4th December 2009, 16:07 | #9802 | Link | |
4th December 2009, 16:27 | #9803 | Link | |
IOW, with the MPC audio renderer, higher-than-16 bit is failing before even reaching the driver. Last edited by Andy o; 4th December 2009 at 16:30. |
4th December 2009, 17:49 | #9806 | Link | |
Media Control author
1/ VS 2008 (not 2010 it is crappy and so sloooow) 2/ DirectX SDK 3/ Grab last SVN release from bitstreamHD branch |
4th December 2009, 17:52 | #9807 | Link |
Alright. I'll start getting that set up. It'll likely be sometime this weekend before I have everything set up. Also, I don't do anything with SVN, so, I will need assistance on how to get the latest SVN release code. (Where it's located, etc) But I've got experience debugging in VS, so, once I get it set up I should be able to help figure out what's going on.
4th December 2009, 17:53 | #9808 | Link | |
The MPC renderer would accept anything in condition the audio driver would accept it. This is how it works However : LPCM has a special mediatype so this is the reason why you won't get 24/32 bits for now with the new ATIs. This has to be fixed on FFDShow : there is a LPCM checkbox in output section but I don't know what it is used for (DVD audio from the code). I wonder if it shouldn't be used in conjonction with 16/24/32/32 floats checkbox instead of exclusive (checking LPCM will disable the 16/24/32 checkboxes) ? Anyway, LPCM support is a second step, let's focus on HD audio bitstream : we need to confirm that THD/DTSHD are okay (EAC3, I am working on it) and that now with the last build the xonar is also working correctly Last edited by albain; 4th December 2009 at 17:55. |
4th December 2009, 18:06 | #9809 | Link |
@albain
The latest DirectX SDK I see is from November 2007. Is that the right one to grab? I've got VS 2k8 downloading now and the SDK will download after that.
4th December 2009, 18:13 | #9810 | Link |
Can we split the ffdshow bitstreaming discussion/development off to another thread? Seems like anything not relating to bitstreaming goes unnoticed and gets lost (bye bye, bug reports) in the 2/3 new pages made each day.
4th December 2009, 18:18 | #9811 | Link | |
MPC-HC Project Manager
Get the latest version here : http://www.microsoft.com/downloads/d...playlang=en#dx
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
4th December 2009, 18:20 | #9812 | Link | |
http://www.microsoft.com/downloads/d...displaylang=en |
4th December 2009, 18:23 | #9813 | Link |
Thanks, guys. Figures MSDN isn't up to date on that. The download of VS is still going. I found a subversion client to integrate into it. So, getting there.
4th December 2009, 18:28 | #9814 | Link | |
I propose to start over with a new thread this monday if necessary |
4th December 2009, 18:38 | #9815 | Link |
A.K.A Mangoat
Hi albain & fellow testers.
I'm sorry to say that I'm still not getting great results with this, certain files give me issues. One thing to note is that I'm playing back over a network currently - I don't think it will make a difference, but I will also try a problematic file from the local drive to be sure. DTS-HD: All show was 96000hz with 8 channels in the Ffdshow tray icon, with varying bitrates. I get stutters & audio drop outs. TrueHD: Seems to read the file data correctly, but I get audio stutter and drop outs on some files. I have tried both in m2ts and mkv with no luck. Using MPC-HC 1373, the internal splitter, beta 46 and the Arcsoft renderer. I'll post a sample for both problem files - do you want logs too? I guess yes. Thanks. |
4th December 2009, 18:51 | #9816 | Link |
Audiophile
hello i have started testing now too and xonar with ffdshow beta 46 and arcsoft audio renderer works with dolby-true hd from the hangover blu-ray remuxed to m2ts with tsmuxer no drop outs or anything i can tell. I have A dolby true-hd blu-ray with 7.1 and 96000hz track if you would like me to try. i am playing these files over a network as well i don't think that will cuase any problems at all null
4th December 2009, 19:00 | #9817 | Link |
Audiophile
alright the 7.1 dolby true-hd 96000hz bitreams perfect! no problems at all, same setup as the previous post WAIT EDIT there are some short dropouts but it is straight from disc with anydvd decrypting and playing the main movie m2ts. I don't think its because i am playing it from disc and not the hard drive so there are still a few things to be worked out. This is so wonderful i am not even taking the time to type a correct sentence or spell. Now i am going to try dts-hd and hr with the xonar
4th December 2009, 19:13 | #9819 | Link |
And chance you can look in the windows event viewer and post the offset that it's crashing at? This is an issue I'll be looking into as soon as I can get my dev env built up. Just want to see if the offset matches any of mine.
