Old 25th September 2014, 02:19   #21  |  Link
lansing
is there going to be a 64 bit version for this plugin?
Old 25th September 2014, 10:29   #22  |  Link
jackoneill
unsigned int
jackoneill's Avatar
There is now.
http://uloz.to/x6gvxpbB/scenechange-win64-7z
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 25th September 2014, 16:52   #23  |  Link
lansing
Originally Posted by jackoneill View Post
Thanks for the quick update
Old 26th July 2015, 22:50   #24  |  Link
jose1711
hi, is this the correct place to report build issues for this plugin?
jose1711 is offline   Reply With Quote
Old 27th July 2015, 07:17   #25  |  Link
jackoneill
unsigned int
jackoneill's Avatar
It is.
Old 16th January 2016, 20:16   #26  |  Link
an3k
an3k's Avatar
What's the difference between the included libtemporalsoften2 and jackoneills https://github.com/dubhater/vapoursynth-temporalsoften ? Do I get any interference when both are installed? If so which one should be used?
an3k is offline   Reply With Quote
Old 16th January 2016, 21:21   #27  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
It's exactly the same
Myrsloik is offline   Reply With Quote
Old 16th January 2016, 21:26   #28  |  Link
jackoneill
unsigned int
jackoneill's Avatar
There is no interference. Chikuzen's version should be faster. Maybe it has additional functionality as well. I don't remember.
Old 8th August 2017, 03:18   #29  |  Link
lansing
How do I get all the frame numbers of the start of the scene change?
Old 9th August 2017, 01:20   #30  |  Link
VS_Fan
This should do the trick:
import vapoursynth as vs
core = vs.get_core()
ret = core.ffms2.Source(source="video file name")
#ret = core.scd.Detect(clip=ret, thresh=40, log="SC_SCD.TXT")#, interval_h, interval_v)
ret = core.misc.SCDetect(clip=ret, threshold=0.15)
fstats = open ('SC.txt', 'w', encoding='utf-8', errors='strict')
fstats.write('frame_no\n')
for i in range (ret.num_frames):
    if ret.get_frame(i).props._SceneChangePrev == 1 :
        fstats.write('{}\n'.format(i))
fstats.close()
ret=core.text.FrameProps(clip=ret, alignment=3)#, props
ret.set_output()
It will scan the whole video, create the 'SC.txt' text file, write to it the list of frames detected by the misc.SCDetect filter as start of a scene change, then it will close the file when finished and only after that it will show any video if run from vsedit.
So give it a while, and when it finishes, rename or copy your new 'SC.txt' text file with the frame numbers to avoid rewritting it.
VS_Fan is offline   Reply With Quote
Old 9th August 2017, 15:18   #31  |  Link
lansing
What is the difference between this scene change detection filter and the one in the misc? Right now I'm using the loop from the documentation to loop through the video, which way is faster?
clip = core.scd.Detect(clip, thresh=25)
for frame in clip.frames():
    if frame.props._SceneChangePrev == 1 and frame.props._SceneChangeNext == 0:
        frame_num = round(frame.props._AbsoluteTime * clip.fps)
        #do stuff
Old 9th August 2017, 15:33   #32  |  Link
Myrsloik
Myrsloik's Avatar
        #do stuff
The misc version is basically a faster replacement of the scd version. It should behave identically.
That's a really awkward way of writing things:
clip = ...
for n in range(length(clip)):
    frame = clip.get_frame(n)
    if frame.props['_SceneChangePrev'] == 1 and frame.props['_SceneChangeNext'] == 0:
        frame_num = n
        #do stuff
And another note about speed. Any script that can be run through vspipe will be faster due to multiple frame requests being possible at once.
Old 10th August 2017, 03:28   #33  |  Link
lansing
um both filters didn't do well on scene change in darker areas, I have to set threshold to 0.02 in order to see them.
Old 10th August 2017, 15:12   #34  |  Link
Myrsloik
Myrsloik's Avatar
Of course not, they're based on a simple absolute difference. You need something fancier to get good results everywhere. Try scxvid?
Old 10th August 2017, 17:11   #35  |  Link
lansing
I just tried it, I clicked on preview in the editor, and after a minute or two of loading, the preview window popped up and the whole program frozed.
