28th October 2015, 20:08 | #1501 | Link | |
Software Developer
Probably not a good idea. Someone will complain he has to re-enable the option every time now
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 28th October 2015 at 20:11. |
30th October 2015, 02:25 | #1502 | Link |
If I am sitting at my pc, this is no problem at all, of course. The cancel-button is pressed easily in that case. But sometimes I start an encode, go eating, to sleep, shopping (...), start a long download too and other jobs, come back and the pc is shut down while the other jobs could not be finished and have to be started all over again. Or I start an encode, go to the living room and want to use my pc as a media server and at sometime suddenly the connection is lost. So, every time I start your launcher, at first I go to preferences and check, if the shutdown-option is checked or not - just to be safe. Sometimes the shut down is welcome, sometimes not. I change that setting regularly.
30th October 2015, 07:45 | #1503 | Link |
User of free A/V tools
If you keep changing that setting regularly then no one else but you must pay attention when is it ON or OFF and ensure that no other tasks are running when encoding job finishes.
Personally, I never used that option because there are far better ways to save power in Windows. Just check your power settings and setup idle times as needed. That way, your PC will run at full power when needed (encoding video) and can switch off automatically as well once no active tasks are running. |
30th October 2015, 08:23 | #1504 | Link |
My energy saving settings are perfectly set. There is no way to save more power for hours then pull the plug. My CPU is running idle almost every time, my GPU too, my monitor switches of after 5 minutes inactivity, my harddrive is permanently on, because I do not shorten its lifetime with unnecessary spin-ups. And if I do not use the system at all, its shut down completely. No hibernation. And I do not want to let my system automatically shut down when no task is running. Sometimes the system has to be running, so I can use it, when I want to, without to change to floor, wait till bootup finishes ...
Yes, I have to pay attention. This is why I check the prefs on every startup. Because I switch so often, I do not know, if I had it set or not. You must not understand that. But you have to accept, that other people think, plan and work different than you. Other tools, like JDownloader, have that function too and it is - for this reason - solved by a permanently viewable button on top of the main window. Further tools, like Comodo Internet Security, solved the deactivation of some protections by options like "disable for 10 minutes", "disable for one hour" or "disable until next system boot" but not permanently. The last one equals the shutdown-switch with an automated reset to off, after the one shut down. There are many other programs solving the shut-down like a one-time-option, because a shut-down is a big deal. I thought, my suggestion would be easy to integrate and also be welcome. Last edited by almosely; 30th October 2015 at 08:29. |
13th November 2015, 03:52 | #1505 | Link |
Gud day Lord!
I am very grateful that you've made this application. And I am using this ever since. As of this writing, I am still using v2.46.902. I am trying to install the latest version but it has issues with my system ( win 7 - 64 bit ). It stops my Catalyst Control System. Another issue also that I am experiencing now (with v2.46.902) is that, even if the I disable the "Auto update notification on start up", it still notifies me to check for update everytime I open the application. I hope you can address this problems and once again thank you very much and more power. |
13th November 2015, 21:26 | #1506 | Link | |
Software Developer
Yes, it's possible that the installer (LockedList plug-in) will ask you to close certain applications, if and only if those applictions block files that need to be overwritten by the installer. But it certainly won't stop those applications by itself. So this sounds more like there's an unrelated problem with your display driver ("Catalyst" is the AMD display driver), which happened to hit while you were trying to install/use Simple x264 Launcher. That's a pretty old version. Update notifications become more emphatic after a while. And that is intentional
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 13th November 2015 at 21:36. |
18th November 2015, 21:10 | #1507 | Link | |
Software Developer
Simple x264 Launcher v2.62
https://github.com/lordmulder/Simple...ases/tag/v2.62 Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th November 2015 at 21:13. |
18th December 2015, 17:29 | #1508 | Link |
I only found this application recently & want to say how terrific it is. I've been a long time user of MeGUI til now, but have made the switch to Simple x264 Launcher for most projects.
I have a feature request I hope you'll consider. Currently I use batch files utilizing your CLI switches to load many jobs, which works a treat. However there is no quick way to delete multiple jobs in the queue, instead having to delete them one at a time. A workaround is closing the program, telling it to discard the jobs at close, then confirming that choice, and after that I can reopen Simple to start over, but that is a bit cumbersome, and not an option if you have jobs currently running that you don't want to abort. I am hoping you can the add the option to select multiple jobs from the list for deletion. It'd be very helpful for those who run 20-30+ jobs at a time. |
19th December 2015, 17:43 | #1509 | Link |
Software Developer
selecting multiple jobs is "problematic". For example, for which job do we show the details in the lower pane, if multiple jobs can be selected in the upper pane? Maybe I will just add an "Remove all (completed) jobs" entry to the "File" menu...
19th December 2015, 17:44 | #1510 | Link |
4k encoding probs
Hey Mulder,
I guess this is more of a x264/x265 complaint and likely not your problem. I have a 26 second 4k file I am trying to encode and when reducing the resolution to 1080p it encodes fine, but when keeping the native resolution it is always corrupt when producing an x264 encode. Also when trying to encode to x265 it tells me the input source is not valid. The source file is: AVI 24 bit RGB (RV24) 24 FPS 4096x1706 Any ideas? Thanks! |
19th December 2015, 18:06 | #1511 | Link | |
Software Developer
The latter clearly can not work with x265. And with x264 you'd be using the "built-in" FFMS2 source filter, which may (or may not) be able to decode your source. Might very well be the problem you are describing. If you are using Avisynth or VaporSynth, do other programs (e.g. VirtualDub) open your script correctly?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th December 2015 at 18:14. |
19th December 2015, 18:21 | #1512 | Link | |
The source file is an uncompressed AVI generated in Adobe After effects. Is there some technical reason x265 wont accept that as a source input? |
19th December 2015, 18:30 | #1513 | Link | |
Software Developer
(Source should be provided in YUV4MPEG format, to exclude decoding issues) I don't think x265 CLI can read anything as input, except for "raw" YUV data and YUV4MPEG. Has that ever changed?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th December 2015 at 18:36. |
19th December 2015, 18:49 | #1514 | Link | ||
I am cognizant that you are helping me with "my" problem and I hope I am not being a pest. |
19th December 2015, 18:54 | #1515 | Link | ||
Software Developer
ffmpeg.exe -i input.avi -pix_fmt yuv420p -f yuv4mpeg output.y4m Quote:
And that is, of course, exactly what the Simple x264/x265 Launcher is going to do, if you select an AVS or VPS script file as your input... (You can also pipe from FFmpeg, which is essentially the same outcome as using x264's "built-in" FFMS2 source)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th December 2015 at 19:17. |
19th December 2015, 19:22 | #1516 | Link | |
And this brings up another question. If I am "downgrading" the chroma to 420, what if I want 422 or 444? And if x265 is supposed to support enhanced chroma ranges and HDR, why does it need to be reduced to 420? Again, sorry, I know this is not specifically a Launcher problem.... Oh wait, can I also import yuv422p and yuv444p? Last edited by ben_franklin; 19th December 2015 at 19:24. |
19th December 2015, 19:30 | #1517 | Link | |
Software Developer
Just use Avisnyth (or VapurSynth) to load your AVI file and drop it into Simple x264/x265 Launcher. The the most simple case, the AVS script you need is a one-liner FFVideoSource("C:\Path to my file\Input.avi") Someone correct me if I'm wrong, but I think at this point there are only the "Main" and "Main 10" profiles of H.265/HEVC finished, which provide 4:2:0 chroma sub-sampling with 8-Bit and 10-Bit per pixel, respectively.
19th December 2015, 19:36 | #1518 | Link | |
19th December 2015, 20:43 | #1519 | Link | |
I did this and the resultant file was half the size. It also completely murdered the colors, and the result was visually indistinguishable from the 1080p version. The spacial resolution advantage was visually undetectable. How do the studios do it when remastering down to blu ray? |
20th December 2015, 02:01 | #1520 | Link | |
Software Developer
Simple x264 Launcher v2.64
https://github.com/lordmulder/Simple...ases/tag/v2.64 Quote:
