Old 17th June 2010, 18:41   #1921  |  Link
SamuriHL
SamuriHL's Avatar
Originally Posted by dbone1026 View Post
I am sure Mike can come up with something. I know one issue with PGS subs was that MKVMerge didn't support, but according to SeeMoreDigital it appears that version 4.0 now supports PGS so who knows, maybe the sky is the limit. Mike's done a great job with AEAC and I am sure he still has more tricks up his sleeve
No, that's incorrect. 4.0 will pass through the PGS subs if they're already in the original MKV you're using as the source. It will not allow you to add them if they aren't there already.
Old 17th June 2010, 18:46   #1922  |  Link
dbone1026
Ahh...interesting. I wonder why add support to pass through but not add support to mux in????
Cheers,
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
dbone1026 is offline   Reply With Quote
Old 17th June 2010, 18:49   #1923  |  Link
SamuriHL
SamuriHL's Avatar
I suspect it's more complicated to add muxing support for it. With passthrough it's already there. I'm just guessing. I really have no idea.
Old 17th June 2010, 20:02   #1924  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I wonder if Mosu can shed some light.
I did a quick search of his thread and couldn't find anybody even requesting PGS subtitle support as a feature
Old 17th June 2010, 20:05   #1925  |  Link
SamuriHL
SamuriHL's Avatar
Oh that's not good. I was under the assumption it had been asked for. Oops!
On the plus side, I just got this all working in 7MC, as well. I forgot about the Win7DSTweaker requirement of shutting off the built in MS codecs and using ffdshow dxva instead. Subs and bitstreaming all working fine.
Old 17th June 2010, 20:32   #1926  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The support for reading PGS subs from Matroska files in mkvtoolnix was requested by one of the MakeMKV developers. I implemented that and extracting them in mkvextract. He argued that adding support for reading raw PGS files was not such a big priority as MakeMKV was the only app creating those files, and because MakeMKV already creates Matroska files.
mkvmerge will get raw PGS input support in the near future though.
Support for PGS in mkvmerge & mkvextract has been implemented at the end of 2009 with release 3.1.0.
Latest MKVToolNix is v83.0
Mosu is offline   Reply With Quote
Old 17th June 2010, 20:35   #1927  |  Link
SamuriHL
SamuriHL's Avatar
Very very nice, Mosu! Thank you!! This will give people options. The embedded PGS in an MKV is really nice, the haali issue aside. Looking forward to it!
Old 17th June 2010, 20:51   #1928  |  Link
SeeMoreDigital
Yes thanks Mosu...
Old 17th June 2010, 21:19   #1929  |  Link
SamuriHL
SamuriHL's Avatar
@albain
Can you take a look at these logs when you get a moment?
http://forum.doom9.org/showpost.php?...postcount=1877
What's really odd to me is that using Haali, my other machines that don't bitstream can decode the DTS core track just fine. It's just the bitstreaming that's an issue. I'm sure if you look at those logs you'll be able to tell why the bitstreaming is broken and maybe that'll help pinpoint the source of the problem. Maybe? Anyway, I'd appreciate it if you get a chance. Thanks!!
Old 17th June 2010, 22:02   #1930  |  Link
rica
samuri, i'd suggest you not to loose much time with other mkv muxers.
Just give it a go with Solveig for now; you'll get core ac3 and core dts from THD+ac3 or DTSHD.
Or only HD audio, whatever you wish.
rica is offline   Reply With Quote
Old 17th June 2010, 22:25   #1931  |  Link
SamuriHL
SamuriHL's Avatar
But it doesn't support PGS subs yet, right? Plus I'm not entirely sure how to even use it. I'm guessing you have to set it up in graphstudio? And only 32 bit at the moment, yes?
Old 17th June 2010, 22:32   #1932  |  Link
rica
Correct, it's 32 bit and doesn't support PGS subs yet.
But they are working on 64 bit muxer and i think new versions will support both of those missing things.
BTW i'm using Seven/64 and i can use it on MPC-HC as well. (while playing...)
Solveig 32 and MPC-HC 32...
Old 17th June 2010, 22:40   #1933  |  Link
SamuriHL
SamuriHL's Avatar
That'd be good. Another option would be nice to have. Once it supports 64 bit and PGS subs I'll give it a try. Be curious to see if we can get it to split for WMP and 7MC, as well. I think we're getting there though.
Old 17th June 2010, 23:34   #1934  |  Link
rica
I'm sure both features will be available in one month; i guess.
What ordinary users will need is gonna be a gui for the muxer.
Old 17th June 2010, 23:36   #1935  |  Link
SamuriHL
SamuriHL's Avatar
Yea, that's guaranteed. Most users aren't going to be able to load it up in graphstudio and attach everything correctly. Hell, I'm not even sure I know exactly how to do it myself. I could probably stumble my way through it, but... A tray icon for the splitter wouldn't hurt, either. That's one of the things I like about Haali.
Old 17th June 2010, 23:37   #1936  |  Link
dbone1026
Any reason to use Solveig over the MPC splitter (Matroska)? Neither support PGS but aside from that MatroskaSplitter.ax has been rock solid. Always good to have choices
Cheers,
Damian
Old 17th June 2010, 23:44   #1937  |  Link
rica
I've been talking about muxer; no any other muxer is able to remux any thd+ac3 file into an mkv container
for now. So finally you can get ac3 core or dts core seperately as you wish via Solveig Splitter over ffdshow.
Pls have a look at this:
http://forum.doom9.org/showthread.ph...28#post1408828
Old 17th June 2010, 23:46   #1938  |  Link
SamuriHL
SamuriHL's Avatar
Just as an FYI, MakeMKV has that ability.
Old 17th June 2010, 23:51   #1939  |  Link
rica
Really?
Thx, i'll give it a go.
Old 17th June 2010, 23:53   #1940  |  Link
SamuriHL
SamuriHL's Avatar
Yup. It's quite awesome. It allows you to extract the core audio as a separate track while keeping or removing the HD audio track. It can do similar things with subs (forced can be extracted to a separate sub track while keeping or removing the original). I really like it.
