Old 3rd July 2018, 05:22   #1  |  Link
enable
how cut/split TVShow episodes in one file m2ts
hi everybody
i bought bluray disk from a tvshow and i want to encode it.
but every 4-5 episodes in one disk.
how can i split or cut every episode with MEGUI?
https://imgur.com/sSmxZz1
https://imgur.com/Zn5fcvr
https://imgur.com/ftNq3R5
enable is offline   Reply With Quote
Old 4th July 2018, 03:04   #2  |  Link
kuchikirukia
MakeMKV can split it if it's authored properly. If not it should at least give you a single mkv with chapters, and you can throw it in MKVToolnix GUI and split on the relevant chapters.
I find it easiest to get the source split properly and encode from there rather than spend time fussing with frame numbers to use trim.
kuchikirukia is offline   Reply With Quote
Old 6th July 2018, 23:52   #3  |  Link
hello_hello
MeGUI has an AVS Cutter under the tools menu if you can't extract the video as individual episodes. If you want to join encodes later, make sure --stitchable is included in the x264 command line.
Old 28th July 2018, 22:53   #4  |  Link
enable
thanks guys
i use TSMuxer and take chapter lists and ok that.
m2ts megui
