13th October 2018, 15:32 | #8648 | Link |
Reason is that File\Exit has also the shutcut ctrl+x. Potentially I could change all other relevant controls to ignore that, however easier is to simply remove the File\Exit option completly. I assume nobody is using that to close MeGUI.
EDIT: or better: I have changed it from ctrl+x to alt+f4 Last edited by Zathor; 13th October 2018 at 15:39. |
13th October 2018, 16:47 | #8649 | Link |
Speaking of cutting and pasting, would it be hard to endow the script creator with more than one "undo" level?
Currently right click and "undo" reverts the last change to any text entered under the script tab, but a second right click and "undo" effectively becomes "re-do". It'd also be nice if after changing something via the GUI (cropping or resizing etc) you could switch to the script tab and "undo" the changes MeGUI made to the script, although maybe that's wishful thinking. It'd be nice to have more than one undo level when manually editing a script though. The more the merrier, really. Cheers. |
28th October 2018, 19:03 | #8651 | Link |
Under the FFMpeg AC-3 configuration dialog, I often use the Time Modification option to slow down with pitch correction from 25 to 24 FPS. I would like to know if it's possible to do the same but using other custom FPS. For example, at the moment I'd like a 22 to 20 time modification, with pitch correction. I guess one can achieve this using the command line in the "Extra" tab, but I don't know how to do it or where exactly to look for it. Thanks!
28th October 2018, 21:07 | #8652 | Link |
Try either of these in the custom command line section (for ffmpeg). I'm not sure which is the better quality.
-af "atempo='20.0/22.0'" -af "rubberband=tempo='20.0/22.0'" Or try this script. https://forum.videohelp.com/threads/...ioSpeed-script AudioSpeed(20,22, PitchCorrect=true) There's a newer version here. I haven't uploaded it to the thread yet. Maybe I forgot, or hadn't tested it much. I can't remember. Not that much can go wrong. AudioSpeed 2018-06-29.zip |
31st October 2018, 01:11 | #8655 | Link |
@ Octo-puss:
Prerequisite would be learning AviSynth. The installation of the legacy version 2.6.0 contains a quite good introduction guide as set of HTML pages (you will want to restore a more modern installation of an MT version afterwards, possibly even AviSynth+); I did not check if it is also contained in a source archive, in this case you may be able to avoid an installation. StainlessS also offers the documentation as a CHM file (reading that in a modern Windows may require the installation of some WinHelp32 tools, but its advantage is being a compact archive, and you don't have to install a legacy version just to get the documentation). To rotate the video left or right by 90°, you can use the Turn filters; Turn180() creates a result equal to both Flip filters in a sequence: FlipHorizontal().FlipVertical(); rotating arbitrary angles is more complex and will require a plugin. __ @ imsrk48: Improving the subjective visual quality is an extremely complex field of video filtering which requires a separate thread. It is also independent of the used converter (whether MeGUI or any other AviSynth based tools), but it depends a lot on attributes of each different source file. It's not a topic for this thread. Except for activating filters already provided explicitly, like some noise filter presets in the AVS Script Creator. Last edited by LigH; 31st October 2018 at 01:14. |
31st October 2018, 01:58 | #8656 | Link | |
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st October 2018 at 02:28. |
31st October 2018, 05:53 | #8657 | Link | |
can i use noise filter for improve quality?
which is best filter. Quote:
31st October 2018, 06:48 | #8658 | Link |
No useless full-quotes, please, they are a waste of space.
No filter ever will repair a ruined video. Lost is gone. CSI-like restoration is a lie. There are ways to make the loss look less annoying, but again: This is not the thread to discuss this huge topic. Make a new one, and provide video samples of the video clip you want to have improved (not just single screenshots). |
31st October 2018, 13:46 | #8659 | Link | |
So I need to download some extra .dlls for this functionality? |
31st October 2018, 13:55 | #8660 | Link | ||
Assist in learning avisynth scripting. Quote:
but rotation by some other non multiple of 90 degrees would require external plugin.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st October 2018 at 14:00. |
megui |
