed: audio resampling from/to 24.975 didn't work properly * fixed: WAV files beginning with lots of zeroes were sometimes not accepted |
29th March 2009, 13:05 | #8635 | Link | |
29th March 2009, 13:47 | #8638 | Link | |
If you want to convert those sup files to SRT, there's no problem. If you want to remux them into a m2ts structure, then with some movies the current sup files produced by eac3to won't display correctly on some standalone players. |
eac3to |
