Old 8th February 2013, 23:35   #3021  |  Link
invy
I will upload the sample a little later if necessary but I ran MediaInfo and noticed something:
General
Complete name                            : D:\jjsample.mpg
Format                                   : MPEG-PS
File size                                : 36.7 MiB
Duration                                 : 1mn 0s
Overall bit rate mode                    : Variable
Overall bit rate                         : 5 123 Kbps
Video
Format                                   : MPEG Video
Commercial name                          : HDV 720p
Format version                           : Version 2
Format profile                           : Main@High
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : Variable
Duration                                 : 1mn 0s
Bit rate mode                            : Variable
Bit rate                                 : 4 829 Kbps
Maximum bit rate                         : 10.2 Mbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Active Format Description                : Letterbox 16:9 image
Frame rate                               : 59.940 fps
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.087
Stream size                              : 34.6 MiB (94%)
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
ID                                       : 189 (0xBD)-128 (0x80)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Muxing mode                              : DVD-Video
Duration                                 : 1mn 0s
Bit rate mode                            : Constant
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 1.38 MiB (4%)
Text #1
ID                                       : 224 (0xE0)-CC1
Format                                   : EIA-608
Muxing mode                              : A/53 / DTVCC Transport
Muxing mode, more info                   : Muxed in Video #1
Stream size                              : 0.00 Byte (0%)
Text #2
Format                                   : EIA-708
Text #3
Format                                   : EIA-708
Text #4
Format                                   : EIA-708
Text #5
Format                                   : EIA-708
Let me know if I shall still upload the sample later.
invy is offline   Reply With Quote
Old 9th February 2013, 12:01   #3022  |  Link
Zathor
I need at least the MeGUI log file with the MediaInfo in order to drop those suptitles.
EDIT: Better would be a sample so that I can verify my changes
EDIT2: fixed (hopefully)
Zathor is offline   Reply With Quote
Old 9th February 2013, 14:23   #3023  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
The MeGUI main window could display estimated time and FPS in place of the end job time and FPS on the queue tab.
At least optionally in case if one has switched off status windows.
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline   Reply With Quote
Old 10th February 2013, 14:02   #3024  |  Link
Zathor
Originally Posted by invy View Post
why doesn't the 'Go' button in OC mode not open the 'browse file' window anymore? Please change it back. It's kinda annoying having to make 2 extra clicks.
You can add several files at once using the folders mode or by drag&drop the files into the input video box. Do you know that?
Old 10th February 2013, 14:02   #3025  |  Link
Zathor
Please post that as a feature request on the SF page. No time yet to implement it, but I like the idea and do not want to forget it.
Old 10th February 2013, 15:44   #3026  |  Link
Zathor
2294 [OneClick] only supported subtitle tracks will be added
2293 [AVS Script Creator] fixed "Clever (TM) anamorphic encoding" if using "Encode non-mod 16"
2292 [AVS Cutter] fixed not fading to black
2291 [M2TS Muxer] disabled pure TrueHD as it is not supported by tsMuxeR
2290 [AVS Script Creator] removed "Successfully converted to YV12" message
2289 [OneClick] fixed error when opening some files. Bug #703
2288 [MP4 Muxer] added support for Apple TV & iPad
Old 10th February 2013, 23:01   #3027  |  Link
invy
Yes. For some reason, though, half of the time it does not register that i'm drag & dropping to the input box (the little + icon does not appear).
Speaking of which, my suggestion a few weeks ago about auto-select OneClick profile based on filename, is that a No?
And i'll have the log info for you later today for the other bug weirdness.
Old 10th February 2013, 23:39   #3028  |  Link
Zathor
Please upload - if possible - a few sample files. I never had this kind of problems.
Yes, at least for the moment. I do not need that feature and as I only have a few minutes here and there for MeGUI I will not spend much time for such features which are out of my interest and I believe of most of the other MeGUI users. But add it as a feature request to SF please.
Please try 2294 first. The problem should be fixed already.
Old 10th February 2013, 23:52   #3029  |  Link
invy
1. It seems to occur randomly but when it happens again i'll upload samples. i'll also try and test it myself but only selecting a few files of the group to see if I can perhaps narrow it down to one file. it kind of feels like an Windows bug though.
2. I can't believe that i'm the only one bothered by the repetitiveness of constantly having to encode things. I've grown very weary of it. haha.
3. I'm using 2287 so I will try to update and report back later.
Thanks!
Old 11th February 2013, 15:52   #3030  |  Link
Poutnik
Poutnik's Avatar
Done. I have finally succeeded in suggesting something useful .
#498 Estimated time and FPS of current job on the queue tab
Old 11th February 2013, 17:35   #3031  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Define "Main Window"...at least, in which place do you want to have such informations ?
Old 12th February 2013, 00:06   #3032  |  Link
Poutnik
Poutnik's Avatar
It is already listed in original post and in FR,
There is noted in the Queue tab in the main window,
for the in progress job.
End time and FPS columns for in progress item
in the Queue list are empty, while they can contain useful realtime information.
At least from context it was clear to Zathor.
I thought there is no other main window but the one
that is launched at the MeGUI start
and from which all other windows are launched.....
Old 12th February 2013, 08:20   #3033  |  Link
invy
@Zathor: problem with it adding subtitle 2,3,4,5 which was mentioned earlier seems to be no longer with 2294. Thanks!
Old 12th February 2013, 23:08   #3034  |  Link
bilditup1
bilditup1's Avatar
Small patch for mp4 chapters
https://sourceforge.net/p/megui/patches/66/
When using the MP4 muxer with an iDevice target, OGG-format chapter files are converted to the xml chapters that iDevices support by a simple method in FileUtil.cs. As written, however, it does not escape double-quotes in chapter names. This is a problem because in the xml format, chapter names are bookended by quotes, so if there is a quote mark in the chapter title, the chapter name is truncated, and the structure of the entire xml file is broken. When this happens, the mp4 file fails to mux, with nothing in the error log to tell you what the hell just happened. This simple patch replaces all " with ampersand-quot;. It has been tested as effective in mpc-hc x64, xbmc frodo for rpi, and the iOS 6 video player.
Also in this patch is a removal of a switch that prevents chapters from being added the 'Nero Digital' way if the target is specified as an iDevice. In other words, both ogg format and xml format chapters are muxed into the MP4 file. This means that software and devices that don't understand xml chapters - for example, mpc-hc cannot read them without special filters like lav - have something to fall back on. Adding the ogg chapters and xml chapters does NOT break compatibility with software that can read both (mpc-hc with filters), or with iDevices (which only recognize xml chapters).
bilditup1 is offline   Reply With Quote
Old 12th February 2013, 23:16   #3035  |  Link
bilditup1
bilditup1's Avatar
iPad 'support' just seems to be adding another switch in the menu, but nothing really distinct underneath from what I can tell Maybe all the switches should be replaced by 'Apple' for all devices except the iPhone, and 'iPhone'.
Old 13th February 2013, 09:27   #3036  |  Link
invy
Suggestion: In One-Click mode, can you make the "Automated Folder Processing" window pop up in the foreground instead of the background? It seems very unnecessary that it hides behind other windows, not to mention it quickly has become very annoying, imo.
Even better, how about 'do not show again' box for it? If someone drags multiple files to the input box, then that is exactly what they wanted to do. They should not need any confirmation.
Old 13th February 2013, 09:33   #3037  |  Link
Kurtnoise
Kurtnoise's Avatar
Nope...coz it's just more useful to end users to have such entries instead of only one.
In addition, it might help to have this in the code to check/restrict Audio formats when we select an Apple Device as target.
btw, thanks for your patch. I'll look at it asap.
Old 13th February 2013, 18:53   #3038  |  Link
bilditup1
bilditup1's Avatar
Yeah I see that, but it's giving the perception to people that there are actually different profiles underneath for each iDevice. It'll make for less-informed users, no?
Great idea, but I don't think this varies from iDevice to iDevice.
My pleasure! I actually came across the issue about a month ago, even made the patch, but forgot to submit it till yesterday, ha
Old 17th February 2013, 12:12   #3039  |  Link
Zathor
2296 [x264] fixed --crf and --partitions not set to default settings for new MeGUI installations
2295 [OneClick] fixed some "index out of bounds" errors. Bug #703 + #707
Old 25th February 2013, 07:26   #3040  |  Link
AMED
AMED's Avatar
Hi Zathor,
I seem to still getting the bug when using the one click encoder when there is "Error" in the file name.
If i change the filename to S04xE06 - Margin Of Erro-.mkv, the one click encoder works fine.
[Error] Log
-[Information] Versions
--[Information] [25/02/2013 7:19:24 p.m.] MeGUI: 2300
--[Information] [25/02/2013 7:19:24 p.m.] Operating System: Windows 8 Professional Edition x64 (6.2.0.9200)
--[Information] [25/02/2013 7:19:24 p.m.] .Net Framework: 4.5 (4.5.50709)
--[Information] [25/02/2013 7:19:25 p.m.] AviSynth: 2.5.8.5 (21/12/2008 9:46:54 p.m.) - portable
--[Information] [25/02/2013 7:19:25 p.m.] DevIL: 1.6.6 (26/05/2004 12:37:34 p.m.)
--[Information] [25/02/2013 7:19:25 p.m.] AvisynthWrapper: 2/01/2009 8:34:04 p.m.
--[Information] [25/02/2013 7:19:25 p.m.] Haali Matroska Splitter: 1.11.96.14 (3/03/2011 11:40:46 a.m.)
--[Information] [25/02/2013 7:19:25 p.m.] Haali DSS2: 3/03/2011 11:37:50 a.m.
--[Information] [25/02/2013 7:19:25 p.m.] ICSharpCode.SharpZipLib: 0.85.5.452 (7/08/2008 9:31:12 p.m.)
--[Information] [25/02/2013 7:19:25 p.m.] LinqBridge: 1.0.0.0 (28/05/2009 1:24:34 a.m.)
--[Information] [25/02/2013 7:19:25 p.m.] MediaInfo: 0.7.62.0 (22/02/2013 10:32:55 a.m.)
--[Information] [25/02/2013 7:19:25 p.m.] MediaInfoWrapper: 0.7.61.0 (6/01/2013 2:47:15 p.m.)
--[Information] [25/02/2013 7:19:25 p.m.] MessageBoxExLib: 1.0.2218.28317 (19/12/2008 7:53:04 p.m.)
--[Information] [25/02/2013 7:19:25 p.m.] SevenZipSharp: 0.64.3890.29348 (2/01/2011 10:59:32 a.m.)
--[Information] [25/02/2013 7:19:25 p.m.] 7z: 9.20 (18/11/2010 4:27:34 p.m.)
-[Information] Update detection
--[Information] [25/02/2013 7:19:25 p.m.] Connecting to server: http://megui.xvidvideo.ru/auto/
--[Information] [25/02/2013 7:19:27 p.m.] All files are up to date
-[Information] OneClick
--[Information] [25/02/2013 7:19:53 p.m.] MediaInfo
---[Information] File: E:\WIRE_S4_DISC1\S04xE06 - Margin Of Error.mkv
---[Information] General
----[Information] Format: Matroska
----[Information] FormatString: Matroska
----[Information] FileSize: 2025370179
----[Information] PlayTime: 00:57:59.840
---[Information] Video
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] Width: 720
----[Information] Height: 576
----[Information] FrameCount: 86996
----[Information] FrameRate: 25.000
----[Information] FrameRateOriginal:
----[Information] FrameRateMode: CFR
----[Information] ScanType: Interlaced
----[Information] Codec: V_MPEG2
----[Information] CodecString: MPEG-2 Video
----[Information] Format: MPEG Video
----[Information] AspectRatio: 1.333
----[Information] AspectRatioString: 4:3
----[Information] Delay: 0
----[Information] Title:
----[Information] Language: en
----[Information] LanguageString: English
----[Information] Default: No
----[Information] DefaultString: No
----[Information] Forced: No
----[Information] ForcedString: No
---[Information] Audio
----[Information] ID: 2
----[Information] StreamOrder: 1
----[Information] Format: AC-3
----[Information] FormatProfile:
----[Information] FormatSettingsSBR:
----[Information] FormatSettingsPS:
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 KHz
----[Information] Channels: 6
----[Information] ChannelsString: 6 channels
----[Information] ChannelPositionsString2: 3/2/0.1
----[Information] BitRateMode: CBR
----[Information] Title: 3/2+1
----[Information] Default: Yes
----[Information] DefaultString: Yes
---[Information] Text
----[Information] ID: 3
----[Information] StreamOrder: 2
----[Information] Codec: S_VOBSUB
----[Information] CodecString: VobSub
--[Information] [25/02/2013 7:19:54 p.m.] MkvInfo
---[NoImage] File 'E:\WIRE_S4_DISC1\S04xE06 - Margin Of Error.mkv': container: Matroska [duration:3479840000000 segment_uid:d9bba726a52c0c61d6ea404f46f3507f]
---[NoImage] Track ID 0: video (V_MPEG2) [number:1 uid:1 codec_id:V_MPEG2 codec_private_length:152 codec_private_data:000001b32d02402317ed2382101010101010101010101010101010101010101010101010101010101212121010101010101010101212121412121212121414141414181818181c1c1e22222b08080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808000001b51482000100000000 language:eng pixel_dimensions:720x576 display_dimensions:768x576 default_track:0 forced_track:0 enabled_track:1 default_duration:40000000]
---[NoImage] Track ID 1: audio (A_AC3) [number:2 uid:2 codec_id:A_AC3 codec_private_length:0 language:eng track_name:3/2+1 default_track:1 forced_track:0 enabled_track:1 default_duration:32000000 audio_sampling_frequency:48000 audio_channels:6]
---[NoImage] Track ID 2: subtitles (S_VOBSUB) [number:3 uid:3 codec_id:S_VOBSUB codec_private_length:509 codec_private_data:2320566f6253756220696e6465782066696c652c2076372028646f206e6f74206d6f646966792074686973206c696e6521290a23200a23205468697320696e64657820626c6f636b207761732067656e657261746564206279204d616b654d4b562076312e372e31302077696e287836342d72656c65617365290a2320776869636820686173206e6f2072656c6174696f6e20746f20566f6253756220736f6674776172652e205468652066697273740a23206c696e652061626f76652069732070726573656e7420666f7220636f6d7061746962696c69747920726561736f6e732e0a23200a73697a653a20373230783537360a6f72673a20302c20300a616c7068613a20313030250a736d6f6f74683a204f46460a66616465696e2f6f75743a2035302c2035300a616c69676e3a204f4646206174204c45465420544f500a74696d65206f66667365743a20300a666f7263656420737562733a204f46460a6c616e676964783a20300a70616c657474653a203030303065312c206538336630372c203030303030302c206664666466642c206330353132612c206561313265622c206661666631612c203039356437362c203763376337632c206530653065302c203730316630332c203037373330372c203030303036632c206363306165392c206432616230662c203733303937320a23200a2320656e640a language:eng default_track:1 forced_track:0 enabled_track:1]
---[NoImage] Chapters: 8 entries
--[Information] [25/02/2013 7:19:56 p.m.] Video: E:\WIRE_S4_DISC1\S04xE06 - Margin Of Error.mkv
--[Information] [25/02/2013 7:19:56 p.m.] Audio: E:\WIRE_S4_DISC1\S04xE06 - Margin Of Error.mkv ([2] - AC-3 - 6 channels / 48.0 KHz / English)
--[Information] [25/02/2013 7:19:56 p.m.] Subtitle: E:\WIRE_S4_DISC1\S04xE06 - Margin Of Error.mkv ([2] - VOBSUB / English)
-[Error] Log for job1 (ext, S04xE06 - Margin Of Error.mkv -> )
--[Information] [25/02/2013 7:20:04 p.m.] Started handling job
--[Information] [25/02/2013 7:20:04 p.m.] Preprocessing
--[Information] [25/02/2013 7:20:04 p.m.] MediaInfo
--[Information] [25/02/2013 7:20:04 p.m.] Job commandline: "D:\MEGUI\tools\mkvmerge\mkvextract.exe" tracks "E:\WIRE_S4_DISC1\S04xE06 - Margin Of Error.mkv" --ui-language en 1:"E:\WIRE_S4_DISC1\mx2i0cmd.j55\S04xE06 - Margin Of Error - [1] English.ac3" 2:"E:\WIRE_S4_DISC1\mx2i0cmd.j55\S04xE06 - Margin Of Error - [2] English.idx"
--[Information] [25/02/2013 7:20:04 p.m.] Extracting started
--[Error] [25/02/2013 7:20:18 p.m.] An error occurred: Writing the VobSub index file 'E:\WIRE_S4_DISC1\mx2i0cmd.j55\S04xE06 - Margin Of Error - [2] English.idx'.
--[Information] [25/02/2013 7:20:18 p.m.] Standard output stream
---[NoImage] Extracting track 1 with the CodecID 'A_AC3' to the file 'E:\WIRE_S4_DISC1\mx2i0cmd.j55\S04xE06 - Margin Of Error - [1] English.ac3'. Container format: Dolby Digital (AC3)
---[NoImage] Extracting track 2 with the CodecID 'S_VOBSUB' to the file 'E:\WIRE_S4_DISC1\mx2i0cmd.j55\S04xE06 - Margin Of Error - [2] English.idx'. Container format: VobSubs
--[Information] [25/02/2013 7:20:18 p.m.] Standard error stream
--[Information] [25/02/2013 7:20:18 p.m.] Job completed
A Man Eating Duck
AMED is offline   Reply With Quote
