Old 14th December 2008, 15:00   #41  |  Link
Let's draw the line right here and confine further discussion to the technical evaluation of the decoder.
Old 18th December 2008, 14:11   #42  |  Link
schweinsz
The Direct_8x8_inference_flag = 0 has been finished.
I will finish the weighted_bipred_idc in recent days.
After this, I will work about the multi-thread decoding and the DiAVC will work much faster than it is now.
schweinsz is offline   Reply With Quote
Old 24th December 2008, 20:52   #43  |  Link
schweinsz
weighted_bipred_idc = 0, 1, 2 is supported now. I will work on the improvement of the CABAC and multi-thread decoding.
Old 25th December 2008, 16:48   #44  |  Link
popper
Originally Posted by schweinsz View Post
I am happy to anounce that the DiAVC, another high profile decoder is released.
http://sites.google.com/site/diavcdecoder/
The supported features:
I Slice, P Slice, B Slice
Custom Quantization Matrix
CAVLC and CABAC
Deblocking Filter
Multi-reference frames
Direct_8x8_inference_flag = 1 or 0
IPCM
Constrained_intra_pred_flag = 1 or 0
transform 8x8 and 4x4
Need CPU with SSE2
Windows XP, Windows Vista and Windows 2000 are supported
On coming features:
weighted_pred_flag
interlaced supporting
Multi-Core supporting
Because the DiAVC's development is in early stage, I only provide the dll and the testbed. I'll add the supports on Direct_8x8_inference_flag = 0, weighted_bipred_idc and Multi-Core supporting, and then the interlaced supporting.
I have tested my DiAVC on my laptop with a Core Duo CPU of 1.86GHz using the CABAC high profile bitstream. The throughput is about 19mbps with 50% CPU fullness (single thread on a dual-core CPU). Because the DiAVC's development is in early stage, there are many space to be optimized to get a faster decoder, such as the un-optimized MC, transform8x8 and CABAC decoding.
Besides, where is some directshow samples I can reference?
I want to code a directshow transform filter for my DiAVC.
its very odd that you state you want to release your app as commercial property today ,however you dont even see fit to put MBAFF and PAFF on the top of your must have list, that IS the most required option for many people around the world that have access to DVB-* MBAFF and PAFF encoded content (the UK, EU, HD cams, etc) right now and want to decode it (better than)realtime for processing.....
will you infact be including these essential MBAFF and PAFF decoder options in your base code/app.
http://en.wikipedia.org/wiki/H.264
"Flexible interlaced-scan video coding features, including:
Macroblock-adaptive frame-field (MBAFF) coding, using a macroblock pair structure for pictures coded as frames, allowing 16×16 macroblocks in field mode (compared with 16×8 half-macroblocks in MPEG-2).
Picture-adaptive frame-field coding (PAFF or PicAFF) allowing a freely-selected mixture of pictures coded as MBAFF frames with pictures coded as individual single fields (half frames) of interlaced video.
popper is offline   Reply With Quote
Old 25th December 2008, 20:39   #45  |  Link
Mr VacBob
I'm not surprised you can make a fast and simple decoder by not supporting interlacing, but it gets harder afterwards.
(didn't you post complaining about "redundant operations" in libavcodec? what part of the decoder was that referring to?)
Mr VacBob is offline   Reply With Quote
Old 27th December 2008, 07:57   #46  |  Link
schweinsz
I will start to work on the interlaced supporting (including the MBAFF and PAFF) after I finished the multi-thread decoding.
Old 27th December 2008, 08:08   #47  |  Link
schweinsz
Adding interlacing will not influence the speed of frame decoding because you can use a totally different slice decoding.
Regarding to the "redundant operations" in liavcodec, for example, the zerosleft decoding can be merged with the dequantization instead of two loop, take another example, the algorithm of cabac decoding and context computation is very un-efficient.
Old 27th December 2008, 13:33   #48  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
What are you talking about with the zerosleft decoding? It is merged with dequantization, and is not two loops (and I don't think this was done recently either).
Would you like to point me to a specific case so I can fix it rather than complaining?
Any suggestion for improved context calculation performance will probably allow me to make x264's RDO faster as well.
Same with the actual CABAC decoding--are you suggesting that there is a better way to organize LUTs/similar that results in better faster arithmetic decoding than what LAVC already has?
Old 27th December 2008, 14:49   #49  |  Link
schweinsz
Originally Posted by Dark Shikari View Post
What are you talking about with the zerosleft decoding? It is merged with dequantization, and is not two loops (and I don't think this was done recently either).Would you like to point me to a specific case so I can fix it rather than complaining?
Yes, I have read the latest libavcodec in ffdshow tryouts, It has been merged.
Regarding to the context calculation, take the coded block flag decoding as a example,
const unsigned int iCabac4x4CnxtAdd[8] = {0x9, 0x18, 0x801, 0x810, 0x9, 0x100008, 0x801, 0x100800};
unsigned int contxt = contxt1+contxt2;
for(int i=0; i<16; i++)
int contextcurr = contxt&3;
contxt >>= 2;
if(cbp[i>>2])
cbf = cabac_dec_symbol(..., contextcurr);
if(cbf)
contxt += iCabac4x4CnxtAdd[i&7];
update the contxt1 and contxt2 using the contxt;
Yes, I have a faster arithmetic decoding and I have written part of it into the DiAVC.
Old 27th December 2008, 14:54   #50  |  Link
Dark Shikari
x264 developer
contxt >>= 2;
if(cbp[i>>2])
if(cbf)
You know there is no way in hell that'll work with interlacing, right?
OK, I'll see what I can take from it then.
Old 27th December 2008, 14:56   #51  |  Link
schweinsz
After I finished the DiAVC, I will improve the x264 and it is opensource. I can improve the computational efficiency of the ME&CABAC at least.
Old 27th December 2008, 15:00   #52  |  Link
schweinsz
You know there is no way in hell that'll work with interlacing, right? OK, I'll see what I can take from it then.
Why do you say that the cbf decoding dont work with interlacing? I think the cbf decoding can work with the interlace. It is possible to take a small change to fit into the mbaff. I am not familar with the mbaff.
Old 27th December 2008, 15:12   #53  |  Link
Dark Shikari
x264 developer
Come to #x264dev on Freenode. We welcome optimizations--even just ideas for optimizations that you don't want/don't have time to implement--plus, you could also help with the upcoming MBAFF patch (currently the code has far too many calls to getNeighborAff() )
MBAFF rules for CBF selection are AFAIK rather messy...
Old 28th December 2008, 07:17   #54  |  Link
akupenguin
x264 developer
akupenguin's Avatar
Latest?! It was merged in r4617 in 2005.
Old 28th December 2008, 08:33   #55  |  Link
schweinsz
I even read a very old livavcodec in this summer. Perhaps a version in 2004.
Old 29th December 2008, 17:23   #56  |  Link
schweinsz
Come to #x264dev on Freenode. We welcome optimizations--even just ideas for optimizations that you don't want/don't have time to implement--plus, you could also help with the upcoming MBAFF patch (currently the code has far too many calls to getNeighborAff() )MBAFF rules for CBF selection are AFAIK rather messy...
I even read the x264. It seems that the SSD in RDO is computed after the reconstraction. But to the best of my knowledge, It can be gotten directly from the transform domain exactly. A scale for coefficients is needed for the transform in H.264. So after de-quantization, the SSD can be gotten. The IDCT and add to mc signal is bypassed. But I have no time now to write it.
Old 29th December 2008, 17:29   #57  |  Link
Dark Shikari
x264 developer
We actually just happened to discuss this in #x264dev recently, and we concluded that it isn't very useful.
The reason it isn't useful is:
1. iDCT is really fast.
2. Psy-RD requires iDCT to be done anyways. It isn't really worth optimizing too much for the case of no psy-opts.
3. It would make the code much messier.
4. SSD in transform domain is not *exactly* the same because of rounding.
5. SSD in transform domain would require a new asm function to multiply by the correct DCT weighting values for each coefficient.
(By the way, this is the proper approach: suggest ideas before implementing them so that you don't waste time on something that has been concluded to be a bad idea, or so that we can suggest even better ways of doing it.)
Old 5th October 2009, 23:29   #58  |  Link
schweinsz
I am happy that DiAVC alpha version is released. The diavc.ax and a setting tool is included.
It supports the interlace coding and frame-level parallel.
I have tested the DiAVC and compared to other decoders and found that the DiAVC is faster than the coreavc and divx h.264 decoder on my computer (intel core duo T2350 1.86G, ram 1G, FSB 533MHz, harddisk, 80G, ati mobility radeon x1450).
Old 6th October 2009, 01:21   #59  |  Link
Sagekilla
x264aholic
@Dark: Regarding the change that would bork interlacing: Would it really be that bad if you created two code paths, one designed solely for progressive video, and another for field based?
I'm sure there's a very good reason why not to, and the only reasons I could think of where because of massive code duplication and messy code.
Sagekilla is offline   Reply With Quote
Old 6th October 2009, 01:23   #60  |  Link
Dark Shikari
x264 developer
CoreAVC already does this. I don't really feel like doing it with x264. It'd be ugly, and hardly worth it for ~1% speed or whatever we'd get.
avc, diavc, fastest decoder, h.264, software
