Old 16th February 2014, 00:37   #201  |  Link
GMJCZP
GMJCZP's Avatar
Thanks for responding ozok.
Originally Posted by ozok View Post
An other user reported that too. I couldn't locate the source of the problem but I think it's about subtitles.
Always turn off the subtitles.
What are you trying to do? Are you using 32bit/64bit version of TEncoder? The bug report you've sent only gives information about why program crashed.
I use TEncoder 32 bit.
I notice that when the program hangs mencoder.exe or ffmpeg.exe remain open in the background.
I'm back again to reformat my PC and I tested (by CLI) a version that was saved from Mencoder, and using a very old version of Avisynth (to eliminate incompatibilities with the latest versions), now works but not like before. I'm trying now not update directx 9.0c (so I formatted again) and update the rest of Windows XP SP3. We'll see what happens.
GMJCZP is offline   Reply With Quote
Old 17th February 2014, 10:25   #202  |  Link
LigH
LigH's Avatar
Reformatting the PC won't be the recommendable solution for every case.
Let's just wildly guess (because you did not provide any useful facts about this part of your issue) that you are trying to process an AviSynth script via TEncoder, and your AviSynth script uses DirectShowSource. Then the main issue is probably based on the installed DirectShow splitters and decoders. And TEncoder is not to be blamed in the slightest. TEncoder, being only a user interface, is always the least probable reason, because it is rather passive once the conversion startet, only monitoring the work either ffmpeg or mencoder do.
New German Gleitz board
Old 17th February 2014, 22:54   #203  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
TEncoder isn't the ideal tool to encode avs scripts. Also post logs, if mencoder/ffmpeg hangs than they are waiting for an input or something.
ozok is offline   Reply With Quote
Old 18th February 2014, 01:52   #204  |  Link
GMJCZP
GMJCZP's Avatar
I know that formatting a PC is not practical, but it had other reasons to do so apart from the problems with these applications.
Now I doubt if I updated Directx causes more conflict, my system is WXP SP3 and in my last formatted did not.
I keep focused on the Mencoder. As I used a 2010 version with no problems, I started taking samples to Mencoder 35925 (sherpya versions) and all good so far. Appears to be significant changes made ​​in the latest versions, for example the option cbp is now o=mpv_flags=+cbp_rd.
Moreover I had to re-employ FFMS 2.19 , I was using a test mode this version, FFMS2 C-plugin r809+35:
http://forum.doom9.org/showthread.php?p=1658765#post1658765
The AVSI script that contains (I usually put it in the Avisynth plugins folder along with the dll and exe) was causing conflicts with Mencoder, without is calling (I use in my case AviSource)!
One more thing: always define -ofps option but an error occurs:
http://forum.doom9.org/showthread.php?t=101268
Conclusion : for now I'll stick with the version of Mencoder 35925. It works well using Avisynth. I would consider pending review FFMPEG.
Thank you once again for having the possibility to use such programs and I hope that the problems identified with Mencoder and FFmpeg are resolved promptly.
Old 20th February 2014, 15:57   #205  |  Link
ozok
ozok's Avatar
Update:
New version 3.8.0 changes:
-Added: Skinning is disabled by default
-Added: An option to copy source files' date/time info to output files
-Added: Support for *.mxf file type
-Fixed: A bug where TEncoder would get stuck even if encoding is done
-Fixed: A bug where checking "Export to script" would cause program to crash
-Fixed: "Apply" or changing selected preset didn't update the summary
-Fixed: "version.txt" errors
Old 21st February 2014, 06:04   #206  |  Link
kolpotoru
Thankyou for resuming the development of TEncoder & adding volume adjustment option. But the source code is not updated?
kolpotoru is offline   Reply With Quote
Old 21st February 2014, 10:18   #207  |  Link
ozok
ozok's Avatar
I update the source repo in bitbucket page: https://bitbucket.org/ozok/tencoder
Old 21st February 2014, 11:55   #208  |  Link
kolpotoru
Thanks for the Information.
Old 21st February 2014, 22:48   #209  |  Link
ozok
ozok's Avatar
No problem .
I'm working on a few new ideas:
-Creating video from an image file and an audio file
-Dubbing video with an external audio file (replacing the one in the video)
If anyone wants to try them out, let me know so I can post new executables here. Also specify the version you use.
Old 22nd February 2014, 06:08   #210  |  Link
kolpotoru
Dubbing video with an external audio file will be a useful addition but it should have option save to video with duel audio. This is one feature due to which many of us still use obsolete virtualdubmod. So if the new beta versions will support duel audio files output, i would like to try it. I will try it with version 3.8.0.
Old 23rd February 2014, 19:43   #211  |  Link
kolpotoru
The problem with mencoder is still there, TEncoder fails to encode audio of mpeg2 video files & using "Do not use audio id" TEncoder completely fails to encode the file. This should be fixed using SVN-r33883(20110719-gcc4.5.2) build of mencoder.
Please add a option in TEncoder to encode few seconds this is a very useful option because when we are not sure weather TEnoder will be able to convert video then rather then converting whole file converting few seconds for testing will be useful.
Old 23rd February 2014, 19:45   #212  |  Link
ozok
ozok's Avatar
You can use trimming to make a small test clip. Also post the log.
Old 23rd February 2014, 20:58   #213  |  Link
kolpotoru
The option to encode few seconds is available in "Moo0 VideoConverter" & it makes the task very easy.
The log files are empty because in first case the video file is converted without audio and in the second case using "Do not use audio id" option TEncoder produces a 0 byte avi file.
Old 23rd February 2014, 21:04   #214  |  Link
ozok
ozok's Avatar
I'm sure it does. Is it that difficult to set start/end points and start encoding? Log shouldn't be empty even if encoding fails.
Old 23rd February 2014, 21:54   #215  |  Link
kolpotoru
here are the empty logs.
Old 23rd February 2014, 22:20   #216  |  Link
kolpotoru
I have sent you a sample mpeg2 file.
Old 23rd February 2014, 23:03   #217  |  Link
ozok
ozok's Avatar
I've downloaded and tried to encode your file. It seems that neither MPlayer nor MEncoder cannot detect any audio from it. FFmpeg seems to be able encode it.
Mencoder's message regarding lack of audio in your file.
MPEG: No audio stream found -> no sound.
I tried the build that comes with TEncoder and the latest x64 build from http://oss.netfarm.it/mplayer-win32.php (where I used to get my builds). I don't know if this means your file is faulty or MPlayer/MEncoder buggy, you may wanna report that to MPlayer/MEncoder developers.
PS. TEncoder created perfect logs in my case.
Old 24th February 2014, 04:23   #218  |  Link
kolpotoru
The problem is not only with this file other mpeg2 files are also having same problem.
I think the problem is with the mencoder version included with TEncoder because i have replaced the mencoder included in TEncoder with SVN-r33883(20110719-gcc4.5.2) build of mencoder and it was able to convert the mpeg2 files.
Old 24th February 2014, 06:36   #219  |  Link
kolpotoru
Preview doesn't work from inside TEncoder but when the file is drag and dropped on mplayer it playes.
Old 25th February 2014, 01:29   #220  |  Link
GMJCZP
GMJCZP's Avatar
The problem with Mencoder to encode to MPEG2, besides those already mentioned with recent releases, is to be defined more options with TEncoder, but the program is interrupted. Try it with Mencoder to encode and use as container and codec MPEG2. The only way is to use the CLI mode and use old versions of Mencoder.
With FFMPEG no problems with the latest version of TEncoder (for encoding to MPEG2), only with Mencoder.
ffmpeg, gui, mencoder, multithreaded, subtitle
